09-30-2004, 02:33 AM | #26 |
Member#: 55867
Vehicle:2005 Saabaru AS |
So I'm probably going to get a myriad of crap for suggesting this.. I was considering, if I can't get my hands on an ej25, taking the heads off of the ej18 i have in my garage, giving them a good PnP (yay Dremel!!), and putting them on the ej22 block I currently have in my car. Other than the added flow of the PnP, would I see any gains from the (I'm assuming) higher compression? Also, is there a post anywhere about lift and duration of all stock EJ Subaru cams? Interchangeability as well?
09-30-2004, 02:41 AM | #27 |
Member#: 53595
NWIC
Vehicle:1987 GL Hatch EA81 1.6L + Weber |
Here's ALL I KNOW:
1. I've seen comparisons of the EJ18 n/a to EJ20 turbo heads. Bigger intake ports, bigger exhaust ports. Bigger valves. MADE for flow. 2. I've read that in shops they often MARK and keep the EJ18s in seperate areas from EJ22s (heads) because they look exactly the same to the eye. 3. calculations suggest that the EJ18 headswap onto a 2.2 block means 11.5:1. so... theoretically... if the only thing changing between the 2.2 and 1.8 heads is the dish volume (changing combustion ratio) then porting and polishing some 1.8 heads, some valve job stuff, better valves, and basically getting better flow, would increase power (of course) on the 1.8L. But so much more on the 2.2 because you're also getting better flow than the 2.2 heads (if #2 is actually 100% true... both head sets would flow the same right?) and then also increasing combustion ratio. I say go for it... I want to try this combo, but I think I'm the only one. either that or the 10.5:1, Ej22 -> 2359ccL stroker. |
09-30-2004, 10:35 AM | #28 |
Member#: 55867
BTW, when I tried to take the heads off of my ej22 last time I had it out, it wasn't having any of it. The bolts were really in there. Is there a way to get them out without snapping them? Or, should I just keep turning them b/c they probably won't break?
Could you not also do the stroker setup with ej18/ej22 head and block? Also, how do you figure out compression increase yields when doing stuff like this. I don't want to do something retarded and get knock out the yin yang. |
09-30-2004, 04:22 PM | #29 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
I would like to see more info to back up the EJ22 vs EJ18 head flow claims. I had been led to beleive that the heads were identical and that the only difference between the EJ22E and EJ22T heads was the NA head longer duration cam profile. But this is what I can tell you empirically:
According to Cobb's bench flow numbers the EJ22T heads from 193 [email protected]" lift on the intake side and 147 [email protected]" on the exhaust side http://www.cobbtuning.com/tech/sohc/page2.html According to MRT's numbers the EJ205 heads flow 151 [email protected]" lift on the intake side and 111 [email protected]" lift on the exhaust side. http://www.mrtrally.com.au/performance/ click the hot link on the bottom of the page for head flow characteristics. Of course the EJ25 heads win with 240cfm and 182cfm respectively. But I get tired of people constantly say that you MUST upgrade the EJ22 heads when doind a build because the flow like s*%&! That just isn't true. They flow all right, especially for the turbo guys... |
09-30-2004, 05:42 PM | #30 |
Member#: 55867
will higher compression engines lose torque if they flow TOO much in the heads? I know that can be a problem with too large a diameter exhaust.
09-30-2004, 11:08 PM | #31 |
Member#: 53595
NWIC
so, I'm not arguing with anyone btw...
I agree, I keep hearing that EJ18 and EJ22 heads are identical in flow. I've seen pics of the EJ20 heads, and... they DO have bigger ports than the EJ18 heads. This I know. How are they measuring the cfm flow? is it by hooknig up some sort of measureing device to the head while it's assembled to the block? of course if it were in this fashio... a 8:0:1 CR engine will have less flow than a 9.5:1 engine. that makes sense... but maybe they're testing it on a bench doing something or other. I don't know how this is done. I can't justify the numbers you've given matt, but from the pictures i've seen, it looks like the EJ20 heads should flow waaaay more than the ej18 heads. which makes me wonder if ej18 heads ARE the same as Ej22 heads (minus the compression ratio) ***FUN WITH MATH*** Ej18, Ej20, and EJ22 engines use 75mm stroke. The only thing differing is the bore. Ej25 uses 79mm stroke. Both phase I and phase II. I don't know if the 22b is a phase II 2.2, but it sounds like it. but it still uses a 75mm stroke crank, just... it's phase II (different thrust bearing location) AFAIK! displacement in cc = Pi((bore/2)^2) * stroke play around with what you know to get what you don't know. you need two of the three to get the unknown. simple math. cr = amount of volume of space above the piston at TDC cc of volume from top of pistons and head area = displacement in cc / known combustion ratio take that number and divide it by four gets it how much volume is in each dish. don't forget that gasket thickness adds to volume of area above the piston (lowers compression ratio) so... from this, if you add a taller piston, less volume above the piston, increases compression. smaller dish in the heads also means less volume above the piston, so more compression. it's all pretty easy. oh, and then when you change stroke... you're actually moving the piston more. so, 75mm stroke vs 79mm stroke means that not only are you taking 2mm away from the volume of area used to figure out compression ratio, but you're also using that 2mm plus the other 2mm you're moving towards the insides of the block for displacement purposes. so figure 2mm as your length for when you figure out how many ccs you're taking away from the volume above the piston that you would use for figuring compression ratio. I could keep going.... but I need to work on this damn computer. stupid viruses. |
10-01-2004, 07:46 PM | #32 |
Member#: 832
RMIC
Jonofscio,
One question. What generation and model of EJ20 heads have you seen pics of? EJ20G's and EJ20K's have bigger ports than the current EJ205 heads. And of course EJ207's have bigger ports as well. I would really like to get some port measurements on the EJ205's as I have some EJ22T heads on my floor that I can measure for comparision purposes. I think I need to go find this one head thread from the spring with a bunch of pics and measurements from various EJ20 heads. Goin' searchin' And if you read both Cobb's and MRT's sites, they say they were benchflowed... |
10-01-2004, 07:59 PM | #33 |
Member#: 832
RMIC
I dug up one additional spec. An EJ207 Spec C v8 head flows 260 cfm@ 0.400" on intake and 195cfm on exhaust, just for comparision purposes...
10-03-2004, 12:36 PM | #34 |
Member#: 53595
NWIC
I'm not sure which heads I saw compared. but the thread is somewhere here on nabisco, I'm sure I'll find it. Good to know that there are vast differences among heads.
10-12-2004, 04:13 PM | #35 |
Member#: 832
RMIC
Ok,
Did a little personal R&D this weekend since I have both NA and Turbo EJ22 heads in my possession. I found that the intake valves on the NA heads were 1/32" larger than the ones on the turbo heads. There were other differences in water jacking and a few other things as well. My NA heads are 1990's and the turbo ones 1992's. So, unless Subaru change the spec with the release of the turbo in 1991 and started using the same cores for NA and turbo, the heads are not the same... |
10-20-2004, 12:01 AM | #36 |
Member#: 55867
Bump!
First off, if anyone was wondering, it doesn't take 4 hours to change a crank seal. Second, if I want to put cams in my ej18, what would be the way to go? Not even sure what to search for. Any ideas? Edit: I've seen a few people mention Delta Cams. If you read further up this thread, you'll see that the cams will be in ej18 heads, but on an ej22 block. Would the regrind Delta does work with the higher compression heads? I plan on doing a PnP, if that helps bring any more answers to the table. Last edited by chip4761; 10-20-2004 at 02:03 AM. |
10-20-2004, 06:27 PM | #37 |
Member#: 55867
Anybody?
10-21-2004, 10:24 AM | #38 |
Member#: 19562
NESIC
Vehicle:95 coupe red |
I've used Delta cams. Give them a call they are very helpfull. You may want to remind them that the 1.8 has roller cams. Also, make sure you have given some thought to lash adjustment. The HLA's will not make up the amount that will be taken off the cams. One possibility, the newer single port 2.2's have mechanical adjusters on the rockers, will they fit on the older heads? I don't know. One more thing, if you pull the HLA's apart you will have to replace the O rings, plan on spending about $65.00 for new ones. If you pull the HLA's out, or store the rockers anyway but the way they are on the engine (that is on their side) for an extended period of time the oil will leak out and they will need to be bled. Higher compression is always better up to the point you get detonation ( if your not worried about emissions). You may also want to search on the web about cam shaft timing/overlap and it's effects on torque/compression. Hope this helps a little.
10-22-2004, 09:48 AM | #39 |
Member#: 53595
NWIC
www.deltacam.com
I already posted that in "the other" thread. (2k for engine mods thread) I'd still love to play with doing some fun n/a stuff on my 2.2... it'll run me about $700 to get the cams, gaskets, and all the stuff to rebuild my 2.2 to have 11.5:1 compression, (already polished the intake and exhaust ports)bigger valves put in, cam regrind, crank pulley, and paint. don't forget paint. lol. *aims for 200hp or more in that* |
11-17-2004, 04:16 PM | #40 | |
Member#: 832
RMIC
11-18-2004, 02:31 PM | #41 |
Member#: 36838
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
*subscribe*
11-19-2004, 01:14 PM | #42 |
Member#: 832
RMIC
Well,
I got most of my questions answered yesterday in person. We start work on this engine today. I will post back once it is in the car... |
12-17-2004, 09:19 PM | #43 |
Member#: 64528
What is the impact of a custom crank with a slightly bigger stroke
This way you can get both additional displacement and additional Compression Would this be cheaper / more reliable than changing pistons ? I know crawford makes custom cranks Would changing the cranks take less time than changing the pistons Last edited by G.Subramaniam; 12-17-2004 at 09:20 PM. Reason: error correction |
12-20-2004, 05:09 PM | #44 |
Member#: 17439
Vehicle:2010 WRX STI SE Gray |
Bump - anxious for some more details out of Matt Monson
12-20-2004, 08:38 PM | #45 |
Member#: 832
RMIC
THE BEAST LIVES...We turned the hybrid over for the first time around 9pm last night. I will post a complete thread about it once we get it fine tuned a little bit and take it out on the road. It still doesn't have headers on it, and the clutch isn't hooked up. But it idles nice.
And to answer the question about pistons vs cranK? You can replace the pistons without cracking the block in half. The crank requires a full tear down. But personally, I still favour using a stock EJ25 with EJ22 heads w/Delta cams. We will take a dyno run once the car is all sorted out, but I am really hoping for 145-150whp out of this... |
12-20-2004, 09:03 PM | #46 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Looking forward to it.
12-20-2004, 09:45 PM | #47 |
Member#: 2289
Vehicle:1998 11.87@112mph Subaru L Ver 6 STi Type R |
I ran an EJ25 with EJ22 heads on my gocart years ago, with a 4bbl carb and distributor It made some good hp and the CR was high, you could pull the spark plug wires off and run it on ether like a diesel! Cool part about the EJ22 heads is they have that spot in the back to run a distributor, that was my initial reason for running them. I found out later it also bumps up the CR. Unfortunately the engine only lasted about a year before it pounded a rod bearing to death(Very high RPMs and G's). These engines are strong and will handle what ever kind of NA power you can throw at them.
12-20-2004, 11:54 PM | #48 |
Member#: 64528
---- How much extra time to do the cranks and pistons as opposed to pistons alone How much do stroker cranks cost and who sells them --- |
12-21-2004, 12:02 PM | #49 |
Member#: 832
RMIC
Have you ever pressed rod and crank bearings? If you have not done this level of build before, I highly recommend against it. And you are going to pay a shop $400-500 in labor to do it for you. To tear down and reassemble to block as a first timer, I would guess it would take upwards of 30-40hours in it's entirety.
As for a stroker crank, use a 2.5l crank... |
12-21-2004, 01:51 PM | #50 |
Member#: 64528
I use a specialist mechanic
I have been quoted $450 in labor to change pistons ( once the engine is out of the car ) Would changing crank take roughly same amount of money ? In addition, changing crank gives me both higher CR and more displacement, and I could use my existing pistons High CR pistons cost $550, how much does EJ25 crank cost ? Further I read that the EJ25 crank in a Ej22 has a CR of 12.5 which is unsafe |
Low Compression/High Boost vs High Compression/Low Boost? | JoeTX | Newbies & FAQs | 35 | 12-13-2016 04:50 PM |
What to do? High Compression, Low Boost or Low Compression, High Boost. | FlooredSubaru | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 01-29-2003 11:55 AM |
Tuning hp and torque curve w/ low compression and high compression pistons | FuJi K | Normally Aspirated with bolt-on Forced Induction Powertrain | 22 | 10-14-2001 08:25 PM |
High Compression | Jgrahn555 | SVX Forum Archive | 7 | 04-16-2001 01:31 AM |
High compression pistons for NA? | bsquare | Normally Aspirated Powertrain | 7 | 04-07-2001 11:56 AM |
