09-02-2008, 12:40 PM | #1 |
Member#: 71075
Vehicle:1998 Impreza RSTi Faded Rally Blue |
EJ207 Swap: After startup, strange idle
Swapped a JDM STi V7 motor into 1998 2.5RS. The engine starts up fine, but after it runs for about 20 seconds, it begins to idle strangely. It idles at about 1200 RPM and creeps up a little, then seems to cut the fuel. It repeats this over and over.
If you put your finger between the maf and the flex pipe (allowing air to bypass the maf), it seems to idle normally. I do not have a fuel pump controller (yet), so the fuel pump is wired to be full on. Here is a video of it running. http://www.s-ca.com/temp_pics/subaru/day6/MVI_3470.AVI Additional details: Model: GDBA4EH Engine: EJ207DW3CR Thanks a lot, John |
09-02-2008, 03:01 PM | #2 |
Member#: 166898
W. Canada
Vehicle:1994 T leg SS ABM |
SOunds like you know your problems, Do what you can and see what happens!
09-02-2008, 05:14 PM | #3 |
Member#: 71075
Does it seem like the MAF is bad? It was open to the elements for a while.
09-03-2008, 08:29 AM | #4 |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
This is not caused by lack of fuel pump controller. Make sure your MAF is positioned correctly in the tube. The plug should be facing the front of the car.
Z |
09-03-2008, 01:22 PM | #5 |
Member#: 166898
W. Canada
possibly yes..
But wont the IAC be sucking in air on idle anyways |
09-05-2008, 01:16 AM | #6 |
Member#: 157526
RMIC
Vehicle:2020 Sierra 1500 AT4 Silver |
My buddies car did this, we had to replace the TB and it worked :P
09-07-2008, 03:49 AM | #7 |
Member#: 38068
South East
Vehicle:03 WRX Wagon |
Try cleaning the IAC. Never seen a bad MAF do that, however im sure its possible.
09-07-2008, 11:04 AM | #8 |
Member#: 71075
Thanks a lot for all the replies.
It turned out that either the throttle cable was not adjusted properly, or the throttle body was stuck. For some reason, after we started the car again, the engine started racing to 5,000 rpm, instead of the previous behavior. That's when we looked at the cable and adjusted it. After that, it idled great for about 30-45 minutes. |
Similar Threads | ||||
Gurgling noise after startup? | Mind | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 12-11-2015 04:14 PM |
Engine shake and strange idle after accident | ziyue | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 09-22-2009 11:34 PM |
People with cold startup high idle issues | 98EJ20 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 01-22-2008 06:47 PM |
Engine shut off after startup | freds88 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 02-02-2005 05:06 PM |
Running like crap at startup. Barely idling. | Rickyh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 02-01-2005 10:14 PM |
