Welcome to the North American Subaru Impreza Owners Club Monday March 1, 2021
Old 09-24-2020, 11:28 AM   #5876
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
When chasing wide wheel widths, you have to put function over form. Find out what fits and only then choose a wheel mfr or model from among the choices that fit.
Start by searching for wheels that do not need any spacer to clear the Brembos. Usually the clearance issue is the back side of the spokes not clearing the faces of the calipers, though for some wheels there is taper in the barrel that fouls the outer "diameter" of the calipers. So that's two more things to check (in addition to strut and fender clearances).
Norm
Old 09-24-2020, 11:35 AM   #5877
Karlot
Member#: 339923
2006 Impreza WRX STi
grey
^ i get that. i'm looking more for who has and what can i do to modify front fenders and can i modify them to fit a 275/35 tire functionally. i have heard of people putting washers on the fenders so they are pushed out further. and of course rolling and pulling. am i missing something?, i just cant find anyone running that setup that has discussed what was done up front.
Karlot is offline   Reply With Quote
Old 09-24-2020, 05:46 PM   #5878
Karlot
Member#: 339923
grey
Originally Posted by RoyaL13 View Post
18x9.5 +22F +17R 275/35/18
This is near exactly what i am hoping to run, however i expect to not be as low with autocrossing. see how the front fenders poke out at the body line? this is what i'm wondering how to go about doing.
Old 09-27-2020, 02:51 PM   #5879
Zeonic
Member#: 490131
2005 Impreza WRX
Default Projected Completion setup
year: 2005
model: WRX
wheel model: Method Race Wheels MR502
wheel size/offset: 17x8 5x100 +38
tire brand/model: Michelin Pilot Sport 4S
tire size: 225/45ZR17
suspension: Tein Type HG Coilovers 1in lower than stock
alignment: stock
fender mods: S11 WRC fenders (+80mm per side)
spacers: None
Recommendations on this set up? still the daily driver right now, but want a configuration to do tarmac and rally. Basically run it and still be able to drive it home.
Zeonic is offline   Reply With Quote
Old 09-28-2020, 11:33 AM   #5880
Karlot
Member#: 339923
grey
Originally Posted by Zeonic View Post
year: 2005
model: WRX
alignment: stock
spacers: None
on the tarmac this will be similar to a stock setup for an sti, with a hair more aggressive offset. you shouldnt have any issues running this. with those fenders you can go signifigantly wider on both wheels and tires.
for rally people typically use suspension to lift the cars, and a narrower tire. i cant speak much to that.
Old 09-30-2020, 07:55 PM   #5881
dhjester
Member#: 142954
Will 18x9.5 +10 with 275/35 tires fit my 2015 wrx with stock suspension without rubbing?
dhjester is offline   Reply With Quote
Old 10-01-2020, 08:29 AM   #5882
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
I've got serious doubts . . . here's how what you're proposing compares to OE (well over 2" further out on the outside, with about 30 mm of unused space on the inboard side that could be used to cut the amount of poke down to something that might work).
Norm
Old 10-02-2020, 12:50 PM   #5883
Karlot
Member#: 339923
grey
i doubt so with that offset. that would poke quite a bit. i did have a friend who ran 18x9.5+35 with 275/35 tires on his 2016 sti. although he did have coils and i think he rolled his fenders too. i dont believe they were pulled but i'm not sure about that
Old 10-11-2020, 10:33 AM   #5884
Zeonic
Member#: 490131
2005 Impreza WRX
Originally Posted by Karlot View Post
on the tarmac this will be similar to a stock setup for an sti, with a hair more aggressive offset. you shouldnt have any issues running this. with those fenders you can go significantly wider on both wheels and tires.
Awesome, I appreciate the feedback. I'm already addressing arms and whatnot cause unsprung weight was my concern with also going out more on offset, but I'm unsure just how much I could actually go with fenders this wide.
Old 10-13-2020, 09:48 AM   #5885
Karlot
Member#: 339923
grey
with a wrc style widebody i believe you could fit an 18x10.5 and run like a 295 tire. but double check that and dont take my word on it. i'd have to double check myself to be sure.
Old 10-16-2020, 09:20 PM   #5886
Shiba
Member#: 258227
I have been searching around and hopefully someone can help out. I am looking at a set of 17 inch Enkei PF01's on a 2017 Base WRX. I want it to be a as close to the stock 17 inch wheel size so I can keep the stock tire size of 235/45r17. Would the 45 inset on an 8 inch wheel fit without rubbing? Thank you .
Shiba is offline   Reply With Quote
Old 10-23-2020, 10:56 AM   #5887
c1souk
Member#: 497907
2019 WRX STi
year: 2019
model: WRX STi
wheel model: Work Emotion CR Kiwami
wheel size/offset: 18x9.5 +38mm
tire brand/model: Michelin Pilot Sport AS4
tire size: 255/35/18
suspension: Tein Flex A with about 1.5 inch drop
camber: -1.7 front, -1.4 rear
fender mods: None
spacers: None
I thought it would be flush, but it looks like it pokes slightly in the rear.
Not rubbing yet, but kind of worried that it will.
c1souk is offline   Reply With Quote
Old 10-28-2020, 09:31 PM   #5888
fn5jason
Member#: 514502
Default Fifteen52 turbomac
Year: 2017
Model: WRX
Wheel Model: Fifteen52 Turbomac
Wheel size/offset: 18x8.5 +30
Tire size: Recommendations?
Suspension: Stock
Alignment: Stock
Fender Mods: Don't really want to do any
Thanks!
fn5jason is offline   Reply With Quote
Old 12-31-2020, 02:52 AM   #5889
UhFive
Member#: 326759
00 JDM Impreza WRX
WR Blue
Default 225/65R17 Winter set up on Bugeye?
Iím wondering if a 225/65R17 setup would work on a stock height bugeye.
I was about to install whiteline springs and KYB struts, but didnít know if it would fit under that too. So I can keep it stock height or if they will fit the lowered set up Iíd like to do that.
Can anyone confirm fitment?
UhFive is offline   Reply With Quote
Old 01-06-2021, 04:49 PM   #5890
Wfosti35
Member#: 411914
2004 Sti
Hoping someone can help!!! I have an 04 sti, Iím the original owner too. Itís been in storage for a few years and I think itís time to pull her out. Car is on tein mono coilovers with oem bbs powder coated cherry blossom ďpinkĒ Iím really wanting a set of volk te37 in bronze 17x8.5 5x100 +45 for tires Advan ao52 255/40r17. Will these wheels clear the bremboís? Will I have to roll the rear fender? I canít find a confirmation this combo works.
Wfosti35 is offline   Reply With Quote
Old 01-20-2021, 01:37 AM   #5891
adriang7
Member#: 517135
Originally Posted by fuelMuncher View Post
You might scrape tire in the rear on large fast bumps and what not. You could get some camber bolts and with the 15mm spacers and 225 tires make it work without too much work after that. Depending on the make of tire you could also probably run a 235, but then again, it will come down to the stiffness of the rear springs, ride height, and the speed you enter terrain fluctuations and corners that will determine if you rub or not, as far as I know, and with the information given about your setup idea.
I think rubbing at all creates such a poor driving experience that it's worth it to get the rears rolled if you're looking for a flush look. 18s on a GD will create more potential to rub than 17s overall, more so that on GR+ models, so putting GR wheels on a GD will create an incentive to roll, while although not necessarily making it a necessity.
But yeah, I ran 18x8.5s on my Bugeye wagon for about 8 months, and it was lame. Not that you're asking for my opinion on what wheels you should get at all, but 17s are easier to get to fit and are more fun to drive with. Anyhow, good luck!
What tire size? offset? fender mods? camber? asking cause i have 18x8.5 +45 for a 04 wrx wagon and i wanna know how much tire i can fit and what i have to do to minimize rubbing. thank you
adriang7 is offline   Reply With Quote
Old 01-26-2021, 03:43 PM   #5892
tbishop112
Member#: 521946
Default 2006 Legacy Wagon 2.5i
Hi Guys
Noob here... tried to search first! But didn't turn up a result.
2006 Legacy Wagon 2.5i, dead stock suspension/ride height. Have some very crappy 205/50/17's on it now, and they are terrible in even light snow.
Found a great deal on the more common size, Continental DWS which are 215/50/17. Will these fit on the stock 17" wheels, and suspension?
I've measured with my hand, and seems like lots of space in the rear - front I can easily get my hand in from the tire to strut, I can't see any issue with going 10mm wider, and concerns with the slight height difference? From what I can tell my existing tire diameter measure just a hare over 25" but the setup with the Conti's will be 25.5". This tire doesn't show up as an alternate size option (215/45/17 is) but I know that if anybody knows what fits its you guys.
Thanks!
tbishop112 is offline   Reply With Quote
Old 02-04-2021, 10:05 PM   #5893
dominicpadawan
Member#: 497749
Hi,
If you have a 2015-2019 WRX or STI, you can try this wheel calculator :
https://wheel-it-fit.com
Thank you
Dominic
dominicpadawan is offline   Reply With Quote
Old 02-05-2021, 08:30 AM   #5894
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
Originally Posted by dominicpadawan View Post
Hi,
Thank you
Dominic
Do you know if it adjusts tire section width as wheel width is varied?
Be nice if you could at least get a demo view . . .
Norm
Old 02-06-2021, 09:37 AM   #5895
sadairk2
Member#: 392890
2005 STI
I think last time I posted I was on Tein Basics. Now I'm on RCE T0. Wheels are Gram Lights 57DR 18x9.5 +38, 255 35 Firestone Firehawk. Other suspension mods: whiteline sways and lateral links.
sadairk2 is offline   Reply With Quote
Old 02-07-2021, 12:17 AM   #5896
dominicpadawan
Member#: 497749
Norm
Yes, it ajusts the section width because it is a percentage of the tire width. The calculator is very well made, but I could try to get a demo view.
Old 02-07-2021, 10:02 AM   #5897
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
First off, I have to appreciate the amount of work it must have taken to work up anything at all with clearances. Can't even imagine doing something like that at this stage (I'm retired).
Just to make sure we're talking about the same thing . . . does it include about a 40% of rim width change as rim width varies from "measuring width"? Both sidewall shape and clearances are affected.
I'm using curve fits for the upper and lower sidewalls.
Norm
Old 02-07-2021, 09:48 PM   #5898
dominicpadawan
Member#: 497749
Norm
Hi Norm,
I have put online a fully functional DEMO of the calculator, so you can try it ! Hope you like it
Dominic
Old 02-26-2021, 11:48 AM   #5899
lidrew
Member#: 142417
2011 STi
Dgm
Will my 18x9.5 +40 Gramlights 57 extreme clear 2020 STi Brembos?
lidrew is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 04:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 02:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 02:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 04:54 PM
