11-17-2017, 03:04 PM | #6226 | |
Member#: 58504
South East
Vehicle:2004 STi Aspen White / Silver |
But it turned out fantastic! You did a great job with it. Congratulations. Hope it sands up and stains nice. It's nice to have stuff you built yourself.
11-17-2017, 04:14 PM | #6227 |
Member#: 339032
Anyone ever build a compressor shed off their garage? How did it turn out? Any tips?
I started building one off my detached to house a 60 gal compressor. Got the slab laid so far and now I'm giving it a couple weeks to cure before I drill it for anchors to build the walls up around the outside. My plan is to build a simple shed with r13 insulation, intake on the bottom and forced exhaust up high. Would it be worth it to insulate with Roxul instead of fiberglass batts for added acoustical dampening? It will have 2x4 walls but the shared wall with the garage will be insulated on both sides. I'm trying to keep the noise down within reason. https://imgur.com/Vmk71jb |
11-17-2017, 04:27 PM | #6228 |
Member#: 85327
RMIC
Vehicle:1964 Miata Hairdresser Red |
This seems pretty well thought out. if you are bolting it to the concrete make sure to put some sort or rubber bushing on the bolt to reduce vibration noise.
http://www.cianperez.com/Photo/Expos..._Enclosure.htm |
11-17-2017, 04:53 PM | #6229 |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
One thing to consider is that when you enclose it, it will get as hot as the hubs of Hades inside when it is running. Some sort of ventilation should be part of the design.
11-17-2017, 07:45 PM | #6230 | |
Member#: 46134
TXIC
Finished the sanding today. I'm super happy with the result. Wife will stain over the weekend, I can seal on Monday and mount the plumbing and place it hopefully on Tuesday. |
11-17-2017, 07:58 PM | #6231 | |
Member#: 26859
TXIC
Vehicle:of TXIC I also like (oYo)!!!! |
11-17-2017, 08:03 PM | #6232 | |
Member#: 26859
TXIC
11-17-2017, 09:06 PM | #6233 | |
Member#: 17256
South East
11-17-2017, 09:15 PM | #6234 |
Member#: 22035
SCIC
Vehicle:2014 Brocoma DCab 71 FJ40, 13 DRZ400SM |
11-17-2017, 09:46 PM | #6235 |
Member#: 306129
I thought adding a piece of wire shelving above my washer/dryer would be super easy, just a few holes in the masonry wall, run the screws in, check for level, done, right?
Nope, the brand new Bosch concrete/masonry bit won't do anything to the wall unless it's on hammer-drill, and that blows chunks out of the block wall so the screws have nothing to grab onto. On just drill, it sits and spins with very little progress made. Fffffuuuuu... |
11-17-2017, 10:38 PM | #6236 |
Member#: 149174
Vehicle:that 's cool. i have a goldfish. |
You could get a significantly smaller bit? You might have to drill multiple pilot holes
11-17-2017, 10:58 PM | #6237 |
Member#: 137902
Vehicle:---- living life to the least!! |
sometimes on the face it'll blow pieces out but as you penetrate further it should be better....
11-17-2017, 11:12 PM | #6238 |
Member#: 224432
Vehicle:1997 Outback Limited 2012 DGM Impreza Hatch |
That's what she said...
For the compressor housing I'm pretty sure just having it outside will be plenty quiet, standard insulation would work great. The biggest concern is sealing it off with proper airflow so animals (wasps) don't decide to make a home in there. As far as mounting, get some hockey pucks and drill holes in them. Or use some thick rubber mat. For my compressor I made up a 2x2 pallet, put a few sheets of foam on top then put another piece of 2x2 plywood with some lag bolts very loose so it kind of 'floats'. You can stand right next to it without feeling a thing. I also ran a remote drain hose so I don't have to get on my hands and knees to drain it. Since you have some extra room you may also want to look into a water trap/heat exchanger. I made one with about 8 feet of copper tubing zig zagged on the wall with the water trap at the lowest part. |
11-18-2017, 06:38 AM | #6239 |
Member#: 47982
Those are going to look fabulous after a few months of mineral buildup.
11-18-2017, 08:36 AM | #6240 |
Member#: 58504
South East
The rubber foot mounts aren't the best. They always harden to the point they don't really work, and shortly afterwards they crumble into little pieces.
You have to replace them every couple of years. The spring type, or wire rope type isolators are much more effective and last much longer. But they are not $10 either. For sound insulation, the egg crate type foam works really well. Use contact cement to attach it to the walls and a few staples for good measure. Alternately, carpet padding is also great, and the foam type is fairly moisture resistant. Even old carpet works pretty well, and can be found for free. I recommend you also caulk all internal joints to make it as airtight as you can using a good exterior silicone caulk. When you make the intake vent, as was recommended, make sure it is insect proof. And baffle the intake so that the sound has to turn a lot of corners. A labyrinth style baffle is perfect. |
11-18-2017, 04:17 PM | #6241 | |
Member#: 306129
I hit Home Depot again for a kit of screws and plastic expansion anchor sleeves, which came with sized non-hammer-drill bits, hopefully those will do better. |
11-18-2017, 05:18 PM | #6242 |
Member#: 33287
Vehicle:RIP Nik I will always miss you |
11-19-2017, 07:26 PM | #6243 |
Member#: 250084
Vehicle:2019 STI Pure red |
Just have to do touch ups and paint base molding
11-19-2017, 07:27 PM | #6244 |
Member#: 250084
Continued..
11-19-2017, 07:36 PM | #6245 |
Member#: 6590
Damn, Son! Rent that **** out for $2,000/month
11-19-2017, 07:49 PM | #6246 |
Member#: 250084
11-19-2017, 07:51 PM | #6247 |
Member#: 155207
Vehicle:2020 MDX 2022 Odyssey |
Beautiful. So jealous.
11-19-2017, 08:52 PM | #6248 |
Member#: 306129
I'm a huge fan of a hand rail or two in a shower, you can buy nicer lever-actuated suction cup ones on Amazon, but screwed into a stud is much better. No one wants to bust their face or break a leg because they lathered up too much or tried to in the shower.
11-19-2017, 11:45 PM | #6249 | |
Member#: 133597
SCIC
11-20-2017, 08:36 AM | #6250 |
Member#: 12368
Vehicle:2008 Infiniti G35X 2011 BMW X5 Diesel |
Johnny. Do you have floor plans of that? I am building a similar half wall. What is the length of it? Is the extra room a workout room or bedroom?
