10-21-2016, 10:45 PM | #27751 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
Unless we are talking 5MT, then it's 4.5qts Gear Oil for everything
10-22-2016, 04:07 AM | #27752 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
10-22-2016, 04:08 AM | #27753 |
Member#: 301179
BAIC
+1, but apparently for drpoop, his manicure is too precious to get damaged or get dirty so even a lightbulb swap for him is a daunting task.
10-22-2016, 06:23 AM | #27754 |
Member#: 314216
10-22-2016, 09:40 AM | #27755 |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
10-22-2016, 10:44 AM | #27756 | |
Member#: 314216
http://forums.nasioc.com/forums/show....php?t=2578343 |
10-22-2016, 12:05 PM | #27757 | |
Member#: 316869
http://www.autoguide.com/auto-news/2...u-impreza.html |
10-22-2016, 12:07 PM | #27758 | |
Member#: 316869
10-22-2016, 02:47 PM | #27759 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
Thanks, but the article only confirms the manual for Canada.
On subaru.com, it looks like the manual is available in the 2.0i and sport. It's still not available in limited or premium, but now there is a 5MT sport sedan, which is good news. |
10-23-2016, 12:35 AM | #27760 |
Member#: 301179
BAIC
This is quite interesting... But good to hear that they are still offering MT...
10-23-2016, 09:32 AM | #27761 |
Member#: 428450
10-23-2016, 02:43 PM | #27762 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
Brake-based torque vectoring, yes
10-23-2016, 02:53 PM | #27763 |
Member#: 421858
Vehicle:2012 Impreza |
You're going to need a tesla with motors on each wheel for power based vectoring...
10-23-2016, 04:27 PM | #27764 |
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
But it's ugly so nope.
10-23-2016, 05:24 PM | #27765 | |
Member#: 319157
10-24-2016, 07:08 PM | #27766 |
Member#: 431290
NWIC
Vehicle:2013 impreza silver |
Finally found another Impreza to take pictures with! |
10-24-2016, 09:36 PM | #27767 |
Member#: 428886
E. Canada
Vehicle:2015 Impreza CBS |
Anyone have any idea about these found them listed on eBay "Tsudo 2011-2015 Impreza Sport FB20 HatchBack 2.0i Wagon Perfromance UEL Header"
10-26-2016, 10:40 AM | #27768 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
Looking for some help diagnosing a coolant loss.
So I noticed my coolant was down below the low line (when cold) in the overflow tank. While waiting to get coolant (about 2 weeks) the level went down by about a cm maybe less. Since then I have filled it up and am going to put a mark where it's at so I can track the loss. I am doing an oil change this weekend so will look for coolant in the oil. I haven't seen or smelled any coolant so don't think it's leaking anywhere. Is there anything else I should check like the radiator cap for instance? |
10-26-2016, 10:48 AM | #27769 |
Member#: 421858
I bet $1000 you're not losing coolant. Also there was no need to buy a whole jug of coolant to sit around... if it was just below the full line you only need to add literally a few spoonfuls of water to bring it back up. Does not affect freezing temperature.
Some coolant evaporates off over time, both water and EG are volatile... How many miles do you have on your car? I had to put like half a cup of water in last year because it was below the low line cold, but I didn't "lose" any coolant in the way that you're thinking. |
10-26-2016, 11:35 AM | #27770 |
Member#: 454773
I don't think I'm losing coolant either but I'm just watching it closely to make sure.
I think the coolant was low from the ambient temp going down ~75 to ~45 I bought my car a month ago and I don't remember where it was at the time of purchase. I probably only put a half cup in to get it halfway between the low and high mark. I figure I will use the coolant eventually anyways. |
10-28-2016, 01:40 PM | #27771 |
Member#: 421858
http://www.chevrolet.com/cruze-compact-car.html
Anyone see this? I know it's not AWD but it's another option, although a little more expensive than the Impreza for some reason. But it's turbo standard and gets 40mpg. Manual available. inb4 "chevy is unreliable" Just another option. Nowhere did I say it was an Imp killer, Keen and Flyboy (yeah that's right, I can predict what you're going to post before you even know what you're going to post) Last edited by drpoop; 10-28-2016 at 06:02 PM. |
10-28-2016, 06:45 PM | #27772 | |
Member#: 454773
Looks good and the base price for the mileage is great. I would so do this if it was AWD The only reason I really went for the Subaru was I couldn't get the mileage I wanted for the price including AWD. Most places to add AWD if it was even available added so much to the price it wasn't worth it. |
10-28-2016, 06:49 PM | #27773 |
Member#: 421858
Only thing is GM only puts 4WD on their trucks and full size SUVs. I don't know that they have ever had any of their cars AWD. I think their few AWD vehicles also have some part time AWD junk that I don't generally go for.
10-28-2016, 09:08 PM | #27774 | |
Member#: 319157
Transverse AWD cars are almost as goofy as longitudinal FWD cars. |
10-28-2016, 10:00 PM | #27775 | ||
Member#: 301179
BAIC
Have you recently flushed your coolant system? If you did, it could be possible that there are still air bubbles trapped in the system, and it's just slowly coming out. If not, you either have: 1. A headgasket going out. Highly doubt it, but possible. 2. Cracked radiator. Get it pressure tested. Could be possible. My miata had a hairline crack right at the radiator cap. It would only leak when the system got really hot. |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
