03-30-2010, 11:25 AM | #1 |
Member#: 142591
Vehicle:2002 Imprezza WRX WRB |
Car studdering...wierd. help please
The other day I was driving around 35 mph. Someone was going about 40-45 and rear ended me. The hit didnt mess up my bumper or did anything visible really. But the engine started to studder. And today in the morning that I jumped in the car it idles pretty rough and studders like a mofo when i accelerate. I would have to accelerate really slow to not notice it. What could it be?
03-30-2010, 11:28 AM | #2 |
Member#: 218001
Vehicle:1995 impreza carriban green |
did u check the charcole canister in the rear maybe a vacuum line came out or it got a crack this can cause the engine to take in un-metered air causing it to stall. not 100% shure about it but take a look. you never know.
03-30-2010, 11:34 AM | #3 |
Member#: 142591
What charcole canister?
03-30-2010, 11:37 AM | #4 |
Member#: 218001
look under the rear bumper its a square black box i forget its either on the left or right side. it should have like 2 to 4 hoses going and coming from it. its visible from underneath.
03-30-2010, 11:42 AM | #5 |
Member#: 142591
i just found it... Havent seen the hoses..But I do see an electronic plug that seems to be broken.. I have no idea where it goes...
03-30-2010, 11:42 AM | #6 |
Member#: 151045
It will be on the passenger side. And yes...if the hoses get knocked loose you may have an intermittent vac leak depending on the state of various solenoids (purge, pressure control, etc.)
03-30-2010, 11:44 AM | #7 |
Member#: 218001
check and see if u can splice a new connector on. it might solve ur problem if the connection is broken like u say it is.
03-30-2010, 11:45 AM | #8 |
Member#: 142591
Ill take a pic of the plug. Maybe you guys know what it is. Give me 5 minutes
03-30-2010, 11:53 AM | #9 |
Member#: 142591
It seems like its been off for a while though...
The wire is resting on top of that hose, but if i let if fall it drops about 7 inches down. |
03-30-2010, 12:01 PM | #10 |
Member#: 218001
yea that's deff been like that for a while. just look up and around it maybe ull notice something else. like what Haelan said before one of the hoses could have been knocked loose, or solenoid damaged. try and find the the rest of that harness btw. with the canister disconnected you run a high risk of setting your a** on fire.
03-30-2010, 12:01 PM | #11 |
Member#: 142591
Im gonna drop the canister and check it out.....Where can I find the selenoid you guys speak of?
03-30-2010, 12:06 PM | #12 |
Member#: 151045
03-30-2010, 12:07 PM | #13 |
Member#: 151045
Just a thought....did you look around in the engine bay too? Make sure your y-pipe didn't pop off?
03-30-2010, 12:07 PM | #14 |
Member#: 218001
not too shure but i can look around for you.
03-30-2010, 01:28 PM | #15 |
Member#: 142591
Ok I checked it out and nothing was disconnected besides the plug. Which was somewhat broken off ... It connedts to a hose connection. I glued it back on. I checked the Y pipe and its fine also.
03-30-2010, 01:29 PM | #16 |
Member#: 142591
Seems to me that it has somethign to do with the pressure.... It does it if I press the accelerator down more than normally.. The boost kinds stays at the 0 on the stock gauge then jumps up a little.. So i'm thinking boost leak or something with the fuel pressure.
Im going to post a video later and hopefully u guys can help me out. i read this http://www.autoshop101.com/forms/h62.pdf, and I might have abad gas cap thats causing this, or pretty much any component this talks about... Last edited by subizzo02; 03-31-2010 at 02:07 AM. |
03-31-2010, 12:46 PM | #17 |
Member#: 142591
Allright I scanned the codes and got...
P0340 Camshaft Possition Sensor A Bank 1 Circuit Malfunction and P0447 Evap Emmissions Control System Vent Circuit Open I got that one 2 times. i dont knwo why. On the second one, the reader had a small "pd" logo on it. That connector is the one that was broken! Last edited by subizzo02; 03-31-2010 at 12:55 PM. |
03-31-2010, 12:54 PM | #18 |
Member#: 151045
Camshaft Position Sensors are fairly cheap especially for a used one. Try replacing it and see if it clears up most of your troubles. If you're handy with a multimeter you can check the resistance on the sensor itself and verify the wiring to the ECU.
P0447 does indeed you have a problem somewhere in your evap system. It's complex and goes from the intake manifold to the maze of junk back by the charcoal canister. I don't have my DTC manual at work or I'd post what I could about the code. "pd" might be short for "Pending" code. It hasn't triggered since the first P0447 is already registered. |
03-31-2010, 01:17 PM | #19 |
Member#: 142591
I checked the valve that is on top of the canister, the one with a black hose fittign on top, and electrical connector, and 2 fittings on the bottom. Is that supposed to be a chek valve? i blow air and it goes through, and then I suck air and it sorta closes, but still lets some air through. I took if off and cleaned it. I blew it out with the air compressor. Reinstalled it, cleared the codes, and turned on the car. The codes came back after abnout 10 seconds.
It DID run a little better though. Since it started after the hit on my bumper, do you guys think the charcole might have come lose and clogged something? I remember reading that it could happen.. |
03-31-2010, 01:47 PM | #20 |
Member#: 151045
Another thread that may help you: http://forums.nasioc.com/forums/show...ighlight=P0447
You may be able to PM some of those folks and see what their issue ended up being. |
04-03-2010, 07:20 PM | #21 |
Member#: 142591
Allright. I took it to autozone to get the codes and it had a bunch of misfires. I decided to get the spark plugs. I installed them and its pretty much the same.
I have noticed that in the mornings it misfires like crazy. It shakes at idle as well. After the cars been running and its warm, it works ALOT better. I also noticed that if i dont boost it it works ok. And as soon as I go past "0" on the gauge it starts to act up. Any ideas?? |
04-03-2010, 07:40 PM | #22 |
Member#: 220158
RMIC
Vehicle:02 bugeye medamullet tuned |
bad coil packs? dirty injectors? those are just some ideas
04-03-2010, 08:16 PM | #23 |
Member#: 142591
My next step is adding a fuel cleaner and seafoam. After that Im going to check the coilpacks, ill come back w the outcome tomorrow.
04-05-2010, 03:29 PM | #24 |
Member#: 142591
Im about to add the seafoam now. I drove it earlier and I noticed something else, I get alot of fluttering from my wastegate. Its a stock wastegate. I never had flutter like now.
04-06-2010, 04:20 PM | #25 |
Member#: 142591
Ok, After adding the seafoam It fixed nothing. Although, i did see alot of smoke come out the exhaust manifold. Can it be possible that a big leak in the exhaust manifold is causing the turbo to not spool propperly, and making my car stutter alot?
Car Audio Newbie - Help Please! | Xavalis | Car Audio, Video & Security | 10 | 03-10-2006 12:03 AM |
2002 stage 2 acting wierd HELP PLEASE!!! | sb253 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 11-23-2005 07:02 PM |
Car Dumping Problem,?? Help Please | killasubi4569 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 09-26-2005 05:12 PM |
Car TV/computer, help please | Unsung Boxer | Electrical & Lighting | 11 | 03-19-2004 04:23 AM |
car audio experts, help please! | VSM EXtasy | Mid Atlantic Impreza Club -- MAIC | 7 | 10-31-2003 07:30 PM |
