Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2025
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 08-19-2021, 10:56 PM   #26
murrdogg24
Member Sales Rating: (49)
Member#: 50586
64 Impala
I have no idea if it's cracked or not because its on the car. I guess I can use a borescope when I change the oil next time.
Originally Posted by KillerBMotorsport View Post
The Smedia pan was installed December 2020. The other recent one is a few months old, and that was an obvious error on our part (setup baffle was used). We've sold +1,500 pans since Dec 2020. Not many failures
Do you have a cracked baffle? If so, reach out to us.
murrdogg24 is offline   Reply With Quote
Old 08-20-2021, 07:21 PM   #27
SwollRX
Member#: 382191
2006 WRX
I haven't seen it yet (or I keep missing it); What is the height difference between this and the OEM EJ Pans? Does it hang below any of the bottom bits when installed (in my case, an 06)?
SwollRX is offline   Reply With Quote
Old 08-24-2021, 11:25 AM   #28
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Our performance pan is ~7/16" taller. I say about, because the depth tolerance on Subaru pans is generally +/-.125, plus the GD and RV/VA pans are slightly different.
For your GD (and I'm relying on my not so great memory) I believe one of the OEM belly pan reinforcement ribs needs to be trimmed. It's a quick cut with a utility knife. I have seen some run without doing this, it will rub under some conditions, but I've never seen it cause any damage. I recommend trimming to provide 1/4-1/2" of clearance.
__________________
vs.
Old 08-24-2021, 06:00 PM   #29
SwollRX
Member#: 382191
2006 WRX
Thank you, so I can still utilize my plastic undertray/ belly pan then. That is good to know. I was initially concerned it may be hanging too low and potentially scrape; Im lowered by around 0.5"-1.0", if that much.
Old 09-24-2021, 07:39 AM   #30
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Correct!
Also, to give you some additional feels, our pan is extremely tough. It's put through two heat treat processes, and dare I say it's the strongest pan out there. In fact, it's VERY popular in off-road rally because of this. One car (El Diablo Rally Team; check them out on FB for the post) had an off into a boulder field a couple years ago, and the skid plat hit so hard it tore the engine from the motor mounts. It left a terrific imprint. They still use that pan today
__________________
vs.
Old 11-27-2021, 03:36 PM   #31
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
__________________
vs.
Old 01-18-2022, 09:12 AM   #32
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Caught up from the holidays we have our Traditional Performance and Super-G Oil Pans back in stock, ready for the spring rush!
__________________
vs.
Old 03-27-2022, 10:56 AM   #33
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
As the race season is upon us, does anyone have oiling questions? Or on our new Super-G Extreme Competition pan?
Oil Control Valve? Track PCV management? Oil pump sizes? Pickups, baffles, oil level, etc...
We're here for any and all questions you may have
__________________
vs.
Old 04-25-2022, 09:10 AM   #34
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Fun vid of the Super-G showing its sealed center baffle with one-way valves...
__________________
vs.
Old 11-25-2022, 12:19 PM   #35
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
PSA for those not on our mailer. We're having a 20% off Black Friday sale on all oiling products.
__________________
vs.
Old 10-11-2024, 02:16 PM   #36
legacybt
Member Sales Rating: (5)
Member#: 357081
I just checked it out and responded. That looks normal for JDM TS contact points. Trimming the heat shield should do the trick. Although, I'd like to see how far off the gaskets the flanges are. Feel free to PM me pics.
Chiming in for anyone using this thread for future reference. I have OEM Spec C twin scroll headers and have trimmed, flattened, welded and filed the heat shielding in an attempt to get it to fit with the pan but there's still contact. The heat shield is pretty much flush with the exhaust underneath.
Even after that work, the headers have to be spaced about 1/4" off the block before there's any gap between the pan and the headers. To get them to clear I'd have to remove the heat shielding completely, hammer in one runner or modify the pan.
I really appreciate the design dialogue and well-thought out answers in this thread! I'm leaning towards cutting and welding an indent to clear the exhaust - any strong recommendations for or against doing so?
legacybt is offline   Reply With Quote
