04-01-2013, 10:54 PM | #3026 |
Member#: 169257
Vehicle:00 rsti & 04 fxt millenium jade |
No worries it's easy, shouldn't take more than 2.5-3hrs for a first time if you take it slow and easy.
04-01-2013, 11:16 PM | #3027 |
Member#: 282086
Vehicle:2003 wrx blue |
So far so good. Got the radiator out and intercooler pulled off. Taking lots of pics as I go too so I can make sure it all goes back together right. Lol
04-01-2013, 11:24 PM | #3028 |
Member#: 169257
Also there is a diy with picts on rs25 I believe it was posted by Joshua, its not a turbo but besides the ic and exhaust it is the same basic process. I used it for my first time and made it pretty nice.
04-01-2013, 11:41 PM | #3029 |
Member#: 282086
Ya. I found pretty detailed thread here on nasioc as well. Tons of pics. Using it for reference too
04-02-2013, 12:42 AM | #3030 |
Member#: 267266
Vehicle:'20 VAF, P8Y '00 SF9, 64C |
So does anyone have any ideas for a second April meet, now that the weather is getting better? Dates? Places?
04-02-2013, 12:51 AM | #3031 |
Member#: 46500
Vehicle:So many I can't remember anymore. |
The trickiest part about subies that's a bit diff from many other cars is the separation of the trans and motor (specifically the release bearing and lock pin). It'll be covered in the DIY's, simple but important.
04-02-2013, 01:04 AM | #3032 |
Member#: 282086
Ya I read that. Hopefully it's not to bad to deal with.
04-02-2013, 01:06 AM | #3033 |
Member#: 282086
04-02-2013, 01:17 AM | #3034 |
Member#: 267266
04-02-2013, 01:40 AM | #3035 |
Member#: 282086
Boo!!! Lol
04-02-2013, 09:48 PM | #3036 |
Member#: 282086
so, turns out pretty sure all that was wrong with my car the whole time was a bad idler puller or something.... i pulled one of the covers to the cam gears and found bearing matierial and metal inside the plastic cover... would explain why it wasnt really knocking, but more of a scratchy chatter.... to bad i already had the entire motor pulled and half way disassembled before i decided to take that cover off... could have had it fixed along time ago.... ugh!!! such is life... i may just get some new pulleys and timing belt and slap it back together for the time being. i miss driving it! haha.
04-02-2013, 11:33 PM | #3037 |
Member#: 212731
Did you already order all the parts for the build?
04-03-2013, 12:09 AM | #3038 |
Member#: 282086
i've got most of what i need. just a few more little things, (bearings, oil pan, oil pickup, clutch) and just need funds for machining heads and block.
decided i've waited this long, i can hold out a little longer. really dont wanna have to pull all this crap a second time. lol. check out what i found when I pulled the timing belt covers! cute huh!? |
04-03-2013, 12:14 AM | #3039 |
Member#: 257636
Vehicle:05 STi Aspen White |
Looks like I won't be able to sell that "lightly used timing belt" this time around
04-03-2013, 12:21 AM | #3040 |
Member#: 169257
Depending on what clearances you are shooting for and what your rods & crank spec out to I had ordered King xpg (new redesign that is supposed to help with subaru's bearing issues) in +.001 for extra oil that are to loose for my stuff after polishing the crank and resizing the rods with the arp bolts.
04-03-2013, 12:35 AM | #3041 |
Member#: 282086
04-03-2013, 12:39 AM | #3042 | |
Member#: 282086
that's my main thing, i have no clue what clearances to shoot for. Should i wait til after i send the block, crank and rods to the machine shop to figure that out??? I'm a little clueless when it comes to that stuff. from what i've read, the tighter the clearances, the better, right? are you trying to say you arent gonna use the bearings you have? cuz if you arent, and they work for my set up i may take em from you... i was wanting to get kings anyways, that or clevites. |
04-03-2013, 01:05 AM | #3043 |
Member#: 169257
Yes that is what I am saying.
It's a range really, if you are to tight it will cause friction & heat and destroy your bearings and maybe crank/rods. If you are to loose your bearings will not have proper crush and you will spin a bearing. According to most of my reading and talking with Dom at MPS you do not want more than .002 on your rods and not less than around .0015. For the mains, you don't really want much more than .0015 and I am not sure of a minimum. Are you going to have your crank polished/anything done to the big end of the rod or are they just boring the cylinders? If they aren't touching that stuff you can measure now, if they are you should wait till it's done(that was my mistake). |
04-03-2013, 01:26 AM | #3044 |
Member#: 282086
Here.s my question. . . Should I have anything done to the rods and crank? They are both used, but look to be in good shape.
04-03-2013, 01:05 PM | #3045 |
Member#: 282086
So is that panda express thing going on tonight?
Who wants to help swap motor from my civic to my crx??? |
04-03-2013, 01:51 PM | #3046 |
Member#: 169257
The panda exp. thing is that one of the management classes at isu is raising $ for make a wish foundation as a project and panda has agreed to donate a percentage of all sales tonight from 6-9 so everyone who can should go eat some Panda. My class did it last semester and we raised enough to send a local girl to disney world. I won't be able to go though because I have a test in my finance class at.the same time :-(
04-03-2013, 01:55 PM | #3047 |
Member#: 266010
Vehicle:'07 Leggy SpecB gray |
Hmm. .. wonder if if panda is doing thathere too. Had a couple of siblings that got wishes granted throb Make AWish.
04-03-2013, 03:46 PM | #3048 |
Member#: 267266
04-03-2013, 03:54 PM | #3049 |
Member#: 282086
Photography??? Hmmm. . . Well I'll prob head to panda too then. Anyone else going?
04-04-2013, 12:48 AM | #3050 | |
Member#: 267266
Similar Threads | ||||
Eastern Idaho owners(or any ID really) Check-In!!! Local Get-togethers?? | neko | North West Impreza Club Forum -- NWIC | 386 | 05-12-2010 06:01 PM |
Tuners in Northern Wyoming/Eastern Idaho? | bryancregger | Rocky Mountains Impreza Club Forum -- RMIC | 3 | 01-06-2010 11:05 AM |
NWIC - Official "I saw it on Craigslist" Thread | Dena | North West Impreza Club Forum -- NWIC | 4 | 11-02-2008 10:19 PM |
