11-07-2000, 02:54 PM | #1 |
Member#: 2848
Vehicle:MY00 RS MY04 RX-8 BRP, and Ricy Yellow |
DIY: rear fold down seats.
if your like me and u snowboard/ski, you hate people that ruin the perfect looking Impreza with a ski rack. well the Impreza doesn't have a rear fold down seat until now. you can do it yourself just by removing some bolts. its very simple.
1. remove the bottom 2 bolts that hold the seat bottom to the car. 2. after u take the seat bottom out of the car, then u will see 3 more bolts. one on the far left, one in the middle, and one on the far right. remove them. 3. to remove the seat back, u must pull up on the top of the seat back because it is held on by 3 hooks. 4. after the seat back is removed out of the car u will see 2 layers. one is a rubber on one side, and a sort of insullation on the other. the other layer is a plastic backing. what i did is i used a spray adhesive to glue the 2 layers together, then glued the layers to the foam seat backing. it seamed to hold together nicely. 5. after i let the glue dry i then put the seat back, back into the car, but i did not put the 3 bottom bolts back in. i just used the 3 top hooks to hold it up. 6. finally put the bottom back in, and then put the 2 bolts back in. make sure u pull the seatbelts through. ITS DONE to fold the seat down all u have to do is lift the seat back off the 3 hooks and it comes down. all in all it took about an hour for this whole mod.(to let the glue dry and stuff) now u can fit your snowboard/skis inside the car without messin up the perfect exterior look with a ski rack. sorry to say i threw out the adhesive i used but im sure u can find some that would work. just want to say thanks to Ridin Low for the help!! [This message has been edited by Imprez Me (edited November 07, 2000).]
11-07-2000, 02:58 PM | #2 |
Member#: 329
Vehicle:1995 325i Arctic Gray |
I did the same thing except I tossed the insulation blanket & just ziptied the corrugated plastic to the back.
Edit: Oh yeah... you're welcome! [This message has been edited by RidinLow (edited November 07, 2000).] |
11-07-2000, 03:01 PM | #3 |
Member#: 2848
i wanted to keep the insullation because the trunk gets pretty cold and i didn't want it to come through in the winter.
oh yeah, i emailed you on how to remove the seat yesterday. thanks again. |
11-07-2000, 03:09 PM | #4 |
Member#: 251
Vehicle:1998 Impreza 2.5 RS Black |
I do like to ski and board, but I'm nothing like you...
-Chris |
11-07-2000, 05:52 PM | #5 |
Member#: 1594
Vehicle:1999 2.5 RS 2002 Legacy |
Anyone with this process documented with Pics, or do I have to do this and take pics??
Also does it rattle or slide around at all or alot?? Thanks - [email protected] |
11-07-2000, 07:06 PM | #6 |
Member#: 329
There's no real need for pics, it's all quite simple once you look at it.
Foam on metal doesn't rattle much. |
11-07-2000, 07:09 PM | #7 |
Member#: 745
Vehicle:2004 STi Java Black Pearl |
i just removed the whole darn thing and keep it in my dorm room. *shrug* At least peeps can't bum rides off of me anymore. hehe.
Don |
11-07-2000, 07:09 PM | #8 |
Member#: 745
Don |
11-10-2000, 05:37 PM | #9 |
Member#: 2263
Vehicle:2014 Sportwagen TDI |
so whats wrong with a Thule rack with a 6 pair ski holder, fork mount bike carrier, and a wind fairing!?!?
11-10-2000, 09:23 PM | #10 |
Member#: 1988
Nothing wrong, I have a Yakima rack and fairing and 2 bike carrier. I just can't fit everything on the roof. I also like the security of having my windsurfing gear inside.
JahWind |
11-11-2000, 10:38 PM | #11 |
Member#: 1469
We have to work with what we've got, and thats better than nothing!!
11-11-2000, 11:02 PM | #12 |
Member#: 1988
I finished my Rear Seat mod. Check it out.
<IMG SRC="http://albums.photopoint.com/j/View?u=1457078&a=12282449&p=44814991&Sequence=0&re s=high" border=0> <IMG SRC="http://albums.photopoint.com/j/View?u=1457078&a=12282449&p=44814992&Sequence=0&re s=high" border=0> <IMG SRC="http://albums.photopoint.com/j/View?u=1457078&a=12282449&p=44814996&Sequence=0&re s=high" border=0> <IMG SRC="http://albums.photopoint.com/j/View?u=1457078&a=12282449&p=44814998&Sequence=0&re s=high" border=0> <IMG SRC="http://albums.photopoint.com/j/View?u=1457078&a=12282449&p=44817383&Sequence=0&re s=high" border=0> The upper part of the back seat is out of the car. A 21"Wx40"Lx.25"H plywood sheet replaces the seat back. It is held in place by 3 hinges. The plywood is covered on both sides with grey carpet runner with rubber backing which matches the trunk carpet, and I then covered the seat back side with a black fabric to match the interior. I also covered exposed areas of the body pan with black fabric which adds to the appearance especially when the seat is down. I just cut notches where 3 hooks are that the seat back would hang on, and I wedge a large washer on the center hook to keep it in an upright position. It is not super comfortable but passengers could still use the back seats if necessary and the seatbelts are still functional. It would unbolt easily by removing 3 bolts. It basically rests on the bottom part of the seat when folded down which keeps it pretty much level with the trunk. JahWind [This message has been edited by JahWind (edited March 25, 2001).] |
04-02-2001, 07:11 PM | #13 |
Member#: 765
jahwind
how long did it take to make this... how much did it take.. thanks, space |
04-02-2001, 10:38 PM | #14 |
Member#: 1988
the spacecowboy,
It probably takes 2-3 hours maybe, if you have all the materials on hand. Plywood-$6.00 Hinges-$6.00 Black Fabric-$6.00 Carpet Runner-3.00 per 1'x3' Screws-$2.00 With a Jigsaw it would be nice and quick. JahWind |
04-03-2001, 08:11 AM | #15 |
Member#: 3608
Location: the T-dot - The green igloo billowing black smoke
Vehicle:2000 Impreza Tanned - BRP |
I would love to have rear fold down seats, but you have to remember that they did this for a reason. The seats in place give the car more rigidity and stability. Even the new WRX is the same. It has a fold down "arm rest" By taking them out, You are sacrifising the cars integrity/strength. You might not notice it but it will when you window seals don't line up.
Nick. |
04-03-2001, 08:32 AM | #16 | |
Member#: 415
SCIC
Vehicle:2018 WRX Ltd Dark Grey Metallic |
Take the time to pull out the four bolts, you'll realize that the "structure" of the seats is entirely molded foam. There's a thin metal "backstrap" to help with something to lean against, but its too flimsy to provide any added structural strength. The strength of the body shell comes from the "ring" formed by the lower floor pan, C-pillars, and cross-tube just under the rear window. |
04-03-2001, 08:35 AM | #17 |
Member#: 1575
South East
Vehicle:2011 WRX Premium Blackest Black |
nikkicalves-
Please don't say such stupid things until you have some experience with what you are talking about! The rear seat back adds absolutely NOTHING to lateral rigidity. If you have ever had it out you would know this it is a 4 pound piece of soft foam there is no earthly way this could add rigidity to anything!!! |
04-03-2001, 08:52 AM | #18 |
Member#: 3611
sweet I was just about to ask if there was a mod for this, cuz I've always wanted a folding rear seat so I can open up my trunk cuz of the subs....
04-04-2001, 12:14 AM | #19 |
Member#: 1988
If anyone is interested in buying my seat mod let me know (Just the 1 piece in photo's above). I now have a WRX so I don't need it anymore. I can find out how much shipping is. Approx. $20.00 plus shipping.
JahWind |
05-14-2001, 10:08 PM | #20 |
What?...
Do they speak English in What? Moderator Member#: 1459
Vehicle:2008 WRX 5door MT WR Blue |
still selling the seat back?
05-14-2001, 11:34 PM | #21 |
Member#: 6072
SCIC
Vehicle:01 Silver 2.5 RS 04 Silver WRX STi |
If the over-sea has the fold-down rear seats, is it possible to install them in the US model? Has anyone imported them?
05-17-2001, 03:46 PM | #22 |
Member#: 2436
Vehicle:2001 Impreza 2.5RS Aspen White |
Does removing that thin metal "backstrap"
in back of the seat safe? (look in jahwind's pics) if i took it out would the person sitting back there fall thru into the trunk ? =] thanks Rob |
05-17-2001, 06:31 PM | #23 |
Member#: 2436
Anyone??
bump rob |
05-17-2001, 06:33 PM | #24 |
Member#: 1170
BAIC
Vehicle:2005 STi White |
rob, im prettys ure that bar is so for when you slam on your brakes or get in an accident so that stuff in the back wont fly through and kill the passangers or whateveer. i could be wrong though.
05-17-2001, 07:33 PM | #25 |
Member#: 2436
anyone else? is it safe to remove it....
rob |
FS:NY Legacy Leather front and rear seats with rear fold down seats. | Oceanparkway | Interior/Dressup/Audio & Security | 1 | 05-17-2008 06:58 PM |
GD Rear Fold Down Seats Modification? | WeSTI | Interior & Exterior Modification | 5 | 08-30-2004 10:45 PM |
Almost did rear-fold down seat conversion... | blkwag | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 10-21-2002 07:12 AM |
('93-'01) rear fold down seat | gypsymoth | Impreza Forum | 5 | 05-14-2001 08:09 PM |
Rear fold down seats | Arnie | Interior & Exterior Modification | 14 | 11-07-2000 09:38 AM |
