Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2020
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 10-25-2013, 09:40 AM   #1
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Default More Oil Pressure Adapters!
To compliment out 1/2NPT to 1/8PT, 1/2NPT to 1/8NPT and M20 to 1/8PT we finally have added 1/8NPT to 1/8PT and 1/8PT to 1/8NPT adapters to the mix. We use them mostly for oil pressure adapters, but they can be used in many other applications.
  • Made from solid SS304
  • 14mm Hex
  • Thread Sealant Applied on Male Threads
  • Made in the USA
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
KillerBMotorsport is offline   Reply With Quote
Old 11-11-2013, 09:37 AM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Officially added to the website...
LINK HERE
__________________
vs.
Old 12-02-2013, 09:30 AM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
So here are the combinations we now stock...
- OEM M20 to 1/8PT
- 1/2NPT to 1/8PT
- 1/2NPT to 1/8NPT
- 1/8NPT to 1/8PT
- 1/8PT to 1/8NPT
__________________
vs.
Old 12-02-2013, 11:02 AM   #4
CanadianSTi
Member#: 296464
I was thinking about running an oil temp sensor out of my drain plug. I have a prosport gauge, and the sensor has 1/8" npt.
The only drain plug I've been able to find with a threaded hole is one with 1/8" pt
Do you guys make a drain plug with a 1/8" npt hole for a sensor? If not, Can you?
I saw your adapters, and thought about using one with a 1/8" pt drain plug.
I'm not sure, but I was thinking the sensor might read a little cooler if I used an adapter. Because the sensor would be a little further away from the oil, and would have air flow around the adapter to possibly keep it cool.
Any thoughts on if this would effect oil temps from a drain plug if an adapter is used?
CanadianSTi is offline   Reply With Quote
Old 12-03-2013, 09:44 AM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We do not make an OEM to 1/8NPT adapter. You shouldn't have any problems using the PT to NPT adapter. Even though it would put the sensor out 1" from where it would normally be the temp isn't read through the body of the sensor, it's read through the sensor face that is still exposed to the oil. This is my theory, we've not tested it.
__________________
vs.
Old 12-09-2013, 09:21 AM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
For your viewing pleasure...
__________________
vs.
Old 12-26-2013, 08:30 AM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
More coming
__________________
vs.
Old 02-24-2014, 07:35 AM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Will be adding OEM M20 x 1/8NPT for oil pan temp sensors and OEM M18 x 1/8NPT for front or rear oil gallery pressure senders.
Also now carry OEM M18 x 1/8PT for top oil gallery senders.
If you have an NPT or PT oil sensor / sender we have an adapter for it!
__________________
vs.
Old 02-28-2014, 09:34 AM   #9
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Mmmm billet stainless goodness.
M18 x 1/8NPT for top gallery mounting of oil temps or pressure senders.
__________________
vs.
Old 11-18-2019, 10:24 AM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Some other adapters we have and have added to our line of expanding adapters...
__________________
vs.
Old 02-07-2020, 02:19 PM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
For the FA guys we now have M16 to 1/8NPT and 1/8PT Adapters...
__________________
vs.
Old 03-31-2020, 07:08 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Dual Thread EGT Weld Bungs available now too...
__________________
vs.
