#1 |
Member#: 412965
![]() Hey all,
I recently took the plunge and got a new 20 WRX base. Been playing with it recently and one thing I couldn't figure out is how to get the map lights to turn on when you open the door because the dome light alone leaves the front seat area super dark. From looking through the manual, I think I may have what they're calling the "type b" map lights based on the tiny, gray-scale pictures. The manual doesn't say anything about whether or not they turn on when the doors are opened (where-as it does get into that for type a and type c lights, of course), so I'm starting to think that they are actually "working as designed". But if that's true, I'm just dumbfounded as to how a nearly $30k car could not have a simple feature that all of my past, MUCH cheaper, cars all had. Am I crazy? And yeah, I know one way to solve this would have been to get the premium over the base, but it was honestly a stretch to make this one happen, and I didn't care about any of the major selling points of the premium over the base. As silly as it sounds, if they told me about THIS I probably would've considered it lol. Anyway, if anyone has any knowledge on this subject I'd love to hear it. I'd love to hear if I'm wrong and I'm just missing something obvious. If I'm right though, I'd also be willing to swap out my map light kit with a different one but I've never really heard of anyone doing that so not sure how involved it would be if it's even realistic. But any advice there would be awesome too. Thanks in advance if anyone has anything to share. Have a good one.
#2 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
![]() I downloaded the manual and it is lacking to say the least.
Regardless, Type-A appears to be with sunroof and manual 6-speed, Type-B appears to be without sunroof and without EyeSight, and Type-C appears to be with EyeSight option. |
#3 | |
Member#: 507317
Vehicle:2019 WRX Pure Red |
![]() Quote:
Yes, your center dome light should come on when you unlock the car with the key fob or open your door. The LED light, in the Pop Pkg, is somewhat dim, from what I can tell in mine, but it provides enough light to see what I'm doing. Others may prefer to install a brighter LED bulb in the dome light to make it more "daylight" or change the color to red to be more night vision friendly. Worst case, call or visit the dealer and see if they can give you the five minutes to figure out the issue. Question, what position is your dimmer switch set to? Full bright, full dim, or somewhere in between. Mine is set to 2-clicks down from full bright and my dome light turns on. Do your map lights pop on when you push them? > Forgot to mention...have you gone into the menu section of the top screen to sort through all of the options. I cannot recall, but I think there is a section in there about dome lights and duration. I know you can set the duration the backup camera stays on after you move out of reverse. Mine is set at 5 seconds, and I believe you can go as long as 9 seconds on the camera Last edited by GoFrogs; 01-20-2020 at 03:45 AM. Reason: driver's menu |
#4 | |
Member#: 412965
![]() Quote:
I still find that hard to believe on a $28k car, but I can't find any reliable source anywhere that claims they should work and even my dealer wasn't sure and just said to drop off the car so they can check it out. I like your suggestion of just dropping by and seeing if they can let me talk to a tech for 5 mins though because I think they're just going to tell me I'm SOL and shoulda got the premium lol. My last resort would be to somehow replace parts with one of the other map light types that do tie-in with the door sensors. But again, not sure how realistic that is. I'm not looking for a wiring nightmare, but it does REALLY bug me how dark it is at night when you open the door. I totally agree with all of your rationale about the base vs premium though which is why I was originally happy with my decision. It's literally just this ONE thing that's killing me :P |
#5 |
Member#: 412965
![]() Hey, thanks for checking me on that. That is my assumption as well. And that's why I'm hesitant to just replace my type b with either a type a or c as I don't have those associated options, so even if it worked, I'd be left with functionless buttons lol.
#6 |
Member#: 383899
Vehicle:2014 WRX Hatch Plasma Blue |
![]() I just upgraded today from a ***8216;14 hatchback and I too am dumbfounded by the inability to activate the map lights when the doors open...
Instructions indicate how to do it for Type A and Type C... but us Type B's have been literally left in the dark when our doors open. Any work around? Last edited by Tonyfastin; 02-18-2020 at 10:30 PM. Reason: Typo |
#7 |
Member#: 488048
TXIC
Vehicle:2019 WRX DGM |
![]() It might be an option only for the Limited trim.
When I grab the handle and/or unlock with the remote, my interior map lights and dome light all come on. Mine is a '19 Limited. |
#8 |
Member#: 493782
Vehicle:2020 WRX |
![]() Just chiming in my 2020 premium trim. The map lights don't come on when the doors are open and there is no way to make them trigger when the door is open. By the way I have the performance package with the sunroof delete is that makes it any different.
