Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 02-10-2017, 08:52 AM   #26
SubieGirl818
Member#: 461913
I would call the dealership to check whether they have a sort of warranty on body rust. I know that major carmakers have 5, 10 years... so why not check.
And yes, wish you luck in fixing this!
SubieGirl818 is offline   Reply With Quote
Old 02-10-2017, 10:16 AM   #27
landoficensnow
Member#: 332534
2013 WRX Hatch
To my earlier point, Subaru acknowledged the issue and agreed to fix it (however I have a call with them today to determine how it would be fixed). They probably did not want to go through the warranty (below) because they would be on the hook if they did a topical fix and did not either replace the door or do an invasive repair (pictured earlier in the thread).
Does anyone agree/disagree this would fall into rust perf. warranty below? My car is new enough that I'd be willing to take them to small claims court. It's ridiculous.
So the below is the Rust Perforation Limited Warranty:
RUST PERFORATION COVERAGE for all models is 5 years, regardless of mileage. Subject to the exclusions listed in this warranty, defective original body sheet metal panels that are rusted completely through from the inside out (perforated by corrosion) will be repaired or, at the option of SOA or your Authorized SUBARU Dealer, replaced without charge to you for labor and materials. The following items are not covered: (1) rusting of the outside of the underbody (floor pan) or any other part of the vehicle except body panels; (2) rust resulting from alteration of any body panels; (3) rust as a result of damage to paint caused by normal road hazards such as stones or other debris; (4) body panel rust caused by abuse, lack of maintenance, or damage to the vehicle; (5) rust caused by sand, mud, salt, submergence of a body panel in water, exposure to industrial fallout, chemical fallout, tree sap, hail, or other causes beyond the control of SOA; (6) replacement body sheet metal panels and (7) other items listed under "What is Not Covered" (later in this section).
Rust Perforation Coverage applies to perforation due to corrosion only. Perforation is a rust-through condition, such as an actual hole in a sheet metal panel. Cosmetic or surface corrosion, such as that caused by stone chips or scratches in the paint, is not covered under this warranty. In addition, SOA or your Authorized SUBARU Dealer reserves the right to decide whether painting the repaired or replaced panel to match the original finish is feasible. SOA will not, under any circumstances, pay for painting the entire vehicle solely to match paint color.
Since your vehicle was designed and built to resist corrosion, use of additional rust-inhibiting materials is not necessary and not a requirement for coverage under this warranty. Whether to obtain such additional protection is your decision.
landoficensnow is offline   Reply With Quote
Old 04-02-2017, 12:54 PM   #28
Harry
Member#: 23390
2010 WRX STI SE
Unhappy Same issue on my STI
Originally Posted by p0staldude View Post
There is a hole at the top of the window frame. It's used to attach the weatherstripping to the door with a plastic clip.
The problem is that there is no drain at the bottom of the window frame
Same issue on the driver's door of my 2010 STI. Now has one dime-sized rust bloom and 3 smaller ones moving up the pillar, so definitely rusting up from bottom.
Any thoughts on drilling a drain hole on the inside of the door, at the bottom where the inside and outside panels separate?
I think I'll try that and flood the cavity with rust stop, via the top hole that holds in the corner of the rubber door seal. Not ready to cut the rust out - looks beyond my bodyworking skills.
- Harry
Harry is offline   Reply With Quote
Old 04-02-2017, 01:37 PM   #29
p0staldude
Member#: 299478
2008 WRX
- Harry
That is exactly what I did after welding the patch. I left a small hole on the bottom where the panels separate and injected some rustproofing in the cavity
p0staldude is offline   Reply With Quote
Old 04-16-2017, 03:33 PM   #30
Harry
Member#: 23390
2010 WRX STI SE
I just injected two doses of 0.5 oz of rust stop into each front door, from the top corner hole. I'll see how much it slows down the rust.
Turns out, the door cavity does have a drain hole - the excess rust stop drained out the drain hole at the bottom of the rear edge of door.
- Harry
Old 05-05-2017, 02:00 PM   #31
Effers
Member#: 221803
2010 WRX Limited 5DR
World Rally Blue
Any updates from folks who have been pushing SOA/dealers? Seems like a fairly widespread issue.
Effers is offline   Reply With Quote
Old 05-06-2017, 12:16 PM   #32
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
This is definitely interesting. My '08 2.5i (that I bought in Nov '07) is showing zero signs of corrosion both inside and outside of the doors. Granted I didn't peel back the black tape. My car has been parked outside since day one but I also live in a dry climate.
subyski is online now   Reply With Quote
Old 05-07-2017, 07:49 PM   #33
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
So sad my '10 STi is doing the same thing on the passenger-side door, in that exact location.
Going to get some estimates soon.
Blackfin is offline   Reply With Quote
Old 06-15-2017, 03:00 PM   #34
pete_fxt
Member#: 231777
any success with this? I'm having the issue on both sides...
pete_fxt is offline   Reply With Quote
Old 06-16-2017, 04:09 PM   #35
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I would not be surprised if this rust(ing) is being caused and/or accelerated by deicing agents that are being used during the winter months on road surfaces in place of rock-salt, sand and/or equivalent.
Old 06-19-2017, 09:03 AM   #36
SnowSTI2011
Member#: 276186
2011 STI stage 2
2012 Odyssey
My 2011 STi is doing the same thing. Both front doors in exactly the same spot. Really irritating issue on a 6 year old car!
SnowSTI2011 is offline   Reply With Quote
Old 08-22-2017, 04:49 PM   #37
wrb2013
Member#: 344486
2013 WRX
WRB duh
My 2013 wax has rust bubble on both sides under the vinyl. 4 years old ;<
wrb2013 is offline   Reply With Quote
Old 01-28-2018, 02:09 PM   #38
Harry
Member#: 23390
2010 WRX STI SE
Default 2008+ Impreza/WRX/STI - B Pillar Rust
Just got mine fixed. IAG (local tuner shop in MD) body shop ground the rust out of driver’s side and covered with epoxy filler, primed and re-applied black vinyl.
Body shop manager thought the rust was happening because the internal channel gets too tight to let factory rust protection to get in there.
Repair looks good
I guess I'll just wait and see how it holds up.
Harry
Old 07-18-2018, 10:22 AM   #39
Effers
Member#: 221803
World Rally Blue
Repair looks good
Harry
Looks great. How is it holding up?
Mine is getting worse, thinking about getting it repaired.
Old 07-30-2018, 10:31 PM   #40
tvbuster
Member#: 393179
Same issue on my 2008
tvbuster is offline   Reply With Quote
Old 10-03-2018, 03:58 PM   #41
Artie56789
Member#: 325507
2010 Impreza 2.5 OBS
2 tone silver
Any updated on how everybody has been dealing with this issue? Anybody willing to share how much they paid to get this rust fixed?
Artie56789 is offline   Reply With Quote
Old 10-06-2019, 04:01 PM   #42
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
I am having the same issue. Doesn’t Subaru have a long rust warranty?
dexterous is offline   Reply With Quote
Old 10-06-2019, 04:17 PM   #43
JP Chestnut
Member#: 504432
“Long”? Not particularly.
JP Chestnut is online now   Reply With Quote
Old 10-09-2019, 04:21 PM   #44
Big-E
Member#: 123843
2016 STI LTD CWP
I still think that this can be attributed to winter deicers that are used.
None-the-less:
"Rust Perforation Limited Warranty
Since your vehicle was designed and built to resist corrosion, use of additional rust-inhibiting materials is not necessary and not a requirement for coverage under this warranty. Whether to obtain such additional protection is your decision."
