Welcome to the North American Subaru Impreza Owners Club Thursday June 4, 2020
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 04-09-2020, 01:12 AM   #1
JimmysRC
Member#: 501341
2019 WRX
Dark gray metallic
Default Check engine light
Tonight on my way home on the expressway my WRX threw a solid check engine light and a flashing cruise control light. I got home and used my access port to read the code; itís p0420 catalyst system efficiency below threshold. Yesterday I had a shop near me install a new J pipe. I donít think they went to the stage 2 tune, and I didnít think about it until now. Any ideas what may be causing the lights? Thanks.
JimmysRC is offline   Reply With Quote
Old 04-09-2020, 01:46 AM   #2
GlarryHoodDIT
Member#: 460907
2016 WRX
Well, if you put an aftermarket J pipe on the stock tune it can't be anymore simple then that. You replaced an OEM cat with a junk hi-flow one and your ecu can tell the difference.
GlarryHoodDIT is offline   Reply With Quote
Old 04-09-2020, 11:56 AM   #3
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Make sure you meet the requirements for a Stage 2 flash.
https://cobbtuning.atlassian.net/wik...n+and+ADM+Spec
Stage2
Intake Requirements: Stock airbox and stock air filter
Exhaust Requirements:
Upgraded J-pipe with high flow catalytic converter
Upgraded cat-back exhaust (stock exhaust acceptable)
Boost Control Requirements: Deleted 2nd restrictor pill (between the tee and wastegate actuator). SEE: VA WRX Wastegate Secondary Restrictor Pill Removal
Boost Targets:
91 Octane 95 RON Minimum: ~20.5psi peak boost pressure tapering down as you approach the 6900RPM redline, +/- 1.5psi.
93 Octane 98 RON Minimum: ~20.5psi peak boost pressure tapering down as you approach the 6900RPM redline, +/- 1.5psi.
gn4rwhals is offline   Reply With Quote
Old 04-11-2020, 12:37 AM   #4
JimmysRC
Member#: 501341
2019 WRX
Dark gray metallic
Stage2
Boost Targets:
Thanks for the info. I got the stage 2 tune on the car now and the CEL is gone. I ended up calling Cobb to make sure itís all done right.
