#26 |
Member#: 59182
Vehicle:2002 WRX GG>> 2016 Focus RS |
![]() Edit: I'm confused about the 'handshake' procedure for the Phase 1 4EAT, 1995-1998 (no 'manual' button). Having trouble finding the 'original' version I've used in the past. The USMB site's search function is not very useful, and i'd guess that's where I last used it. My current Subie has a manual.
No...I don't think it means 'fully off', just key to 'off' has far as it'll go. BUT - I think that is the Phase 2 / II; not Phase 1 / I. If you're referencing this post, per the title is for late '90s-2004: https://www.subaruoutback.org/thread...es-dtcs.44383/ Another TCU Code link: https://www.ultimatesubaru.org/forum...mission-codes/ See this and scroll down to the attachments. Under 'Readcodes' it has the FSM/factory service manual's version of the 'handshake': https://www.ultimatesubaru.org/forum...egacy-outback/ Phase 1 is '90-'98; Phase 2 is '99+ (not sure when/if Subaru stopped using the 'phase' designations)
#27 |
Member#: 241731
Vehicle:1995 Impreza LX Wago Black |
![]() The below step is for the handshake method for a 96 legacy OB on the USMB forum. The guy couldn't pull any codes until he did the step. I wonder if you or someone can confirm if it applies to my 95.
"Move the shifter to D with the key off. Connect the diagnostic terminal pin 5 to ground using the ground pins in the harness." |
#28 | |
Member#: 59182
![]() Quote:
Your '95 doesn't have the Manual button on the AT gear shift, correct? I'd guess it's the same as the '96-'98 procedure. |
#29 |
Member#: 241731
![]() Ok, I'll try to get a hold of the FSM. And correct, mine does not have the manual button on the shifter.
#30 |
Member#: 59182
#31 |
Member#: 241731
![]() You're too kind :-)
Question for you: When it says to ground pin #5, I'm assuming they're talking about position 5 on the OBD2 port, correct? But what does it mean when it says to ground it using the ground pins in the harness? Confused. |
#32 | |
Member#: 59182
![]() Quote:
Looks like it may be taped up to another harness - maybe near the green connectors used for 'active' diagnostics. In all my years playing with (Hah!) Subarus I've yet to see anyone tap into the the OBD2 port for anything - other tha to connect a code scanner, Tactrix cable (to tune certain models' ECUs) or the like. Last edited by wtdash; 10-30-2024 at 04:49 PM. |
#33 |
Member#: 241731
![]() Ok thanks. So once I find the connector (B82) I put a wire in position 5 and take it to a ground? Sorry for the ignorance here.
#34 |
Member#: 59182
![]() No worries. - yes, that's what I believe you'd do.
