Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2020
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 04-03-2017, 01:36 PM   #1
GTWORX.com
Vendor Sales Rating: (10)
Member#: 97303
2015 WRX
Default GTWORX Bilstein Cup Sport Struts and Bilstein B6 comparison
We wanted to shed some light on something that people have asking about a lot lately, as well as address some misleading forum posts and social media activity. In this post, I’ll go through some of the details between our GTWORX Bilstein Cup Sport kit and the standard Bilstein B6 kit. This includes differences in the actual strut and shock bodies as well as technical differences in the actual valving of each damper.
First, we think it’s great that Bilstein USA is releasing their own B6 strut and shock for 2015+ WRX and STI! It shows how far the Subaru suspension market has come in the last couple years. When we first came to Bilstein years ago to propose our first GTWORX dampers for the previous generation Impreza, they weren’t exactly sure if this was a viable market. We were big Bilstein fans, having used them on the old GC platform, other vehicles, and some interesting JDM parts. Our goal was to convince Bilstein USA to bring that kind of shock technology to what was then the latest Impreza chassis and the result was our GTWORX Bilstein kit. We were pretty excited to be a part of making Bilsteins fixed perch dampers easily available to the USDM market…and of course we were excited to run them on our own personal cars because they are an awesome kit.
Now with Bilstein making their regular B6 kit available on the new 2015+ chassis, we are happy to offer both our own GTWORX Bilstein Cup Sport kit and the standard Bilstein B6 kit. We think both are excellent options that serve different needs, but there are significant differences.
The valving differences are particularly important, as Bilstein’s description of their B6 kits say "Bilstein B6 Performance dampers are a performance upgrade to OE dampers designed to be paired with the OE factory spring."
1. ABS bracket
a. Our GTWORX Bilstein kit uses OE ABS sensor brackets for easy installation.
b. The standard Bilstein B6 kit requires the use of zipties to secure the ABS bracket to the front strut.
Bilstein B6
2. Rear height adjustment
a. The GTWORX Bilstein kit includes an adjustable rear spring perch, allowing adjustment of rear ride height in 5mm increments. From the standard perch location, a user can bring the car up or down a total of 15mm. This is useful for getting a little more damper travel, evening out height differences when using camber plates in the front, or just getting the look and rake you really want.
b. The standard Bilstein B6 kit has a conventional non-adjustable rear spring perch.
GTWORX Adjustable rear cir-clip
Bilstein B6
3. Valving
Here’s the big one. Obviously, the actual shock valving is the most important part of equation. Bilstein’s description of their B6 kits say “"Bilstein B6 Performance dampers are a performance upgrade to OE dampers designed to be paired with the OE factory spring." Our GTWORX kit was designed primarily around our RCE Yellow and Black lowering springs. Both can work safely with OE springs or a variety of aftermarket lowering springs, but the different design goals are important.
Front:
Note that the Bilstein B6 dyno curve does not have as many data points…this dyno came directly from Bilstein and that unfortunately is how they do things most of the time. However, we can still see what we need to see. Also, gas force has been removed for all 4 dampers. Compression is on top, rebound on bottom.
All 4 curves have a similar compression values during shock piston velocities around 50 mm/sec (which is about 2 inches/sec). This is in the low speed range, which can be considered body roll and handling. Sharp and aggressive transitions may be a little higher.
A lot of low speed force can give a feeling of “platform” and responsiveness, but too much can low and mid speed damping can make the car feel very jiggly over even smooth pavement. Even the “soft” 2016 WRX inverted front dampers are overdamped in rebound, which is about 125% critically damped with RCE Yellows at 2 inches/sec. Damping ratios are often used as a measure of how underdamped or overdamped a shock is when used with a specific spring. Roughly 60-70% critically damped in the low speed range is often cited as a good target for rebound for a sporty car that still needs to soak up bumps. A damping ratio of 125% is excessive for a street car and some track cars. The STI takes that even farther which is why many complain about ride quality on that car. They are extremely firm. Too much rebound up front can also increase understeer and in the case of OE STI shocks, this is indeed too much. The WRX does digress nicely after that so it’s not as bad, but there is lots of room for improvement. On the compression side, the OE shocks build force quickly which is nice, but may have slightly too much at 1 inches/sec for optimal ride comfort. They do flatten out/digress decently in the high speed range to help soak up big bumps.
Our GTWORX Bilstein B6 kit uses the Bilstein COB digressive piston. You can see the smooth ramp up in both compression and rebound forces before digressing in the high speed range. At 2 inches/sec with our RCE Yellow springs, we’re at about 60% critically damped in rebound. We do need enough rebound in the high speed range to keep the car from bouncing excessively after big bumps when using firm springs, so we continue to build force before leveling off a little. For compression, we wanted to keep up some force in the mid-speed range and then flatten out in the high speed because we don’t want too much force to upset the car when we hit sharp impacts or mid-corner bumps.
The Bilstein B6 front struts are almost (but not quite) linear to 250 mm/sec. So for compression, there’s roughly the same amount of low speed damping compared to the other shocks, but a decent amount more in the high speed range when you hit bigger bumps. It’s not excessive and it begins to flatten out a little more after that, but I’m not sure many would want more high speed compression on their daily driver (in some specific cases you actually would, but for the most part it’s not ideal). The Bilstein B6 fronts are at about 90% critically damped at 50 mm/sec for rebound and 80% in the high range at 250 mm/sec. That’s a bit firmer than the often recommended 60-70% but this means they will not have any trouble controlling firmer springs, at least up front.
Rear:
We see bigger differences when we look at the valving of the rear shocks.
The OE 16 WRX rear shocks from the inverted suspension are very soft on rebound. Running firmer springs on these shocks is very much a compromise, and you could expect a bouncy rear end due to the lack of rebound. The OE STI rear shocks (which are the same as 2015 WRX rear and 2016+ base WRX rear) do a little bit better but are still slightly underdamped in the rear in rebound. They’re fine with aftermarket springs, but really right on the edge which is why you will occasionally hear about a little bounciness from the rear. The OE STI rear shocks are at about 30% critically damped in rebound with RCE Yellow springs in the high speed range. That’s okay, but that means you get a few extra oscillations after bumps. On the compression side, they’re pretty good and IMO that’s part of what makes the car fun to drive.
Our GTWORX Bilsteins use a similar valving curve for compression compared to the STI but are a little bit more digressive. Having a good amount of low speed compression damping in the rear helps reduce understeer when powering out of corners and helps the car rotate. More rebound in the rear also helps the car turn in as well as solve the problem of the bouncy rear end. We are at about 60% critically damped in rebound in the high speed range with RCE Yellow springs, so the rear end will settle quickly after hitting bumps.
The Bilstein B6 kit has a compression curve that is very similar to OE 16 WRX. Basically the same fairly soft curve. Which is fine, but remember that the front Bilsteins are a little firmer than we want in rebound. Firm rebound in front and soft compression in the rear is generally a recipe for understeer when powering out of a corner as the front wheels want to pick up and the rear compresses more easily. On the rebound side, the curve is closer to OE STI with a tiny bit more low speed and a tiny bit less high speed. So with RCE Yellows and most aftermarket springs, we’re not making a big improvement over OE STI and we’re again right at the edge of what feels good in the high speed rebound range.
Overall valving differences
It’s important to remember that the design goal for standard Bilstein B6 is to work well with OE springs. I think they do succeed with that, and they will still work relatively well with most lowering springs including our RCE Yellows. I would expect a good overall ride and good handling.
A big focus for our GTWORX Bilstein Cup Sport kit was balance. We knew that the OE rear shocks were right on the edge of what was acceptable for rebound when used with an aftermarket spring, and we knew that the OE fronts have excessive rebound. It’s one of the best OE suspensions ever from Subaru, but it still understeers and can be pretty harsh in the front and bouncy in the rear. Addressing both of those issues not only improves ride quality, but makes the car a lot more balanced on corner entry and exit. Which means it’s a lot more fun.
4. Price
Here’s another big one. Yes, our GTWORX Bilstein kit is roughly 450 bucks more expensive than the going price on the standard Bilstein kit. Why? Well part of that is the difference in the damper bodies (OE ABS bracket, rear ride height adjustment, that sweet stealth black paint) and the other part is that our GTWORX Bilstein Cup Sport kits are low production run custom builds. There’s all our test days at the track, the autocrosses, the tens of thousands of daily driven miles and road trips we’ve put on our prototypes….but when it comes down to it, our pricing is the result of a different pricing structure based on building very small amounts of these in comparison to what Bilstein does with their B6 kit. We wish we could build thousands of these and bring the cost down, but we’re a small company serving a niche market of enthusiasts within a niche market of Subaru fans. Although the street price of the Bilstein B6 kit is around $750, the actual MSRP is $1148. We unfortunately don’t have the luxury of playing with the price quite that much.
Also, it’s important to note that a custom revalve from Bilstein is $575 for the set + shipping, + $55 an hour of tuning time.
We believe that our GTWORX Bilstein suspension is an awesome kit and we’re proud to be able to offer it to everybody. The easy installation, the durability, the ride height adjustment, the advanced digressive valving, the balanced handling, and the improved ride….we believe these are one of the best all-around suspension kits available for a fun daily driver and mild track day and autocross car at any price.
The standard Bilstein B6 kit is a good kit at a very good price, and that’s why we will offer it to our customers too. It is, however, very different from our GTWORX Bilstein kit, and anyone implying that they are the same shocks is simply being dishonest with you.
Thanks for reading and I’d be glad to answer any questions.
- Andrew
__________________
GTWORX.com is offline   Reply With Quote
Old 04-03-2017, 02:11 PM   #2
GTWORX.com
Member#: 97303
2015 WRX
Here are a few pics of the standard Bilstein B6 kit, showing the non-height adjustable rear and the non-OEM ABS bracket fitment on the front struts:
__________________
Old 04-03-2017, 04:14 PM   #3
GTWORX.com
Member#: 97303
2015 WRX
oops. blank.
__________________
Old 04-03-2017, 08:57 PM   #4
Opie
Floresbian
Member Sales Rating: (13)
Member#: 470
2020 Canyon Denali
'18 FXT, '16 XV, '13 BRZ
Any chance of GTWORX Bilstein Cup Sports for the 2015+ Legacy?
Opie is online now   Reply With Quote
Old 04-04-2017, 08:26 AM   #5
GTWORX.com
Member#: 97303
2015 WRX
Man I would love that....I really like the new Legacy and want to build a proper sports sedan with custom Bilsteins. I'm not sure it's in the cards unfortunately but I'll run it by the guys here.
- Andrew
__________________
Old 04-05-2017, 08:52 PM   #6
Opie
Floresbian
Member#: 470
2020 Canyon Denali
- Andrew
I'd order the STI set today & put them on my Legacy if I could, but the front sway bay end link bolts to the strut body on the newer Legacy's...like the BRZ and 2018 Impreza's....so they won't bolt up
Old 04-06-2017, 10:02 AM   #7
kenliu84
Member Sales Rating: (55)
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
very nice, thanks
kenliu84 is online now   Reply With Quote
Old 04-13-2017, 01:01 PM   #8
SuperBrute
Member#: 264439
2017 WRX
Dark Grey Metallic
wow, great read. Really makes me want your kit even more!
SuperBrute is offline   Reply With Quote
Old 04-27-2017, 02:55 PM   #9
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Also a note: Bilstein B6 (HD) and Bilstein B8 (Sport) have identical valving. The B8 has a shorter stroke than OEM. Our GTWORX kit has identical stroke to OEM.
- Andrew
__________________
Racecomp Engineering
512 Shaw Ct, Suite 104
Severn, Maryland 21144
410-846-5407
RaceComp Engineering is offline   Reply With Quote
Old 05-29-2017, 11:29 AM   #10
EightTenths
Member#: 468430
Last week I had a set of RCE Blacks installed with OEM dampers on my 2017 STI picked up in April. While understeer and turn-in improved on smooth corners the moment undulations and ruts appeared the overall grip and balance of the STI fell behind OEM setup. Also the extra bounce on the highway over a big bump made it clear that I either had to remove these springs or find better dampers. Seeing your charts and explanation above summed everything up so thank you. Looking forward to getting these custom Bilsteins installed this week. I'm hoping this will get the state of my STI to "more is more fun" instead of "pros and cons" and make excuses.
Lastly I think it would helpful to post your explanation and charts on your website and all the vendor websites?
EightTenths is offline   Reply With Quote
Old 06-14-2017, 10:48 PM   #11
InTheWerks
Member#: 447206
2016 WRX(Base)
Thanks for the info, was almost on the verge of getting the regular bilsteins. Keep it up! Look forward to getting a set when the funds present themselves.
InTheWerks is offline   Reply With Quote
Old 08-12-2019, 04:15 AM   #12
EPTSubbie
Member Sales Rating: (1)
Member#: 367996
2019 STI
CWP
Sorry to revive an old thread.
Did GTWorx stop making the Bilstein Kit all together at this point? Looking for an upgraded shock to go with my Yellows.
EPTSubbie is offline   Reply With Quote
Old 08-12-2019, 05:38 PM   #13
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
No not at all. Just waiting for the next batch in the autumn months.
RCE
__________________
410-846-5407
Old 04-03-2020, 10:40 AM   #14
nycmalu
Member#: 377842
2018 Impreza WRX
Dark Grey Metallic
I am seeing, on various sites, that this product has been discontinued. I am in the market for new struts, and was pretty much set on these after doing some research. Come back to it a month later, and find that I can't purchase it on most sites. Some companies still have them listed, but now I'm hesitant, wondering if there's something bigger and better on the horizon.
nycmalu is offline   Reply With Quote
Old 04-03-2020, 11:18 AM   #15
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
We have these in stock. We have had these in stock for the last month and these are selling again. We are selling these directly to the customer instead of thru a wide dealer network.
Let us know if you have any questions.
410 846 5407
[email protected]
Myles
__________________
410-846-5407
