Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2025
Old 12-22-2004, 08:46 PM   #51
G.Subramaniam
Member#: 64528
bump
G.Subramaniam is offline   Reply With Quote
Old 12-22-2004, 10:44 PM   #52
G.Subramaniam
Member#: 64528
I have seen claims of
Cams = 15 whp
Port and Polish heads = 20 whp
Headers = 12 whp
and so on
What are the average whp and torque gains expected from
1. Raising CR from 9.7 to 11 ( assuming that heads, cams, catback are already done )
2. Stroking a 2.2L to 2.35 L
Old 12-23-2004, 07:54 PM   #53
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
This is the last time I will say this: YOU CAN GET AN EJ25 SHORTBLOCK FOR $500 OR LESS!!! For what you are going to pay in labor on the piston swap or the crank swap you can get a 2.5l engine that will make over 11:1 compression with your stock heads on it. What more do you want?
Do your port and polish. Do your cams. Get the headers. But don't spend a read cent on that bottom end. You won't set any HP records and you will spend over $1000 on a shortblock that won't provide any more power than the EJ25 block. I repeat my mantra that I have said over and over around here: OEM IS BEST...*shaking his head and walking away from the thread*
Old 12-23-2004, 09:11 PM   #54
G.Subramaniam
Member#: 64528
Ok Matt
you got my attention
What can I salvage from my current 2.2L SOHC. single port heads, MAF
1. Next level racing Air fuel adjustor - Yes / No
2. Hi Flow cat + cat back - Yes / No
3. Underdrive Pulleys - Yes / No
4. ECU - Yes / No
5. Pro ECM chip - - Yes / No
6. Delta Cam Grind #220 - Yes / No
7. Throttle body - Yes / No
8. Fuel Injectors and Fuel Pump - - Yes / No
9. MAF Cold Air intake - Yes / No
10. Current Port and Polished 2.2L single port heads - Yes / No
and what is a good source of 2.5L short blocks
Old 12-23-2004, 09:13 PM   #55
Storm
Member#: 5218
96L Most Over-
Developed Beater
I have a few (3) EJ25 shortblocks right now. I also have a couple sets of DOHC heads if you're interested.....
Jay Storm
Old 12-26-2004, 02:06 AM   #56
Matt Monson
Member#: 832
99 2.5RS, '85 911
Jay Storm
Jay,
Can you shoot me a PM with a price and details on one of those EJ25 shortblocks, preferably a phase II one. Today's oil change revealed that my bottom end is farther gone than I had suspected and I am going to need a shortblock sooner than I can get the STi block built with high CR pistons. I can just hear my engine tick tick tick. It is a timebomb counting down to a catastrophic bearing failure...
Old 12-26-2004, 01:23 PM   #57
Storm
Member#: 5218
96L Most Over-
Developed Beater
http://forums.nasioc.com/forums/show...ighlight=Storm
I have one phase II block. I was planning on keeping it, but may deal.
Jay Storm
Old 12-28-2004, 01:35 PM   #58
G.Subramaniam
Member#: 64528
I spoke to ccrengines.com on swapping the EJ25 shortblock
and they said that there are 2 specific issues / problems
1. The water jackets on the EJ22 heads dont match to the EJ25 short block
2. The head gaskets on the Ej22 heads dont match to the Ej25 shortblock
Old 12-28-2004, 04:52 PM   #59
CirrusWRX
Member#: 17439
2010 WRX STI SE
Gray
That's disappointing, but also somewhat surprising :confusing: I have access to an EJ22 and an EJ25, don't know when I'll have the time to inspect both, but I was almost positive they were the same :shrug!:
CirrusWRX is offline   Reply With Quote
Old 12-28-2004, 05:00 PM   #60
Matt Monson
Member#: 832
99 2.5RS, '85 911
Well, both blocks are open deck, so the water jackets things is false. And you use the Ej25 head gasket for this swap. The holes in the gasket don't line up prefectly, but they line up good enough. Do you really think it is going to be a problem if lots of guys are running EJ25 heads on EJ22T closed deck blocks with the same alignment issues, and those guys are running 20-30psi and 400+ hp. We are only talking about a measily 200-210chp. It is a non-issue...
Old 12-28-2004, 05:23 PM   #61
G.Subramaniam
Member#: 64528
Would a switch to cometic headgaskets be advisable ?
Old 12-28-2004, 07:06 PM   #62
Storm
Member#: 5218
96L Most Over-
Developed Beater
Cometic uses the OEM design as far as water/oil passages. The difference is in the construction. Pricewise you could go either way.....I personally would use the Cometic set. And actually am right now.
Jay Storm
Old 12-28-2004, 08:33 PM   #63
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
you can have the oem gaskets "cut" to match up better.
greg donovan is offline   Reply With Quote
Old 12-28-2004, 08:47 PM   #64
Matt Monson
Member#: 832
99 2.5RS, '85 911
be sure you are using a phase II block if you go cometic. The phase I pistons clear the deck, and you MUST use the new thick HG for this conversion...
Old 12-28-2004, 09:03 PM   #65
G.Subramaniam
Member#: 64528
If I use phase 2 blocks I can use cometic ??
Are cometic thick Head Gaskets ?
Who sells cometic head gaskets ?
Old 12-29-2004, 12:31 AM   #66
Storm
Member#: 5218
96L Most Over-
Developed Beater
You can get Cometic gaskets in any thickness you desire. They have (part #s for) OEM thickness(post redesign), Slightly thicker than stock for FI engines as well as thinner for NA and compression raising. To get them, try www.cometic.com for starters. Mention sourcemotorsports and they *may* cut you a little discount....I can't promise that though....Or you can email me with exactly what you want and I'll get them for you, since they're local to me.
Jay Storm
www.sourcemotorsports.com
Old 12-29-2004, 10:31 AM   #67
G.Subramaniam
Member#: 64528
For Phase 2 EJ25 short block
what thickness should I get for my NA, High CR application
How thin or how thick can you safely go
Is there a formula between thickness and CR
Thickness = X. CR = Y
Old 12-29-2004, 07:49 PM   #68
Storm
Member#: 5218
96L Most Over-
Developed Beater
Subaru EJ25, 100mm bore diameter
C4264HP: .043" "HP" MLS gasket, DOHC 16V <- stock thickness.
H1631027S: .027" MLS DOHC 16V <- You want this set.
Jay Storm
Old 12-29-2004, 08:20 PM   #69
Matt Monson
Member#: 832
99 2.5RS, '85 911
Hmmm....Gonna have the engine out of the car next week. Jay, will you see what sort of price you can get me on a thin one for the RS?
Old 12-29-2004, 09:17 PM   #70
G.Subramaniam
Member#: 64528
1. Phase 2 EJ25 are SOHC, so will these fit
2. What is the CR difference between a 0.043" gasket and a 0.027" gasket
3. Is a 'thin' 0.027' gasket safe for NA engines
Old 12-29-2004, 11:38 PM   #71
Storm
Member#: 5218
96L Most Over-
Developed Beater
So far the thin ones are working just fine for my NA build.
Matt, I can get them for just under $100/pair. I'll talk to my contacts and see if I can get any deal right quick. Gimme a few days since the holiday is here and I'm not sure what their work schedule is.
Jay Storm
Old 12-30-2004, 10:17 AM   #72
G.Subramaniam
Member#: 64528
Will the thin ones fit SOHC
your descriptions shows DOHC
Old 12-30-2004, 12:19 PM   #73
Matt Monson
Member#: 832
99 2.5RS, '85 911
Awesome. I already bought the OEM ones, but if you can get me some thin metal ones before Saturday the 8th when we rebuild the motor, that would be great.
Old 12-30-2004, 09:42 PM   #74
Storm
Member#: 5218
96L Most Over-
Developed Beater
You shouldn't have any problems using the gaskets with SOHC heads. I can inquire though....
Jay Storm
Old 01-01-2005, 11:41 PM   #75
G.Subramaniam
Member#: 64528
Bump
Low Compression/High Boost vs High Compression/Low Boost? JoeTX Newbies & FAQs 35 12-13-2016 04:50 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 11:55 AM
Tuning hp and torque curve w/ low compression and high compression pistons FuJi K Normally Aspirated with bolt-on Forced Induction Powertrain 22 10-14-2001 08:25 PM
High Compression Jgrahn555 SVX Forum Archive 7 04-16-2001 01:31 AM
High compression pistons for NA? bsquare Normally Aspirated Powertrain 7 04-07-2001 11:56 AM
