Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 10-07-2019, 10:07 AM   #1
pazzoduc
Member#: 493859
06 WRX TD Swapped
sorta black-ish
Default Autocross tires for Cold Temps?
Now that the weather is cooling off, curious what you guys run during the winter moths for Autocross.
In TX there are events pretty much all year (Except Dec) and temps can be in the 30's (F). Thinking mostly dry but cold conditions.
I'm due for a set of tires, wondering If I should grab a cheap set of all seasons?
pazzoduc is online now   Reply With Quote
Old 10-07-2019, 11:41 AM   #2
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
RE71R's are fine in colder temps with some tire blankets.
Old 10-07-2019, 11:27 PM   #3
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
RE71R is pretty much the best 200tw tire when not hot.
Though I will say that the Nitto NT01's i'm running right now are way better when cold then I was expecting.
Breezio is offline   Reply With Quote
Old 10-08-2019, 07:35 PM   #4
jesup16
Member#: 306393
2017 GTI DSG
'99 Corvette FRC
NT01's are not an autocross tire... they are a track tire. They will not do well in autocross compared to other tires.
As others have stated, RE71R's are a good choice. They'll do better in the cold than the BFG RivalS, which take longer to heat up and get to optimum operating temp's.
The new Yokohama A052 did really well at nationals this year. They are fast on run 1 and manage heat well. However, be warned they have even more aggressive wear characteristics than the RE71R or BFG. If you are running a car with limited camber, I'd would not recommend these as you will get 60 runs or less.
jesup16 is offline   Reply With Quote
Old 10-09-2019, 03:28 AM   #5
nemos_black_wrx
Member#: 372679
2012 impreza
DGM/plylon orange stains
you will be find with what you have or use your all season daily tires. wait off till events are all over then in winter get some re71's, bfg's, a052's, or 615k+ for next year events. which clubs are you running with scca, er, or Ntaxs.
nemos_black_wrx is online now   Reply With Quote
