Welcome to the North American Subaru Impreza Owners Club Thursday June 4, 2020
Go Back   NASIOC > NASIOC Technical > FA Series Normally Aspirated Powertrain
Old 11-15-2018, 11:53 AM   #1
parkitgary
Member#: 473958
Default Fa20dit what is this noise?
Take a close listen to this video. At about 30 seconds as I switch two lanes over you can hear a high pitched noise. I can reproduce the noise and usually happens at about 4-6k rpm under medium throttle. Is my engine knocking? What should I do?
https://youtu.be/VLT1Th5btXU
parkitgary is offline   Reply With Quote
Old 11-15-2018, 09:44 PM   #2
jcf_dori
Member#: 484219
i can't hear anything
jcf_dori is offline   Reply With Quote
Old 11-16-2018, 05:03 PM   #3
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Sounds like some kind of buzzing.
jasonwrx86 is offline   Reply With Quote
Old 11-17-2018, 04:38 AM   #4
parkitgary
Member#: 473958
Sounds like something is rattling. Itís high pitched and happens only in like 4-6k rpm. I reved my engine in neutral and still heard it. I hear it coming from my left air vent...
Old 11-17-2018, 12:38 PM   #5
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Could it be some kind of loose exhaust shield?
Old 12-04-2018, 01:35 PM   #6
killadawg
Member#: 424203
2016 WRX stg 4 Rally
STI Drivetrain GM
That sounds like knock ;-)... bad gas? also in higher gears at low rpm you put lots of stress on the engine.. downshift, don't go into Neutral (some countries even prohibit that is it is dangerous) my 2 cents.. Here is a great solution on the cheap that works as good or better than the highend versions.. http://tunernerd.com/
Is you car tuned? what mods? etc..
killadawg is offline   Reply With Quote
Old 12-07-2018, 12:40 PM   #7
Prodrive_sti
Member#: 357918
Check the exhaust manifold nuts , either loose or fallen off
Prodrive_sti is offline   Reply With Quote
Old 03-30-2020, 07:04 AM   #8
contaminatrix
Member#: 435611
2002 SG5-2.0-XT-JDM
45A, originally 18L
can't hear a thing save for the doop-doop-doop... is that it? i have earplugs on as well
contaminatrix is offline   Reply With Quote
Old 04-03-2020, 07:57 PM   #9
Definespeed
Member#: 512678
If the noise in question is the slight buzzing/ rattling then I would start with the shifter my car is actively making that exact noise and I isolated it to the shifter but I also have kartboy shifter bushings. I believe it to be something with the reverse lockout cable that goes inside the shifter and is held by a pin. Good luck
Definespeed is offline   Reply With Quote
Old 05-15-2020, 01:01 PM   #10
G.hoststi
Member#: 281959
Is it the loud whining noise? Have you done any tranny work recently?
G.hoststi is offline   Reply With Quote
