Welcome to the North American Subaru Impreza Owners Club Wednesday April 8, 2020
Vancouver Impreza Club
Old 06-27-2013, 08:13 PM   #51
DIGGYGV8
Member#: 313558
2011 STi Sedan
are you sure it needs to be running and not in <ON> mode for the key? the car shouldn't see it as a big difference. if you've first hand verified this, i'll add it to the article.
DIGGYGV8 is offline   Reply With Quote
Old 06-27-2013, 10:16 PM   #52
thesniperz
Member#: 235744
2000 Forester STi
White - JDM yo!
yes.. i tried it (multiple times) with having the key in ON mode and didnt work..
some vid i found..
thesniperz is offline   Reply With Quote
Old 06-27-2013, 10:27 PM   #53
OTG
Member#: 313951
2006 STI
^ You gotta do it 20 times in 30 seconds. Engine doesn't have to be running just key on.
OTG is offline   Reply With Quote
Old 06-28-2013, 08:49 AM   #54
DIGGYGV8
Member#: 313558
2011 STi Sedan
Yes, as per my reply.
thesniperz, I'll add the compatibility note up top when I have a chance. Thanks!
Old 08-02-2013, 11:56 AM   #55
DIGGYGV8
Member#: 313558
2011 STi Sedan
bump.
threw two hard CELs during my trip to the states for BNW meet 2013.
Keep in mind the Seatbelt chime trick will be reset if you remove your battery to reset ECU.
Old 09-01-2013, 05:22 PM   #56
DIGGYGV8
Member#: 313558
2011 STi Sedan
bump.
Anyone has any new tricks/tips to submit?
I'm working on an article to fix the broken strut/shock for the glove box. (as mine just broke last night)
Old 09-01-2013, 05:48 PM   #57
Neilm
Member#: 345975
2013 wrx STI
white
i have an ecu pinout for 2012+ i can post in a bit
Neilm is offline   Reply With Quote
Old 09-01-2013, 07:16 PM   #58
DIGGYGV8
Member#: 313558
2011 STi Sedan
2012+? I wonder if this differs from 2011.
make sure to follow syntax of previous KB articles, and I'll credit you appropriately! :P
Old 05-19-2015, 02:56 PM   #59
DIGGYGV8
Member#: 313558
2011 STi Sedan
Default Aftermarket Seat Install Airbag Light Fix
Old 05-19-2015, 03:42 PM   #60
lymphomaniac
Member#: 334451
2018 WRX Sport CVT
CBS
Since Diggy (OP) bumped this, and because I've got an itching (or is it burning?) curiosity to know, does anybody know if this fix will work for the MY '15 WRX / STI (ie. the VAs)?
Originally Posted by DIGGYGV8 View Post
For the first tip/trick I know...
*disclaimer* All information I know (unless otherwise stated) is gathered from owning my '11 STi Sport-Tech Canadian Model. Please take extreme caution, and use any information at your own risk.
Problem:
It was that I was being annoyed at the A/C automatically turning on when I change my vent setting to defrost the front windshield. Sometimes I just want the windshield to have warm-ish air to defrost without the A/C on. In other cars I've owned, there was a certain button sequence to disable the auto A/C.
Solution:
- If you are on defrost vent position already (and unsure if the compressor is running):
press the A/C button to turn the A/C on, and then off. This will ensure the A/C compressor is off, and you will still be in defrost vent position, but without A/C on.
- If you are on any other vent position (and desire to be in defrost without A/C):
move selector to defrost vent position, the A/C light should come on, press A/C once to turn off the compressor.
Notes:
If you change the vent to any other selection, and back to full defrost, it will automatically turn on A/C again.
If you have climate control (Sport-Tech for MY11-13), and have HVAC set to AUTO control, you will be able to turn off A/C manually, but this will affect performance.
The setting will remain if you change the fan speed, AND if you turn off the car.
Tested Compatibility:
- MY09 STi
- MY10 STi
- MY11 STi w/ Sport-Tech
- MY12 STi w/ Sport-Tech
lymphomaniac is offline   Reply With Quote
Old 05-19-2015, 04:59 PM   #61
cp2503
Member#: 292566
2011 WRX ltd GV WRB
Problem:
A lot of people say the stock radio non nav unit sucks and does not have a good quality sound what so ever.
Solution:
TRICK 1: By having key on No.1 position (accessory only) turning on your radio. by pressing 1 and 6 together and by pressing the tune button you can switch the deck from LOUD OFF to LOUD ON. this will give you a little more bass from crappy radio quality.
TRICK 2: same thing key on no.1 position. turn radio unit off. BY pressing 1 and 4 together and double tap tune button you can change the deck setting to THROUGH MODE. which imo the best of them all. (1,2 double tap tune is SEDAN MODE; 1,3 double tap is WAGON MODE)
Notes:
-I didn't discover this hidden trick so all credit goes to the internet
https://www.youtube.com/watch?v=AnYFs6OpGGs
check out this video if my instruction isn't very clear.
- 11-14 WRX, Sti
cp2503 is offline   Reply With Quote
Old 05-19-2015, 06:32 PM   #62
DIGGYGV8
Member#: 313558
2011 STi Sedan
My friend has a VA. I'm going to try it with his when I see him
Originally Posted by cp2503 View Post
http://www.i-club.com/forums/stereo-...uttons-248307/
this is one of the trick I find a must for people that have stock non-nav unit radio.
Hey, would ya mind formatting that into the syntax of the other posts? I will credit you in the first post. I just want this thread to look back on incase links die etc.
Old 05-20-2015, 10:38 AM   #63
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
I've stickied it for ya
rs420 is offline   Reply With Quote
Old 05-20-2015, 03:50 PM   #64
lymphomaniac
Member#: 334451
2018 WRX Sport CVT
CBS
Huzzah! Huzzah!
Old 05-20-2015, 04:40 PM   #65
DIGGYGV8
Member#: 313558
2011 STi Sedan
Sweet! no more having to search! Thanks!
Old 05-20-2015, 09:19 PM   #66
Ricewagon
Member#: 59703
2004 STi
always wrb
What's going on in here?
Ricewagon is offline   Reply With Quote
Old 05-27-2015, 05:44 PM   #67
DIGGYGV8
Member#: 313558
2011 STi Sedan
GR/GV old man! no place for your kind in here
Old 05-27-2015, 05:45 PM   #68
DIGGYGV8
Member#: 313558
2011 STi Sedan
I should add that if anyone has tested any of these articles on other models than listed, please let me know so I can add it to the compatibility.
Old 05-30-2015, 02:33 PM   #69
Zordos
Member#: 165121
Works on 08 2.5i
Zordos is offline   Reply With Quote
Old 05-30-2015, 03:00 PM   #70
DIGGYGV8
Member#: 313558
2011 STi Sedan
Originally Posted by Zordos View Post
Works on 08 2.5i
which article? I'll add it to the list.
Old 05-30-2015, 04:28 PM   #71
Ricewagon
Member#: 59703
2004 STi
always wrb
Models list? testing on them? Where can I sign up?
Old 05-30-2015, 10:27 PM   #72
Zordos
Member#: 165121
Sorry the radio tricks
Old 11-15-2015, 02:57 PM   #73
lymphomaniac
Member#: 334451
2018 WRX Sport CVT
CBS
I just had a quick read-through on the VA thread in the General Community forum. Looks like there's no defeat for a/c (and possibly "Auto" mode on the climate control system?) on the VA's. Kinda sucks (and sucks fuel), because I'm the kind that likes to control what kind of air is flowing into the cabin, and how quickly it does so. You don't really need dehumidified air to keep condensation off the windshield (although I agree that it helps), you just need to keep the windshield above a certain temperature and ensure free-flowing air.
Diggy - could you please confirm the VA constraints with your friend?
Old 12-23-2017, 02:23 AM   #74
edsuusde
Member#: 479436
2012 STi HB
great info, thanks.
edsuusde is offline   Reply With Quote
