Welcome to the North American Subaru Impreza Owners Club Thursday June 4, 2020
Old 03-12-2020, 02:49 PM   #1
NemeGuero
Member#: 339764
Default ej20g knock/misfire robtune warning light at idle
EJ20G with robtune 440.
Things I have done to investigate:
OHM'd the knock sensor.. 500K Ohms
Checked compression - 150 almost dead on on all cylinders
Leakdown - less than 5% on all cylinders
spark check - tested all coils on all cylinders and got a healthy spark
12V measured at each plug with key in on position
measured primary coil resistance.. 1.1 vs spec of .7 but all 4 are consistent
could not get a secondary coil resistance due to poor contact on the spark contact I'm guessing.
Here is video of misfire light: *Click*
Only ECU code was Idle valve - 24.
Have not done coilpack conversion but they're new coils, new plugs, freshly cleaned and flowed injectors.
Any help is greatly appreciated.
thanks.
NemeGuero is offline   Reply With Quote
