Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 03-27-2018, 09:14 AM   #1
Brandon07STi
Member#: 480215
Default P0457 & P0171
2007 Subaru STi, Throwing two codes that I cannot figure out!
P0171 - System Too Lean ( Extreme Fuel Trims )
P0457 - Evap System Leak Detected ( Fuel Cap Loose/Off )
I replaced fuel cap, didnít get rid of CEL or code.
The car doesnít seem to be running lean at all. Runs fine honestly. The code isnít always thrown and the CEL isnt always on. Iíll clear it and maybe a day or two later it will come back on. Clear it couple days no CEL and then it comes back on.
Also if I fill up with gas, then go to start my car, I have to crank it and push the pedal a little bit and hold it steady at like 1500 for 10-15 seconds or the car will die on me. After that the car is perfectly fine. Turns on and off and runs just as should. Only when I fill the car up with gas. I use 91, no bad gas or anything. Iím lost on where to go next. Any Subaru Gods out there to help guide me?
Thinking Gasket on fuel pump assembly maybe? Or a Clogged Evap Line?? Iím not sure.
Please and thanks for your time and response!!
Brandon07STi is offline   Reply With Quote
Old 04-18-2018, 01:31 AM   #2
MegaZac
Member#: 99455
2002 WRX Sedan
I'm looking for a solution to my P0457 situation as well. 2006 Saabaru Aero, and I keep getting this code. Car runs great and the cap is not loose (it's even been replaced).
The real annouance is that whenever the CEL comes on, I lose cruise control as well. Thd cruise flashes repeatedly until I clear the code.
Would love to hear if you solve this.
MegaZac is offline   Reply With Quote
Old 10-01-2019, 03:10 PM   #3
Shiloh51933
Member#: 498320
2005 Saab 9-2x
I was curious if you ever resolved the p0457 issue?
I have a 9-2x with same issues...I'm thinking it could possibly be the vent line in the filler neck or the purge valve. Any information would be great.
Shiloh51933 is offline   Reply With Quote
Old 10-07-2019, 09:53 PM   #4
KS07WRXTR
Member#: 506853
2007 WRX TR
37J
Check the plugs and the wires going to the evap solenoid by your gas tank often a source for the cel
KS07WRXTR is offline   Reply With Quote
