Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Mid Atlantic Impreza Club
Old 01-16-2015, 11:49 PM   #1
leakyoutback
Member#: 411093
Default Head Gasket Job
Hello forum
This may be in the wrong place,so, mods please move it if necessary. I have a gen2 outback that's in need of new head gaskets. I've called a few places near Annapolis and they all want north of $1400 for the job.
If someone here can recommend a place or someone that can do the job at a more reasonable cost please pm me.
leakyoutback is offline   Reply With Quote
Old 01-20-2015, 04:21 PM   #2
sabreofsd
Member#: 48943
2004 95%*STi Blu/Gld
www.dcawd.com
That sounds about right :/ http://www.exlineauto.com/ is who did mine and I was happy with them.
sabreofsd is offline   Reply With Quote
Old 01-20-2015, 04:38 PM   #3
ColdSoda
Member#: 200545
2008 SPEC B
Not sure where you are or how far you are willing to travel... Mach V motorsports is in VA, you could give them a call or perhaps email for a quote.
ColdSoda is offline   Reply With Quote
Old 01-20-2015, 10:37 PM   #4
leakyoutback
Member#: 411093
Thanks guys. I feel that it's not an overly complicated job once you pull the engine out.
Old 01-20-2015, 11:24 PM   #5
thefultonhow
Member#: 107064
17 RWD V8 Malibu
05LGT 07Spec.B 15WRX SOLD
Maybe you should do it, then?
Sorry, that was kind of a douchey thing to say, but really, the point is that it's a fairly involved job. First of all, you have to pull the engine, and then there's a bunch of stuff you have to take off the front, and then the heads need to be partially disassembled in order to remove them, and then you have to prep the surfaces, and then you have to put it all back together.
I know my way around Subarus (four engine pulls and one partial rebuild previously), and I'd say it was still a 10-15 hour job when I did headgaskets on my uncle's 99 Outback. That's in addition to $300-400 in parts (headgaskets, valvecover gaskets, main seals, cam seals, head bolts, probably some other stuff too).
What I'm saying is, when you factor in the labor costs and the parts cost, $1400 is not unreasonable. The only ways to not spend $1400ish are to DIY, or to sell the car to someone who can.
thefultonhow is offline   Reply With Quote
Old 01-20-2015, 11:39 PM   #6
leakyoutback
Member#: 411093
Meh. lol.
I'd diy it but I don't have a garage or the time. It's not a simple job but I'm not a mechanic either. I guess what I'm looking for is someone to keep the car for say 2-3 weeks and work on it when they have time. As for parts felpro (http://m.summitracing.com/parts/fel-...aQodf3IACg)has an MLS gasket kit for about $100. As for the heads Id just want them resurfaced.
Old 01-21-2015, 10:37 AM   #7
thefultonhow
Member#: 107064
17 RWD V8 Malibu
Keep in mind that there are other parts you will probably need besides the HGs. The head bolts are torque-to-yield and should not be re-used, and new ones aren't cheap. If you've got the engine out, it would be a mistake not to do the rear main seal. Valvecover gaskets are probably dead, unless you did them recently. And when's the last time you did a timing belt/waterpump job? You have to take the timing belt off to do this job anyway, so if that's coming up, now is the time.
If you can find someone who's willing to do the labor for next to nothing, more power to you. Personally, I would charge $40+ an hour, and there's no room in my garage or my project list anyway. And there is still the matter of parts. My guess is even if you shopped around for the best deals on parts and found someone cheap for the labor, you'd still be looking at $600+.
Old 01-21-2015, 11:35 AM   #8
KillerAngel
Member#: 352483
2013 WRX 5Dr
If you were able to pull the engine out yourself (cost of an engine hoist rental + beer for buddies), and reinstall after the work was done, you'd be able to save some cash.
No one will work for free, and I don't recall free mechanic labor being included in the state of the union address so don't get your hopes up...
KillerAngel is offline   Reply With Quote
Old 01-21-2015, 12:47 PM   #9
leakyoutback
Member#: 411093
$600 would be too good to be true. But
Bolts / head gasket kit $200
Resurface $60 (yes called a few places)
$labor $500
So $700ish hopefully?
Timing belt / water pump are done. So is the radiator and thermostat and hoses. My apologies for phone punctuation and grammar.
Old 01-21-2015, 12:49 PM   #10
leakyoutback
Member#: 411093
Lol. Ok.
Old 01-21-2015, 01:50 PM   #11
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
If you were in my area I could hook you up with a headgasket job that wouldn't take more than an afternoon. And wouldn't be very expensive (parts and labor). The headbolts are re-useable as well as the valve cover gaskets (provided they aren't leaking). A subaru engine can be removed easily in an hour.
Jake
KONKILR is offline   Reply With Quote
Old 01-21-2015, 02:14 PM   #12
Tut4u2
Member#: 40424
05 STi
It's not necessarily complex, but you're paying for time.
Tut4u2 is offline   Reply With Quote
Old 01-21-2015, 02:38 PM   #13
leakyoutback
Member#: 411093
Jake
What area are you in?
Old 01-22-2015, 11:28 AM   #14
thefultonhow
Member#: 107064
17 RWD V8 Malibu
Looks like the Cumberland area. Basically, western MD right where MD is at its narrowest North-South.
Old 01-23-2015, 12:22 AM   #15
leakyoutback
Member#: 411093
Does anyone have contact info for user rileyd?
Old 08-13-2018, 06:48 AM   #16
peterparker
Member#: 490060
Good posts
peterparker is offline   Reply With Quote
Old 10-08-2018, 04:49 PM   #17
Verity
Member#: 194228
2009 WRX Sedan
Does anyone have any experience with a cracked head gasket? I have an 09 Subaru I need to sell. Low mileage at about 85K but need to fix the head before I sell it.
7034014218 is my cell or if anyone has any good shop recommendations in Nova please let me know.
Verity is offline   Reply With Quote
