Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2018
Old 06-15-2006, 03:55 PM   #1
kaisersouse
Member#: 85900
2001 Forester S
Default Jamie (or anyone else who can help)...can you help me find brake part number(s)?
So now that my little episode with my drum brake has gotten worse (fluid pissing out of the piston. No its not the bleeder valve.) I'm now wanting to do that disc conversion sooner rather than later.
I bought these[/url] off a member here about 6 months ago. I know only one is pictured, but I got a set. According to the post they would fit my axles/rear diff. They are JDM STi...but I can't remember what version and year wasnt stated. I want to say version 6...but thats not definate. By the way...what are these things officially CALLED (insert laughter here).
I need calipers, pads and rotors. I think thats all I need....can you tell what else I might need from the pic? The only part-ish looking number was a raised "6F 19" but I have no idea where else to look. Theres numbers on the rubber bushing...but I'm assuming those relate to the bushing itself.
So anyways...I'm trying to find a # for the calipers primarily. It would be nice to be able to walk in somewhere and go "yah I need rear pads for {model}" too...but if its just a part number I'll definately take that too. I'm going on desperate here. I spent $120 for these, I wasnt going to swap in the winter but I shouldve done it the instant it got above 50 degrees. I'm fed up with this "maze of springs and voodoo" bull****.
Tangent: My bro-in-law (>real< mechanic) is coming over to help me out if this next test doesn't work. Bumming a ride to work tommorow (thank GOD). Liek any of you care.
Hi.
And thank you. Tell me what I can do to repay. I'm sure this isn't a 2 minute task I'm begging for.
PPS: Jamie...Can you get older JDM stuff and if so how much? Needless to say if you have them I'm just getting them thru you because christ only knows what I'd get if I asked around local (plus that would be a lame thing for me to do..ask for someone to spend time looking up part numbers based on pics...then buying the stuff somewhere else).
Pictures:
FIXT:
I posted pictures of my cats instead of the right ones, because I am stupid. Standby.l
kaisersouse is offline   Reply With Quote
Old 06-15-2006, 11:59 PM   #2
Boxologist
Member#: 21118
a fustercluck may be happening if those are r180 hubs. they may not fit ur axles. if they are r160 hubs, u may then run into issues with which caliper they had orignally, 2pots or 1pots. different rotors fit each.
if u can get a center to center measurement on the caliper mounting bolt location i can check if its 2pot or 1pot backing plate over the weekend.
Boxologist is offline   Reply With Quote
Old 06-16-2006, 10:18 AM   #3
kaisersouse
Member#: 85900
2001 Forester S
I'll measure that tonite. And they are r160s definately.
THANK YOU
Old 06-16-2006, 11:14 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
pm my vendor name: subarugenuineparts
with details of what you need and i'll get you part numbers
in a couple of hours i'm leaving for a race this weekend
so i wont be able to do this until Monday
good luck
Jamie
Subie Gal is offline   Reply With Quote
Old 06-16-2006, 12:05 PM   #5
kaisersouse
Member#: 85900
2001 Forester S
good luck
Jamie
I will...and whenever you get to it is awesome awesome awesome. Thank you
oh and good luck on the race!
Old 06-19-2006, 09:41 AM   #6
kaisersouse
Member#: 85900
2001 Forester S
entire thing is about 11" in diameter. I was able to match it up to my 15" wheel with what looked like enough room for a caliper. The caliper holes are 5 3/4" apart...center to center. Hope that helps some...
Old 06-19-2006, 08:12 PM   #7
Boxologist
Member#: 21118
the 2pot mounting holes were ~115mm(4.5") center to center. u probably will need the 1pot calipers, but i can't give u positive answer until i pull off a rear wheel to get at the brakes.
Attn.: SubEd, Turismo Lou, Brucelee or anyone else who might be able to help me Janq Off-Topic 60 11-28-2005 11:58 PM
Can you help me finding Part # ?? Power_Getter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-15-2005 10:45 AM
('93-'01) Part question - Jamie or anyone else... Rice & Gravy Impreza Forum 4 08-19-2004 01:05 PM
Can you help me find my rally car? Subie Gal Vancouver Impreza Club Forum -- VIC 3 07-24-2001 12:33 AM
