Welcome to the North American Subaru Impreza Owners Club Tuesday April 7, 2020
Old 02-11-2016, 03:42 PM   #1
TylerHartman
Member#: 307597
1999 Legacy GT
Default TylerHartman's 1999 Legacy GT Wagon 6MT+EJ205AVCS
TylerHartman's 1999 Legacy GT Wagon 5SPD
Well on Tuesday, November 18th at 4 am I was on eBay and Came across a 99 Legacy GT Wagon with a Blown Engine over 2,100Miles away ending at 5:00 PM. Long story short I ended up winning the car...
The Car: 1999 Legacy GT Wagon 5 Speed with Sunroof. Pretty Rare combo I've heard, It has a 137,000 Miles and Suffers from two dents from the pictures I can see and a Knocking engine, although the dents and engines are Aye-Okay in my book since I've been watching for a Rust Free, 5 Speed wagon here in Indiana/Ohio for a while and haven't found anything this clean or sweet.
Body Work/General Completed
-Respray Factory Color
-DogLeg Trim Pieces Deleted
-Antenna Deleted
-Badges Holes Deleted
-JDM AeroMajic Rear Skirt With Custom Mounts
-Refinished Roof Rack
Maintenance Work
-Steering rack boots
-Por15 Painted Front Swaybar, Rear hubs, knuckles, Front Sway bar brackets
-Rear Wheel bearings,
-Front Drivers Side Wheel Bearing
Parts on the way or order soon:
-JDM Climate Control, JDM Climate Control Trim/Vents
-Custom Brackets for FX-R Retrofit into JDM Housings
-Kartboy lockdown bolts
-JDM Power Folding Mirrors (White)
-JDM Aero Spats (White)
-JDM BG5 Rainguards
-Cool Nuts Coolant Hoses
-eyelids
-2004 STI Steering Rack
-Chargespeed Yellow Glass
-Aftermarket grille
-JDM GC8 Ver1-3? Fender Coolant tank
-JDM Panasonic ETC CY - ET906KD
-Beatrush blue reverse lockout
My Up Coming Plans
-Turbo smart/Tial 40MM/38MM EWG
-EL Header
-Open Source Tune (SD)
-BLUEFLEX PLUG-AND-PLAY ECA
-ID1050X Injectors (coming soon)
-EBCS
-Cobb Short throw (coming soon)
-2016 VF48 with 5,000 Miles (waiting)
-Cobb SF Intake (waiting)
-Aeromotive Fuel Pressure Reg with gauge (waiting)
Exterior:
-HOOD STRUTS/DAMPERS Carbon Fiber (Prova?)
-Beatrush Belt Cover
-JDM ZERO SPORTS Cool Radiator Legacy Cover
-JDM ARC Carbon Fiber Hood scoop Extension
-JDM AeroMajic Rear Skirt/Lip
-JDM Liberal 3 Part wing
-JDM Silm Door Moldings
-JDM Facelift Bumper + Bumper Beam
-JDM Projector Fog lights
-JDM Clear Side Markers
-JDM Smoked “kouki” tail lights
-JDM Projector Headlamps
-JDM GTB L7 Red Badge Grill
-Hella Supertone Horns
-Honda Pilot Wiper
Interior:
-JDM BH5 GT-B Front seats
-USDM 99 Limited Center Vent and Radio bezel
-TopStitchTrim Shift boot
-Ashtray delete
-Noico 80 mil 36 sqft car Sound deadening
-Option Rear Cup Holder
-Outback Floor panels (Tie down points)
-USDM 00-04 Wood LL Bean Wheel
-00-04 Underseat Subwoofer
-Forester/2.5RS Compass
-USDM 98-02 Forester Option Leather E-Brake Handle
-USDM 2004 WRX Red Momo Airbag
-EDM/USDM (Rare) Door Grabs
-OEM OB Limited Rear D Pillar Tweeters
-I30 Auto-Dimming Rearview Mirror
-JDM Aluminum Legacy Door Sills
-JDM Center Console E-Brake Trim
-LEDS
-Kenwood KFC-1665S 6-1/2" 2-Way Speakers (Front)
-PIONEER DEH-X6500BT
-Cobb Tuning Shift Knob
-OEM 6MT Shift Knob
-OEM 6MT Red Shift knob
-AEM 30-4110 DIGITAL WIDEBAND UEGO CONTROLLER AIR FUEL RATIO BOSCH 4.9LSU
-AEM Oil Pressure X-Series 100 Psi
-Defi Sti Genome Boost gauge
Engine & Drivetrain:
-JDM EJ205 AVCS (Big Port T20 Ver8-Ver9 EJ207 Head Castings)
-STI 08-14 Top Mount Intercooler
-TGV's Deleted
-Ported EJ205 Intake Manifold
-Custom DrivenFab MidPipe 3" to 2.5"
-Apexi Megaphone Dunk Muffler
-Kartboy 15mm Extended hangers
-Tomei Turbo Inlet
-Tomei Intercooler Elbow
-Killer B EJ25 Pickup
-Killer B Windage Tray
-06+ STI Oil Pan
-Cobb XLE BPV
-GrimmSpeed 38mm EWG Up pipe with Screamer pipe
-GrimmSpeed 38mm EWG Block off
-GrimmSpeed (Red) Bypass valve hose
-Invidia Catless Downpipe
-iWire merged with AVCS EJ205/EJ207 V7, With TGV Delete)
-WALBRO 255LPH FUEL PUMP
-Prova 1.3 Bar Cap
-JDM STI V7 6MT
-JDM R180 3.9
-JDM Driveshafts
-USDM Automatic Tail shaft
-Snorkus Delete
-Goodridge Stainless Steel Clutch Line Kit Clear 04-05 Subaru Impreza WRX STI
-Poly Front Shifter (stay) bushing
-Kartboy Rear Shifter Bushing
-TiC Ver7 Pivot Linkage Shifter Bushings
-Kartboy Subframe bushings
-Karboy Rear Outrigger Bushings
-JDM Grounding kit (Zerosports or syms?)
Suspension & Brakes:
-Fortune Auto 500 Coilovers 8K Front - 6K Rear - Radial Bearings
-JDM SUBARU LEGACY BG5 BD5 STI CARBON FRONT STRUT TOWER BAR
-JDM Cusco Rear Sturt Tower Brace Carbon Fiber
-JDM Cusco Rear Diff/Subframe Brace
-JDM Mines Lower Arm Bar/Brace
-JDM Garage Dog House Roof brace
-JDM Do-Luck Back Seat Floor brace
-JDM BG5 Cusco Rear sway bar
-Group N Sti Pinch mount
-Group N Sti Transmisson mount
-GrimmSpeed Master Cylinder Brace
-Kartboy Front Endlinks
-EBC Rotors (Rear)
-StopTech Pads (Rear)
-Goodridge G-Stop Stainless Steel Brake Line Kit 90-01 Subaru Impreza Legacy
-225/45ZR-17 BFGoodrich g-Force Sport COMP-2
-2004 STI BBS Wheels (Bronze)
-Whiteline Front Lower Inner Rear Control Arm Bushing & Bracket Subaru (W53515)
-BE5 STI Alloy Control arms
-94 Turbo Legacy Cross Member
-94 Turbo Legacy Steering Rack
-94 Turbo Legacy Sway Bar 18mm (Repainted)
-Whiteline KSR202 Steering Rack Bushings
Pictures before I even bought it
Here it is today
TylerHartman is offline   Reply With Quote
Old 02-11-2016, 03:44 PM   #2
TylerHartman
Member#: 307597
1999 Legacy GT
Video of it running. LOLOLOLOL
https://youtu.be/WpTP8Eu33U4
The big dent I get to pay to get fixed YAY!
Old 02-11-2016, 03:44 PM   #3
TylerHartman
Member#: 307597
1999 Legacy GT
ONE OWNER, Till now
Old 02-11-2016, 03:44 PM   #4
TylerHartman
Member#: 307597
1999 Legacy GT
It's so pretty <3
- - - Updated - - -
- - - Updated - - -
Test fitted the JDM Side Markers
Got my new STI Key
Old 02-11-2016, 03:45 PM   #5
TylerHartman
Member#: 307597
1999 Legacy GT
Found some Trash under the rear seat and trunk area
Found tons of dirt
Installed my Zero/Sports Cover (isn't as good as it was pictured, But I'll work with it)
Old 02-11-2016, 03:45 PM   #6
TylerHartman
Member#: 307597
1999 Legacy GT
GC8 Hood Dampers/Struts
Threw on my Old JDM Plates and My New Hella Horns
Removed the AWD Badge off My Trunk
Pulled one of the Plugs for fun
Old 02-11-2016, 03:45 PM   #7
TylerHartman
Member#: 307597
1999 Legacy GT
Carbon Fiber Brace on <3
Led Plate Bulbs
Old 02-11-2016, 03:45 PM   #8
TylerHartman
Member#: 307597
1999 Legacy GT
Well my JDM lights showed up, The center part got broken Been sad all day.
Momo Red stitched wheel came in
Leds in the door and over headlights.
My goodies, Sadly the center garnish is busted Anybody have an extra? Paypal ready :/
I'll update more once my pictures upload
Old 02-11-2016, 03:46 PM   #9
TylerHartman
Member#: 307597
1999 Legacy GT
Well I've been quite busy grabbing parts so here's what I've got
-WALBRO 255LPH FUEL PUMP Subaru Impreza WRX STi EJ25 RS w/ Install Kit 400-791
-AEM 30-4110 DIGITAL WIDEBAND UEGO CONTROLLER AIR FUEL RATIO KIT NEW BOSCH 4.9LSU
-04 SUBARU IMPREZA WRX WAGON CHASSIS BODY INTERIOR BULK WIRING HARNESS
- OEM Genuine Honda 76720-S9V-A01 Windshield Wiper Arm
-JDM SUBARU LEGACY BG BD PROJECTOR HEAD LIGHTS
-Subaru Impreza WRX 2.0L Turbo Intake Manifold Collector Aluminum EJ205 Oem 02-05
-JDM RFRB Door Trims, JDM Climate Control, JDM Climate Control Trim/Vents, JDM Inside door Handles, JDM Door sills (Some Dings but okay shape to use), and JDM Spats but need some work (Cracking and wrong color)
-JDM Grille L7
-JDM Cusco under body Brace
Old 02-11-2016, 03:46 PM   #10
TylerHartman
Member#: 307597
1999 Legacy GT
Here's one little lot of stuff I got
Here's the grille in with Stock Lights
Door sills
Old 02-11-2016, 03:46 PM   #11
TylerHartman
Member#: 307597
1999 Legacy GT
Old 02-11-2016, 04:31 PM   #12
DumbstixLars
Member#: 205942
2003 WRX,00 2.5RS
2007 2.5i, 04 STI, 99 OBS
Nice, I really like those Wagons.
DumbstixLars is offline   Reply With Quote
Old 02-11-2016, 04:54 PM   #13
Abarrett
Member#: 364238
2003 WRX
MBP
Nice wagon man. Lucky to find one that clean. Can't wait to see the updates. Subscribed
Abarrett is offline   Reply With Quote
Old 03-05-2016, 10:13 PM   #14
TylerHartman
Member#: 307597
1999 Legacy GT
Thanks guys! More updates soon
Old 03-06-2016, 09:56 PM   #15
jmh_nyc
Member#: 442015
Wow, nice one! Can't wait to see how it turns out
jmh_nyc is offline   Reply With Quote
Old 03-07-2016, 12:40 PM   #16
slow_celica_gts
Member#: 442050
2003 Celica GTS
Man I love wagons This is gonna look killer when it is complete
slow_celica_gts is offline   Reply With Quote
Old 11-23-2016, 01:24 PM   #17
TylerHartman
Member#: 307597
1999 Legacy GT
Junkyard finds
Old 11-23-2016, 01:26 PM   #18
TylerHartman
Member#: 307597
1999 Legacy GT
New Shift knob
Needs a bath bad, and Dent Removal Kit
Old 11-23-2016, 01:27 PM   #19
TylerHartman
Member#: 307597
1999 Legacy GT
Old 11-23-2016, 01:27 PM   #20
TylerHartman
Member#: 307597
1999 Legacy GT
V8 STI Seats
Old 11-23-2016, 01:27 PM   #21
TylerHartman
Member#: 307597
1999 Legacy GT
Old 11-23-2016, 01:28 PM   #22
TylerHartman
Member#: 307597
1999 Legacy GT
Ready to ship my wiring into iWire
Old 11-23-2016, 01:28 PM   #23
TylerHartman
Member#: 307597
1999 Legacy GT
Grabbed a few pictures after I took my Wiring harness out
Old 11-23-2016, 01:28 PM   #24
TylerHartman
Member#: 307597
1999 Legacy GT
This will hopefully be in next week
Old 11-23-2016, 01:29 PM   #25
TylerHartman
Member#: 307597
1999 Legacy GT
Hint of what is in store next
