Brakes & Suspension Forum sponsored by The Tire Rack |
06-10-2005, 01:29 PM | #1 |
Member#: 63742
NWIC
Vehicle:2004 Subaru STI Black on Gold |
Experience with Ground Control Coils?
I know a guy at Ground Control that hooked me up with a set of there new coils fot the STI. I am putting them on a stock 04 STI, and I was just wondering is anyone else running on them or am I the guinnee pig?
06-10-2005, 03:13 PM | #2 |
Member#: 50646
NWIC
Vehicle:2004 WRX STi Java Black |
Is it their coilover conversion kit, or direct replacement springs?
06-10-2005, 04:44 PM | #3 |
Member#: 63742
NWIC
It's the coil conversion kit.
06-10-2005, 05:18 PM | #4 |
Member#: 70532
Vehicle:2015 STI Grey Metallic |
A few vendor sites are saying that some grinding might be necessary to fit the conversion kit to the stock wrx or sti shock. Im interested in whether that is the case...
06-10-2005, 05:30 PM | #5 |
Member#: 50646
NWIC
They've been available for a while and many people here have installed them. I plan on doing the install tomorrow.
http://forums.nasioc.com/forums/show...hreadid=252447 |
06-10-2005, 06:32 PM | #6 |
Member#: 34162
Vehicle:2005 WRX wgn, 01 RS White, White |
I have the Ground Controls with v7 STi struts.
SOOO nice. Car sticks to the road like crazy. Me likey. |
06-10-2005, 06:33 PM | #7 |
Member#: 50646
NWIC
While on the topic, do the Ground Control kits usually come with a wrench for the spring perch? I'm not seeing one. =)
06-11-2005, 03:18 PM | #8 |
Member#: 50646
NWIC
So far not enjoying GC; checked all of the bolts 3 times, duct-taped between the strut & threaded collar, but am having rather significant "thunking" over decent-sized bumps.
06-11-2005, 03:26 PM | #9 |
Member#: 50646
NWIC
What a dumbass... tightening the top strut bolt some more seems to have done the trick. =) Now to continue working in this Seattle mini-monsoon...
06-15-2005, 09:17 AM | #10 |
Member#: 50646
NWIC
FYI the Ground Controls are working fine. Makes me a little nervous having all that slack between the spring & strut top when the suspension isn't compressed, but still works okay. Also it saves roughly 20 pounds of unsprung weight.
06-15-2005, 01:18 PM | #11 |
Member#: 88472
The slack in the assembly won't be an issue. Remember, the stock inserts are designed for a much longer spring. Every conversion kit will have this issue unless you run shorter dampers or a tender assembly.
A spanner is only necessary for preloaded assemblies. No grinding should be needed. |
06-15-2005, 04:36 PM | #12 |
Member#: 50646
NWIC
Yeah I noticed during the install that it's quite easy to adjust with your hands. A little bit of a pain doing the hex bolt with the stock perches still there since I didn't cut them off.
06-15-2005, 07:08 PM | #13 |
Member#: 6034
BAIC
Vehicle:2002 WRX It's Soo-BAH-roo |
If the slack bothers you, you can get some tender springs from Ground Control for that. You'll also need the appropriate sized spring couplers.
06-15-2005, 10:29 PM | #14 |
Member#: 88219
BAIC
Vehicle:2003 WRX |
Yes, tender springs can also make for a more comfortable ride.
06-15-2005, 10:52 PM | #15 |
Member#: 50646
NWIC
Thanks, didn't know about those before but found this:
http://e30m3performance.com/tech_art...-tech/springs/ Looks like helper springs might be perfect. |
06-16-2005, 12:42 PM | #16 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
yup and i would wager they sold you sprigns that are way too stiff too
GCs were a bad idea when they first came out with the subaru kit ~1999 and are still a bad idea linear springs with stock struts is just not a good idea |
06-16-2005, 12:48 PM | #17 |
Member#: 50646
NWIC
Aren't the stock STi springs linear rate (224f/194r)?
07-19-2005, 12:04 PM | #18 |
Member#: 70532
Yeah, but they have a much higher dampening ability than the gc or wrx struts do, so it probably doesnt matter that much. I like linear springs for racing because I like a linear response in my steering inputs, but nonlinear springs are definitely more comfortable and streetable, especially on struts that dont have adjustable dampening.
07-19-2005, 04:26 PM | #19 |
Member#: 7492
South East
Vehicle:No race cars www.tomhoppe.com |
Yes, we have the GC setup with helper springs on stock 05 STi struts. The struts are valved perfectly for the 325/300 spring rate and the helper springs prevent any spring slack.
-Tom |
07-19-2005, 06:13 PM | #20 |
Member#: 43580
Vehicle:2004 Impreza WRX Blue |
Anyone have any pic of these on their, just wondering to see what the strance and cleariance looks like. Thanks
07-19-2005, 06:16 PM | #21 |
Member#: 7492
South East
They are "coilovers" which means adjustable sleeves. You can do whatever you want.
-Tom |
FS/FT 05 STi Struts with Ground Control Coils | kevin05wrx | Suspension/Brakes/Handling | 9 | 02-25-2009 10:29 PM |
Ground-control coil overs for WRX - spring rate/length... | rwroth | Brakes, Steering & Suspension | 0 | 09-09-2001 11:22 PM |
Who sells Ground Control Coil Over Kits? | Swivel1000 | Brakes, Steering & Suspension | 3 | 04-29-2001 11:36 AM |
ground control coil overs | hondaconvert | Brakes, Steering & Suspension | 18 | 04-12-2001 12:02 AM |
Ground Control Coil Overs?????? | Elite Twit | Brakes, Steering & Suspension | 14 | 03-25-2001 12:38 AM |
