Welcome to the North American Subaru Impreza Owners Club Wednesday April 8, 2020
Old 07-15-2008, 02:05 PM   #176
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
quick question, does meth chemically bond with the h20 when you mix it? Im using faucet (brita) water and 100% VP meth, will the methanol sink to the bottom of the tank because its a heavier mixture? Or do they bind together?
Thank you,
Jeff
j255c is offline   Reply With Quote
Old 07-21-2008, 08:43 AM   #177
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Thank you,
Jeff
Researching, I have heard that the meth will absorb the water, or something to that effect over time.
DP
DonkeyPunch is offline   Reply With Quote
Old 07-21-2008, 06:47 PM   #178
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Thank you,
Jeff
once mixed the methanol will be inseparable from the h2o by anything short of distillation. the two will never stratify.
Old 01-10-2009, 07:46 PM   #179
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
The link to the freeze temp chart at Ashland Chemical is broken.
Here is the new link there.
http://162.128.70.44:8080/cs.html?ch...vioc&n=1&la=en
It's a PDF.
Buck
bucket7788 is offline   Reply With Quote
Old 01-11-2009, 01:59 PM   #180
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
It's a PDF.
Buck
Thanks a lot. I'll fix it.
-Andy
Old 01-18-2009, 01:47 PM   #181
wrx_dryver
Member#: 153230
02 WRX
so i am running about 350hp on stock internals and i wanted to instal the meth kit. will this put too much pressure on my pistons and rings and what not. or will i be safe with it
wrx_dryver is offline   Reply With Quote
Old 01-18-2009, 05:19 PM   #182
bcblues
Member#: 17256
18 Outback
on the road....
It depends on how you tune for it. If you just use it as a knock preventative and don'ttune to the ragged edge you will be no worse off, and probably better off than you are now. Knock destroys moremotors than anything else, IMHO.
bcblues is offline   Reply With Quote
Old 01-18-2009, 09:50 PM   #183
wrx_dryver
Member#: 153230
02 WRX
well i am gettin an accessport and im gonna download a tune for the meth inj. jus wanted to see if i was going to need to upgrade my internals which i didnt wanna do. but i dont want to put my cars life at risk either
Old 01-18-2009, 10:09 PM   #184
LaptopBrent
Member#: 112731
2006 WRX
Uhh I am sure there is no downloadable tunes for meth injection. You will need to get a custom tune.
LaptopBrent is offline   Reply With Quote
Old 01-19-2009, 10:33 AM   #185
Rodwrx23
Member#: 170948
What could be causing the ecu to initially pull timing when the water/meth starts spraying? Wrong mixture? I'm running a 50/50 mix of Heet/distilled water. While tuning and logging, I've noticed the timing drop to as low as 12 degrees when is starts to spray.
Rodwrx23 is offline   Reply With Quote
Old 01-19-2009, 10:55 AM   #186
bucket7788
Member#: 124263
2004 WRX Wagon
I doubt that it's pulling timing because of the meth/water. Either your fueling is off or you are calling for too much timing.
What kind of controller are you using to control spray? What is the set point to start spraying?
Do you have a log with (at least) RPM, Load, Boost, AFR, Total Timing, FBKC and FLKC?
Old 01-19-2009, 11:18 AM   #187
Rodwrx23
Member#: 170948
I'm using the UTEC in SD mode. Prior to spray, my fuel and timing was perfect. I road tuned the car myself and got everything exactly where I wanted it. Here's a log of a run made with my 18psi SD map that was completely dialed in. I didn't make any changes to it when I added the meth into the equation just to see where I was at. This was with the gain set to 8 on my var-cool controller and I'm running a 500cc nozzle which is placed just after the BPV and before the TB on my cold side FMIC pipe.
Code:
                    Load Knock                     Mod   Map         Mod   WB
 RPM   MAP  MAF TPS Site Count  AFR  Ign#1  Inj#1  Ign    VE  Boost  MAF   AFR
       psig  V   %                    deg   duty   deg    %   (PID)   V
 2699  +3.7 2.7 101  20    00   W/B  +32.2   15.8 +33.7  91   WGS.   2.5  12.30
 2725  +3.7 2.7 101  20    00   W/B  +31.7   16.5 +33.7  91   WGS.   2.6  12.33
 2773  +4.1 2.7 101  20    00   W/B  +31.9   17.0 +33.2  92   WGS.   2.6  12.30
 2861  +4.3 2.9 101  20    00   W/B  +31.5   18.1 +32.6  94   WGS.   2.6  12.33
 2886  +4.5 2.9 101  20    00   W/B  +30.8   18.8 +32.0  95   WGS.   2.7  12.42
 2957  +4.9 2.8 101  20    00   W/B  +30.4   19.9 +31.0  97   WGS.   2.7  12.45
 3003  +5.1 2.9 101  20    00   W/B  +29.7   20.9 +30.6  97   WGS.   2.7  12.39
 3077  +5.5 2.8 101  30    00   W/B  +29.4   21.4 +30.0  96   WGS.   2.8  12.25
 3159  +5.9 2.9 101  30    00   W/B  +29.7   22.1 +29.9  95   WGS.   2.8  12.06
 3211  +6.3 2.9 101  30    00   W/B  +29.7   22.7 +29.2  93   WGS.   2.9  11.96
 3267  +6.5 3.0 101  30    00   W/B  +30.4   23.6 +28.9  93   WGS.   2.9  11.89
 3316  +6.9 3.0 101  30    00   W/B  +30.2   24.3 +28.5  92   WGS.   2.8  11.77
 3432  +7.2 3.0 101  30    00   W/B  +29.7   24.8 +28.2  93   WGS.   2.9  11.61
 3450  +7.6 3.0 101  30    00   W/B  +29.7   25.5 +27.6  90   WGS.   3.0  11.42
 3512  +8.0 3.1 101  30    00   W/B  +29.7   26.4 +27.4  90   WGS.   3.0  11.23
 3591  +8.6 3.1 101  40    00   W/B  +29.1   27.9 +26.5  90   WGS.   3.0  11.17
 3663  +8.8 3.2 101  40    00   W/B  +27.2   29.5 +25.5  90   WGS.   3.2  11.23
 3796  +9.8 3.2 101  40    00   W/B  +25.4   31.6 +23.9  90   WGS.   3.2  11.37
 3844 +10.8 3.4 101  40    00   W/B  +24.0   34.8 +21.8  89    55.60 3.3  11.42
 3930 +11.8 3.5 101  50    00   W/B  +23.0   36.7 +20.9  89    54.90 3.3  11.20
 3996 +13.1 3.5 101  60    00   W/B  +21.1   40.0 +20.0  89    53.90 3.3  11.06
 4089 +14.3 3.5 101  60    00   W/B  +19.3   42.9 +19.6  89    52.70 3.4  10.93
 4156 +15.9 3.7 101  60    00   W/B  +17.4   46.7 +19.5  89    51.80 3.5  10.86
 4235 +17.4 3.9 101  70    00   W/B  +10.4   50.3 +20.1  90    36.80 3.7  10.86
 4409 +19.0 4.0 101  80    00   W/B   +9.6   55.1 +19.0  90    35.30 3.8  10.96
 4510 +19.8 4.0 101  80    00   W/B  +10.9   56.9 +18.8  90    32.60 3.7  11.11
 4591 +18.0 3.9 101  80    00   W/B  +12.8   55.8 +20.5  90    28.40 3.6  11.12
 4721 +16.7 3.9 101  70    00   W/B  +14.4   54.7 +20.9  91    30.60 3.7  11.11
 4945 +16.9 4.0 100  70    00   W/B  +16.5   55.2 +19.4  91    31.40 3.7  11.11
 5035 +17.8 4.0 101  70    00   W/B   +9.6   61.4 +19.5  91    36.30 3.8  11.11
 5136 +18.2 4.0 101  80    00   W/B  +10.8   61.7 +20.1  91    36.00 3.9  11.17
 5341 +17.8 4.0 101  80    00   W/B  +11.1   64.2 +21.1  92    36.70 3.9  11.20
 5367 +16.5 4.0 100  70    00   W/B  +12.2   63.2 +21.3  93    38.10 3.9  11.27
 5464 +16.9 4.1 101  70    00   W/B  +11.4   67.4 +21.0  94    39.20 3.9  11.28
 5717 +17.4 4.2 101  70    00   W/B  +11.7   68.7 +21.0  95    39.70 4.0  11.24
 5630 +17.1 4.2 101  70    00   W/B  +11.9   69.5 +21.0  96    40.60 3.9  11.30
 5899 +16.7 4.2 101  70    00   W/B  +12.4   69.6 +21.0  95    42.10 4.0  11.33
 5899 +16.7 4.1 101  70    00   W/B  +12.7   72.9 +21.0  98    43.90 4.0  11.24
 6093 +16.7 4.2 100  70    00   W/B  +11.1   73.8 +21.0  97    45.10 4.0  11.12
 6071 +16.9 4.2 100  70    00   W/B  +10.6   73.1 +21.5  98    46.50 4.0  11.01
 6349 +16.7 4.2 100  70    00   W/B  +10.9   77.5 +21.3  97    48.10 4.0  10.96
 6337 +17.1 4.3 100  70    00   W/B  +12.7   80.5 +21.6  98    47.90 4.0  10.96
 6253 +16.5 4.3 100  70    00   W/B  +13.3   82.9 +21.7  98    49.10 4.1  10.96
 6523 +16.9 4.3 100  70    00   W/B  +13.6   80.3 +21.6  98    50.20 4.1  10.90
 6548 +17.1 4.3 100  70    00   W/B  +14.1   83.3 +21.6  99    50.80 4.1  10.87
 6802 +16.7 4.3 100  70    00   W/B  +14.4   83.4 +21.3  97    52.70 4.1  10.86
 6887 +16.9 4.3 100  70    00   W/B  +14.9   84.2 +21.5  98    53.90 4.1  10.81
 6802 +17.8 4.3 100  70    00   W/B  +14.6   88.1 +21.8 100    53.70 4.1  10.73
 6901 +18.0 4.4  63  80    00   W/B  +15.0   89.2 +21.1  95    36.60 4.0  10.76
 7092  -8.1 2.2   0  10    00   W/B  +10.5   21.1 +22.0  92   LCM.   1.7  11.80
 5707  +8.2 3.6 101  30    00   W/B  +26.7   46.2 +24.2  93   WGS.   3.9  13.12
 4997 +14.9 4.0 101  60    00   W/B  +12.3   57.8 +19.3  93    38.60 3.9  13.39
 5058 +19.2 4.1 101  80    00   W/B  +10.2   64.9 +19.4  92    34.70 4.0  12.46
 5112 +19.8 4.0 101  80    00   W/B   +8.1   65.4 +19.3  92    32.30 3.8  11.33
 5104 +17.4 4.0  96  70    00   W/B  +11.7   59.8 +20.0  92    14.70 3.7  11.20
 5224  -6.7 2.1   0  10    00   W/B   +8.9   16.7 +21.7  92      .00 1.9  11.14
 5065  -9.6 1.4   0  10    00   W/B  +11.2   12.8 +10.1  92      .00 1.3  12.11
As you can see, there is no perceived knock by the UTEC, but I fully understand that I should ideally be monitoring FBKC and FLKC via Tactrix which I don't have right now. I gotta take my girl to IKEA right now to "look at stuff" so I'll log on my way there. I appreciate the help.
Old 01-19-2009, 12:44 PM   #188
bucket7788
Member#: 124263
2004 WRX Wagon
If your tune was dialed in and you made no changes except for spray, I'm stumped.
A question about the Vari Cool controller. From what I've read, you set the min and max boost pressure with the left and right dial. The center dial is the gain, which you set at 8. Just throwing random numbers, if you set the left (min) dial to 12psi and the right (max) to 18, what the center dial does is set the duty cycle of the pump at max flow? So in your case, it would be at 80% duty cycle at max flow?
What are your min and max settings?
Buck
ETA:
Which HEET are you using?
Old 01-19-2009, 02:50 PM   #189
Rodwrx23
Member#: 170948
I have the controller min @ 10psi and max @ 21psi. I'm using the yellow Heet, not the red Iso Heet. Here are some logs from last night w/ the gain @ 7. Seemed to improve a little bit.
Code:
 2574  -7.7 1.6  32  00    00   W/B  +11.7    8.2 ECU.   90      .00 2.8  11.43
 2602  +0.0 1.6  72  00    00   W/B  +19.5   12.7 +19.5  90      .00 2.6  11.65
 2552  +1.0 2.8 103  10    00   W/B  +33.6   12.6 +36.0  90    63.20 2.5  12.37
 2590  +1.7 2.7 103  10    00   W/B  +30.7   14.4 +35.2  90    63.00 2.5  14.92
 2808  +1.9 2.6 103  10    00   W/B  +32.3   15.1 +34.8  90    62.70 2.6  16.11
 2761  +2.3 2.7 103  10    00   W/B  +32.2   15.3 +34.3  90    62.20 2.6  14.18
 2805  +2.9 2.8 103  10    00   W/B  +29.5   16.4 +33.5  90    61.90 2.7  13.62
 2906  +3.3 2.8 103  20    00   W/B  +28.5   17.3 +32.8  92    61.60 2.7  13.42
 2960  +3.7 2.8 103  20    00   W/B  +27.4   18.0 +32.3  94    61.20 2.8  13.42
 3022  +4.1 2.8 103  20    00   W/B  +27.0   19.7 +31.4  96    60.90 2.8  13.47
 3052  +4.7 2.9 103  20    00   W/B  +27.0   20.3 +30.6  96    60.40 2.8  13.17
 3121  +5.1 2.9 103  20    00   W/B  +27.0   20.8 +30.4  93    60.30 2.8  12.74
 3192  +5.3 2.9 103  30    00   W/B  +27.0   21.5 +29.9  91    73.90 2.8  12.46
 3252  +5.7 3.0 103  30    00   W/B  +26.5   22.0 +29.3  92    84.60 2.8  12.39
 3330  +5.9 3.0 103  30    00   W/B  +26.6   23.3 +29.1  93    84.30 2.9  12.39
 3418  +6.5 3.1 103  30    00   W/B  +26.2   24.0 +28.5  92    84.20 2.9  12.25
 3454  +6.8 3.1 103  30    00   W/B  +26.2   24.2 +28.2  90    83.80 3.0  12.00
 3512  +7.4 3.2 103  30    00   W/B  +25.5   25.9 +27.6  90    83.40 3.0  11.77
 3588  +7.8 3.2 103  40    00   W/B  +26.9   26.9 +26.8  90    83.00 3.0  11.68
 3683  +8.6 3.2 102  40    00   W/B  +25.2   29.2 +25.2  90    82.30 3.2  11.68
 3766  +9.6 3.4 102  40    00   W/B  +23.0   31.6 +23.3  90    81.70 3.2  11.73
 3894 +10.4 3.5 102  50    00   W/B  +21.3   34.2 +21.5  89    80.90 3.3  11.71
 3944 +11.6 3.5 102  50    00   W/B  +20.4   37.4 +20.8  89    79.70 3.3  11.53
 4045 +13.3 3.6 102  60    00   W/B  +18.5   41.1 +19.9  89    78.70 3.4  11.39
 4089 +14.3 3.6 102  60    00   W/B  +16.0   43.7 +19.6  89    77.40 3.6  11.23
 4224 +16.3 3.7 101  70    00   W/B  +14.4   48.5 +19.8  90    61.20 3.7  11.11
 4268 +18.6 3.9 102  80    00   W/B  +13.4   52.6 +19.0  91    58.80 3.7  10.99
 4450 +20.8 4.1 102  90    00   W/B  +11.8   61.3 +16.5  95    56.40 3.9  10.95
 4597 +22.5 4.2 101 100    00   W/B  +12.3   69.4 +15.1 100    47.10 3.9  10.87
 4728 +22.1 4.1 101  90    00   W/B  +14.2   67.2 +16.3  97    42.60 3.8  10.52
 4923 +21.0 4.1 101  90    00   W/B  +16.2   68.5 +17.8  95    44.50 3.9  10.23
 4967 +21.0 4.1 101  90    00   W/B  +16.8   71.6 +19.0  95    41.90 3.9  10.29
 5104 +21.0 4.1 101  90    00   W/B  +17.2   70.3 +19.0  95    38.40 3.9  10.36
 5232 +20.6 4.1 101  90    00   W/B  +17.2   69.8 +19.0  95    41.00 4.0  10.40
 5376 +20.6 4.2 101  90    00   W/B  +18.1   73.2 +19.0  95    38.70 4.0  10.43
 5509 +20.0 4.2 101  90    00   W/B  +18.6   74.1 +19.2  95    36.10 4.0  10.48
 5630 +20.0 4.3 101  90    00   W/B  +19.2   74.0 +20.3  95    34.50 4.0  10.55
 5767 +19.6 4.3 101  80    00   W/B  +19.6   77.8 +21.0  95    33.30 4.1  10.65
 5698 +19.8 4.3 101  80    00   W/B  +19.5   78.1 +21.0  96    33.50 4.1  10.68
 5847 +19.0 4.3 101  80    00   W/B  +20.7   81.4 +21.0  98    31.90 4.1  10.67
 5899 +18.8 4.3 101  80    00   W/B  +21.1   82.7 +21.0 101    30.70 4.1  10.58
 6172 +19.0 4.3 101  80    00   W/B  +21.3   83.2 +21.2 101    30.40 4.1  10.52
 6242 +18.6 4.3 101  80    00   W/B  +21.4   84.6 +21.7 101    29.80 4.1  10.45
 6349 +18.6 4.3 101  80    00   W/B  +24.2   86.5 +21.7 101    29.20 4.2  10.43
 6265 +18.6 4.3 101  80    00   W/B  +24.6   85.8 +21.7 101    28.70 4.1  10.43
 6666 +18.6 4.3 101  80    00   W/B  +25.6   88.9 +21.7 101    28.30 4.1  10.46
 6447 +18.6 4.4 101  80    00   W/B  +25.4   87.4 +21.8 101    27.90 4.1  10.48
 6747 +17.4 4.3  44  80    00   W/B  +25.9   81.3 +21.0  93     6.80 4.1  10.46
 5984  -6.7 2.1   0  10    00   W/B  +10.9   20.1 +22.0  92      .00 2.0  10.73
 5640  +8.0 3.9 102  40    00   W/B  +16.2   46.2 +23.5  93    46.80 3.9  11.92
 4734 +14.7 4.0 101  60    00   W/B  +17.6   52.3 +20.7  92    36.30 3.9  12.59
 4823 +19.6 4.1 101  80    00   W/B  +13.1   62.8 +19.0  91    36.30 4.0  11.62
 4859 +21.6 4.1 101  90    00   W/B  +14.7   69.7 +18.1  97    33.10 3.9  10.95
 4967 +20.8 4.0 101  90    00   W/B  +16.8   66.6 +18.8  95    30.80 3.9  10.68
 4990 +20.6 4.1 101  90    00   W/B  +17.4   68.2 +19.0  94    28.30 3.9  10.55
 5073 +20.2 4.1 101  90    00   W/B  +17.7   68.5 +19.0  93    25.90 4.0  10.55
 5192 +20.2 4.1 101  90    00   W/B  +18.0   70.4 +19.0  94    25.90 4.0  10.52
 5167 +19.8 4.2 101  90    00   W/B  +18.0   67.3 +19.0  94    28.30 4.0  10.48
 5249 +20.0 4.2 101  90    00   W/B  +18.3   69.5 +19.4  93    26.20 4.0  10.48
 5299 +20.2 4.2 101  90    00   W/B  +18.2   69.2 +19.3  93    24.00 4.0  10.49
 5341 +20.0 4.2 101  90    00   W/B  +18.3   70.7 +19.3  93    21.60 4.0  10.52
 5274 +20.0 4.2 101  80    00   W/B  +18.6   68.4 +19.3  94    19.70 4.0  10.55
 5509 +19.8 4.2 101  80    00   W/B  +19.0   72.8 +19.4  94    17.70 4.0  10.56
I then took this map and added a degree of timing up top and took out some fuel as well. At quick glance today AFR's were around 11.2-11.5's from 5k and up.
Old 07-24-2009, 10:01 AM   #190
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I think It's interesting to see in posts 97 & 98 that power on water/meth injection was lost initially around 4000 RPM (compared to peak on pump gas), then regained and increased above 5000 RPM. Why would there be a loss in power? Is the tune not right, is the amount of spray too much for the boost and AFR at that point?
Anyway, I would love to run water/meth injection but I am concerned about blowing my very expensive fresh built motor...
What are the options out there for having my ECU switch to a conservative map automatically when the level in the water/meth tank run low for added protection?
Will an Accessport be able to do this?
What other ECU options are there for water/meth injection (hydra, motec, etc.) and what advantages does one have over another?
If I run my car at a track all day where I would be in boost often, what is the ideal water/meth tank size to hold enough fluid to account for each tank of fuel if the fuel tank capacity is 15.9 gal.?
What are my options for water/meth tanks, who makes them, and where can I buy them?
Thanks in advance.
chrisarella is offline   Reply With Quote
Old 07-24-2009, 10:17 AM   #191
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Size "Big"
At least 3 gallons
jblaine is offline   Reply With Quote
Old 07-24-2009, 12:21 PM   #192
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Thanks in advance.
You can run water meth on just about any engine management you can tune with. I run Accessport 2, and this the most stable tune I have had yet. I have ran meth on open source, and UTEC previous. Accessport was way better for quality of tune, and the same tuner tuned all the other types I have used. Most of the water/meth system makers produce some sort of tanks for their system. Mounting or finding space to mount becomes the issue. You can't mount a big system under the hood tank wise. I would say what would work best would be the STi spec C 13L tank, and say that if you go to the track, to bring extra juice already pre mixed. Get a 5 gallon race gas container (can be bought through summit, jegs etc.) and keep some mixed and ready to go for when you come in between sessions. As far as switching on the fly, I don't think accessport can do it without shutting the engine off. So you are kinda hosed on that. UTEC can swtich on the fly though. You just have to throw the clutch in let the RPMS drop below 1000, switch the map with the remote switch, and then let the clutch out. But you would also have to tune for that more consevative map. If I were going to do this I would make wire my meth system controller so I could power it off from a swtich, so it doesn's kick on while on that "conservative map" Hope all this helps. If you have more questions ask.
-Andy
Old 07-24-2009, 03:18 PM   #193
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I've had a UTEC and was not happy with it. I have OpenECU now and was looking to go with something more feature-rich and advanced like an AP2 or Hydra, but want some sort of integrated safeguard in the ECU like Snow Performance's SafeInjection which drops boost pressure and cuts ignition timing advance:
http://www.snowperformance.net/product.php?pk=13
As far as tanks go, I have a wagon and would need to fab up a bracket for the Spec C tank. Since I'd need to make something anyway I am not restricted and can pretty much use anything I want.
With a little searching I found the following companies making reservoirs:
USPC: http://www.usplastic.com
Alcohol Injection Systems: http://www.alcoholinjectionsystems.com
Devil's Own: http://www.alcohol-injection.com
5 Gallon Black Multi Purpose Tank (10-1/4” H x 15” W x 8-1/2” D) for $24.55:
They have other containers as well ranging from standard washer tanks to petrol-safe containers for fuel and oil, like this 2.5 Gallon Tank (7.75” x 12.75” x 7.75”) for $21.73:
or even go for something more extreme like this 6 Gallon Fuel Tank with 1/4" Brass Fitting (18" L x 14" W x 12" H) for $72.09:
^^^ There is a 12 gallon option for a few bucks more as well, and both can come with or without the fitting.
AIS makes this 6 Gallon Water Alcohol / Methanol Tank With Pump Mount (15" L x 12" W x 8" H) for $89.99:
Here is a link to all of their tank options:
http://www.alcoholinjectionsystems.c...c39/index.html
From what I can tell, Devil's own has the same tank options as AIS here:
http://www.alcohol-injection.com/tan...7e558086a70785
I'm sure there are more but this is what Google came up with in a quick search.
Note: the pictures are link to their associated pages on the sites.
Old 07-28-2009, 11:57 AM   #194
SprintA3
Member#: 218446
Very nice info in here. This stuff is great to see coming from the VW / Audi community where W/M injection is seen as "new technology that no one understands".
SprintA3 is offline   Reply With Quote
Old 07-29-2009, 10:00 PM   #195
05BoostinSubie
Member#: 206209
05 WRX
I ordered a Coolingmist CMGS kit yesterday and plan on running 50/50 (Denatured Alchohol/Distilled Water).
As far as this setup, except from the "steam cleaning" effect from the alchohol, what would be the pros of running methanol in leu of alchohol?
05BoostinSubie is offline   Reply With Quote
Old 08-09-2009, 10:57 AM   #196
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
As always thanks for the order. Its generally believed that Methanol has a higher octane rating. I have read estimates as high as 118-120. Methanol is likely less expensive as well depending on where you buy it. Denatured alchohol in general is easier to get.
Thanks again.
CM
Coolingmist is offline   Reply With Quote
Old 08-11-2009, 08:10 AM   #197
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
meth evaporates faster and has more oxygen.
Old 08-11-2009, 09:58 PM   #198
Dak Jones
Member#: 220149
2004 Subaru WRX STI
WRC Blue
Please help. I have a SMC methanol injection system installed on my 2004 sti. Everything has always worked fine untill i took it to a mechanic to have a new ACT 6 puck clutch kit and new light weight flywhee installed. The garge i went to was recomended by a guy i know that has multiple high performance, highly modified cars.
I went for a ride after the install to break in the new clutch and found that the car felt under powered compaired to usual. The car makes 454 whp spraying meth. I noticed that the indicator light on the dash control module that let you know that the system is armed was lit as it should be but at 10 PSI the system should spray but does not. No spray at all. The mechanic said that all he did with the electrical system was pull the batery. I checked the ground wires for the meth pump, they were fine. I am really upset about this. I worked fine when i took it to this guy. I just noticed it today and the mechanics shop is closed so i havent had a chance to bring the car back to the shop. I reset my map with my access port to the 26 psi + meth map because the ECU had reset after they pulled the battary. Can anyone help me? I tried the spay test and got nothing.
Dak Jones is offline   Reply With Quote
Old 08-11-2009, 10:33 PM   #199
Disaster646
Member#: 135382
2013 Gtr
Gunmetal
if ur meth controller is boost based.. then check for the feed boost line for the controller.. even tho ur mechanic only unplugged the battery.. im sure he had to remove ur intercooler.. of if u have a fmic.. he still had to remove the pipin.. plus ur bov vac lines.. thats where most ppl put the T connection for the meth controller.. .. it seems like ur controller is on.. and has power.. but its not reading boost to be activated... how's ur boost?? or does ur bov sounds different?
Disaster646 is offline   Reply With Quote
Old 08-30-2009, 03:13 AM   #200
AlfaShoppy
Member#: 222072
2003 Alfa Romeo 156
Thanks for all the info.
Here in The Netherlands w/m injection is relativity 'new'.
So I was forced to read all the info in English hihi.
I myself am driving a Alfa Romeo 156 1.9JTDm 16v with massimo chiptuning from Squadra and I am experimenting with the standard set of Coolingmist for the small diesel.
Again much thanks for all the info it was really helpfull.
AlfaShoppy is offline   Reply With Quote
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 08:01 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 06:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 05:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 04:51 PM
