Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2025
Old 10-31-2024, 02:08 AM   #1
hedron
Member#: 535911
2011 Impreza 2.5l Pr
Default rattling noises and possible a/c compressor locking up
https://files.catbox.moe/1uj0ib.mp4
The above video, I believe, shows my a/c compressor locking up. Or is that just normal behavior? Because it looks like the belt is moving, but the compressor is not.
I think simply taking a knife and cutting the belt would be sufficient to solving the problem, for now. Cold weather has finally arrived (I nearly froze to death the other day on a hike not prepared for a temp drop from 55f to 20f) and I have no need for A/C until the spring. But maybe I'm wrong on the internals of the EJ25 engine, and something else needs to be done?
Also, at 0:22 there is a quite disturbing rattling sound that is eerily similar to a water pump bearing gone bad. I'm just asking because maybe someone knows it's just a normal sound and I should just not worry about it.
hedron is offline   Reply With Quote
Old 11-01-2024, 10:13 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Engine running, the outer ring of the AC pulley spins. Turn on AC or defrost, the center part of the AC pulley locks to outer part and runs the compressor.
Noise.......I don't have a good sound to tell.
Old 11-01-2024, 01:35 PM   #3
hedron
Member#: 535911
A rattling noise clearly begins at :22 seconds of the video. I've been looking at "bad water pump" videos on youtube, and it sounds exactly like that. I had a previous car with a bad water pump and it sounded exactly like that. It could be one of the other bearings as well, since I don't have a stethoscope.
But you're saying the stop/go behavior of the compressor is normal? (for an ac and defroster that is set to 'off' position)
Old 11-01-2024, 11:45 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
What I posted on AC is correct, all(?) automotive AC compressors work the same way. It's an electromagnetic clutch. That's why there is a wire going along the compressor to the middle part of the pulley to power the magnet.
Defrost uses the AC to dry the air blowing onto the windshield.
My available sound sucks to hear your sound clip.
Old 11-02-2024, 12:29 AM   #5
hedron
Member#: 535911
My last car, Toyota Camry, the A/C compressor locked up and snapped the serpentine belt. But with that vehicle, it constantly spins. The clutch is internal, and operates when activated, but the 'wheel' spins continously. When it locked up it wouldn't spin. I just assumed all compressor worked that way. I guess I'll check under the shroud tomorrow.
Old 11-02-2024, 01:24 AM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
If the internals of a compressor locks up for whatever reason, then yes, engaging the clutch with engine running will shock load the belt, likely breaking it.
Old 11-05-2024, 10:06 PM   #7
hedron
Member#: 535911
Ok, upon further inspection, it seems the a/c compressor isn't locking up. It just operated differently than I expected.
But I'm not convinced that rattling is normal.
