Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2024
Mid Atlantic Impreza Club
Old 12-20-2004, 02:56 PM   #1
rogue
Member#: 7977
100% Abuse
Subaru Stars It's cold outside... welcome to raw fuel smell!
per this thread: http://forums.nasioc.com/forums/showthread.php?t=131755
I got a nice strong fuel smell today, even after the car was warmed up.
Paul Brothers Subaru in Herndon told me "yeah, we've gotten a lot of calls about that this morning, it happens when the car is cold, don't worry about it. And it's just a TSB, so even if that's it it'd be your cost to fix it."
I worry about fuel leaking into my engine bay, right above my uppipe. But that's just me.
Anyone else getting this issue, call your local dealership, and let's not take any crap on this. Leaking fuel is not a minor issue, SOA should be fixing this on affected vehicles, and your dealership should be making every effort to get your car in. If you find otherwise, report it to SOA (800) SUBARU3
-rogue
rogue is offline   Reply With Quote
Old 12-20-2004, 03:01 PM   #2
lowkey
Member#: 17518
2002 wrx
I got the heavy fuel smell only after my car had been warmed up and driven about 5 miles this morning. I tried to get it fixed last year, but was told they couldn't reproduce the smell .
I won't have the time to get it fixed for another month, though, so if it's cold, I'm going to smell like gas.
lowkey is offline   Reply With Quote
Old 12-20-2004, 03:05 PM   #3
rogue
Member#: 7977
100% Abuse
I can live with smelling like stuff... but I don't want my engine to kersplode
I'm not a warranty hog... I never went in for the clutch shudder or anything like that, but dammit this could be dangerous
Old 12-20-2004, 03:13 PM   #4
saint_foo
Member#: 64364
Yeah, my car smells like it's running rich.
saint_foo is offline   Reply With Quote
Old 12-20-2004, 03:22 PM   #5
meshuggah
Member#: 8578
I had that problem, after I did injectors and fuel rails, it obviously went away. Not a cheap way to fix that problem, but I wonder if there is a do it yourself way to fix the stock fuel rails to prevent the smell.
--Geoff
meshuggah is offline   Reply With Quote
Old 12-20-2004, 04:01 PM   #6
lowkey
Member#: 17518
2002 wrx
I agree. It should clearly be a warranty repair and likely a recall. I really don't want my car to go up in flames, either, although the high from the fumes is alright when I'm stuck in traffic.
However, short of Subaru sending techs to my garage at work right now, I don't have time to get it fixed. If it does blow up, I'll be in a rental pretty quick.
Old 12-20-2004, 04:02 PM   #7
Endlesshine
Member#: 19598
1998 Honda CR-V
Sold the LGT
It's a very common problem with the '02/'03 WRX'es and I can't believe they STILL won't fix it!! They'll fix that stupid Cruise Control clip but they wont fix a fuel leak. WTH??
Haven't noticed anything in the LGT :lifts nose at leaky WRX'es:
-Ron
Endlesshine is offline   Reply With Quote
Old 12-20-2004, 04:10 PM   #8
Soon2bSubbieowner
Member#: 21812
2011 Mazda2
My 05 smelt like lovely brand newness.
-Rob
Soon2bSubbieowner is offline   Reply With Quote
Old 12-20-2004, 04:14 PM   #9
psyber_0ptix
Member#: 60671
1972 Datsun 240z
LS3 w/ Jenvey ITB
HUM, i dont know if its the same, but i was trying to inspect a potnential coolant leak when all of the sudden, BAM i kicked it up a notcha nd smelled pure gasolene from somewhere near the upper coolant tank by the turbo. is this what you were referring to?
i was afraid one of my injectors inseated itself and was spewing fumes (maybe even lowering compression in a cylinder?)
if this is normal, then i guess i wont sweat it. i sniffed my exhaust thinking it was just cold gas fumes condensing inside the pipes in such a cold day and making it smell, but that wasnt it.
what is this phenomenon?
psyber_0ptix is offline   Reply With Quote
Old 12-20-2004, 04:17 PM   #10
rogue
Member#: 7977
100% Abuse
You've got the WRX engine in there, right?
The phenomenon is a fuel rail hooked up to a rubber hose on the passenger side of the engine, under the manifold, above the engine, just to the inside of where the manifold hits the cylinder nearest the turbo. See the thread linked above for a picture.
Old 12-20-2004, 04:42 PM   #11
psyber_0ptix
Member#: 60671
1972 Datsun 240z
LS3 w/ Jenvey ITB
AH CRAP, that kind alooks like a pain to fix... (unless its up top?)
Old 12-20-2004, 05:11 PM   #12
Siper2
Member#: 1134
2015 Outback H-6
-Rob
I miss that.
Even a thorough vacuum and Vinylex/Lexol job won't restore it. Heh!
Siper2 is offline   Reply With Quote
Old 12-20-2004, 05:26 PM   #13
M
Member#: 4470
2002 Subaru WRX
Blaze Yellow
i had the same smell this morning as well. Never had it till today.
M is offline   Reply With Quote
Old 12-20-2004, 05:33 PM   #14
rogue
Member#: 7977
100% Abuse
call your dealership, schedule to get it looked at.
I'm also getting my cruise control recall done at the same time.
Old 12-20-2004, 05:45 PM   #15
psyber_0ptix
Member#: 60671
1972 Datsun 240z
LS3 w/ Jenvey ITB
i doubt the stealership would even look at my car as its not stock :\
anyone wanna help me take my manifold off? :P
Old 12-20-2004, 06:00 PM   #16
RayO
Member#: 42329
2002 WRX sedan
I had the fuel smell once last year in my 2002 WRX. I read the TSB here, and decided to try to get my dealer to fix it.
At first, they mentioned my mileage. I said it seemed to be an emissions/safety issue, and they then agreed.
While they were fixing it, I had them put in my inlet pipe at no charge, since the manifold needs to come off to do the TSB work.
It pays to be polite and have all of your facts before going to the dealer. Their first response is almost always "NO", but they will work with you in many cases.
RayO is offline   Reply With Quote
Old 12-20-2004, 06:10 PM   #17
psyber_0ptix
Member#: 60671
1972 Datsun 240z
LS3 w/ Jenvey ITB
even if you have a 1999l with wrx motor and aftermarket turbo/exhaust
Old 12-20-2004, 08:04 PM   #18
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
My car always smells of gas, ever since my new fuel pump went in. You get used to it after a month or so.
Tur1smoWRX is offline   Reply With Quote
Old 12-20-2004, 10:21 PM   #19
WRX11
Member#: 26638
-Ron
It's cheaper to paid someone when their cars burn down and they lose in court.
WRX11 is offline   Reply With Quote
Old 12-20-2004, 10:36 PM   #20
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I don't have a 2002 WRX anymore so I am no longer having this problem, but I urge you all who have this problem to complain to the NHTSA!!
if you don't all do this, you'll stand very little chance of a solution ever being provided free of charge.
nhluhr is offline   Reply With Quote
Old 12-20-2004, 11:03 PM   #21
M
Member#: 4470
2002 Subaru WRX
Blaze Yellow
I'm going to go over in person ot the dealer tommorow to arrange to have this fixed as well as my seat recall/ TSB.
Old 01-19-2005, 07:45 AM   #22
mklier1218
Member#: 23889
ot mods
are weaksauce
bump
Well I have this prob now. Where did you all go to get it fixed and did you have to pay for it? I have an 02 with 67,000 miles. I tightened two of the clamps, and will find out this morning if it leaks or not.
mklier1218 is offline   Reply With Quote
Old 01-19-2005, 08:05 AM   #23
rautox
Member#: 68573
98 Italkart F125
I took 4 trips yesterday.
Trip one, warmed car up for 5-10 minutes before driving to work. No smell.
Trip two, didn't warm car up before rollin' across the base. Strong smell.
Trip three, warmed car up for 5 and grabbed some lunch. No smell.
Trip four, intentionally didn't warm car up more than a minute. Some smell.
I'll be warmin' my car up carefully today, and hopefully get a chance at those clamps tonight.
rautox is offline   Reply With Quote
Old 01-19-2005, 08:14 AM   #24
SilverBoosted
Member#: 7764
16 Jeep Renegade
Its Trailrated Yo
The raw fuel smell problem is why I no longer own my PSM baby... Subaru said "tough cookies its $650 to fix" I told them F*#k You and traded it in.... No issues with my Jeep in 22k miles cant say the same for the great Japanese quality... 2 batteries, 2 radiators, 3 sets of rotors and pads, clutch assy, wheel bearing plus many other issues in the 3 yrs I owned the car.......
SilverBoosted is offline   Reply With Quote
Old 01-19-2005, 08:57 AM   #25
rogue
Member#: 7977
100% Abuse
I never got it fixed, but it would have been on my dime to do it.
How did you guys tighten the clamps? Those things are WAY down burried under the intake manifold!
I'm gonna replace the fuel lines down there with longer rubber and double-clamp them at some point, but for now I'll just warm it up.
Raw Fuel Smell Log fluffybunny Warranty Issues & SOA Problems 3411 01-10-2021 06:16 PM
Raw Fuel Smell/Leaking Fuel Line on WRX pumpkyn Rocky Mountains Impreza Club Forum -- RMIC 40 10-01-2020 07:48 AM
Raw Fuel Smell Inside Cabin - WRX Kenneth2000 Warranty Issues & SOA Problems 13 12-21-2012 11:28 PM
02 WRX slow to start/raw fuel smell tobylazur Service & Maintenance 4 05-21-2009 03:15 AM
Raw fuel smell/leak when cold, where did Chicago ppl get theres fixed? MF-DIF Mid West Subaru Owners Club Forum -- MWSOC 74 02-14-2009 06:24 PM
