Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2024
Old 08-07-2007, 01:03 PM   #1
edvc520
Member#: 71908
04 WRX
Default will a v8 sti gauge cluster work on an 04 auto WRX?
will a v8 sti gauge cluster work on an 04 auto WRX/RS?
my friend is looking to install a v8 cluster on his auto...
will it work?
edvc520 is offline   Reply With Quote
Old 08-08-2007, 05:44 PM   #2
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
Well, which is it?
Anyway, this is a powertrain forum. There's another forum dedicated to electrical stuff 12 below this one, and another on conversions (engine swap stuff). Both are more likely to have better info than this one.
Old 08-08-2007, 06:20 PM   #3
sc00ter
Member#: 117767
2014 Audi S4
DP Stage 2 (~420whp)
I know the '04 WRX/RS 5 speed will both plug right into a V8 STI cluster. However, I don't think it will work with an automatic because the wiring for an automatic cluster also allows you to see if you are in Neutral, Drive, Reverse, etc.
sc00ter is offline   Reply With Quote
Old 08-09-2007, 08:52 AM   #4
wagons_ho!
Member#: 16574
Default Why do people do this?
"I don't think" isn't a yes, or a no. Just someone's belief. If you don't know, for 100 percent positively sure, don't say "I don't think."
Yes. An automatic will work with a STi cluster. Hell, if you get one with the DCCD display, the DCCD lights even work in order.. but there's no light for P.
I know. I've done it. I had to rewire a plug pin to get the alarm light to blink, but everything else works. R and N are yellow, the rest are green.
A non-DCCD cluster doesn't give you the PRNDLL.
A DCCD cluster will give you RNDLL.
Easy peezy.
wagons_ho! is offline   Reply With Quote
Old 08-09-2007, 10:49 AM   #5
edvc520
Member#: 71908
04 WRX
hey.. thank you for ur response on my inquiry.
yes, my friend is looking to buy one that has DCCD to put on his 04 Auto.
so, do u mean i only need to clip the B28 wire and it's good to go on an Auto?
because i own a WRX, i have a STI gauge cluster on, all i need to do is clip the B28 wire.
thanks for ur help in advance.
Old 08-09-2007, 06:50 PM   #6
thetrev8588
Member#: 112158
2004 WRX Wagon GGA
Bright Aspen White
yes it will work. my friend did it on his 94 auto wrx from an STi, o5 i belive, and where the DCCD lights are works as his gear ****f indicator, not sure how he wired it up.
thetrev8588 is offline   Reply With Quote
Will an 06 sti gauge cluster fit in a 04 wrx? subiewrx001 Electrical & Lighting 3 11-09-2008 09:03 PM
will an 06 STI gauge cluster fit in a 04 wrx? subiewrx001 Interior & Exterior Modification 1 11-09-2008 04:46 PM
will STI gauge cluster work on an auto RS? edvc520 Electrical & Lighting 0 08-07-2007 01:43 AM
will 04/05 sti gauge cluster work in 03 wrx soobieajax325 Interior & Exterior Modification 8 10-19-2005 06:50 AM
can 04 STI gauge cluster fit into an 04 wrx? DieselClown Interior & Exterior Modification 5 10-16-2003 01:47 PM
