Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2024
Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 02-19-2006, 06:04 PM   #1
WrexFactor36
Member#: 63700
2002 PSM WRX 4EAT
Protuned Stage 2
Default Fuel Smell In Cabin (02 Wrx)
Any Experiencing Any Fuel Smell Today Inside The Cabin As Result Of Cold Or Wet Weather? I Thought I Smelled Fresh Fuel Inside My Car, Just Curious, Thanx
WrexFactor36 is offline   Reply With Quote
Old 02-19-2006, 06:06 PM   #2
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
It's a problem with the 02's in teh cold. The dealership was fixing these for free...
djerickd is offline   Reply With Quote
Old 02-19-2006, 06:15 PM   #3
WrexFactor36
Member#: 63700
2002 PSM WRX 4EAT
Protuned Stage 2
hopefully mine is still covered, anyone else having this problem?
Old 02-19-2006, 06:21 PM   #4
qingshan
Member#: 81322
12/6 Sti/Fo
swp/CGM
I think they would fix it for free even if out of warantee - too much liability otherwise
qingshan is offline   Reply With Quote
Old 02-19-2006, 06:21 PM   #5
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Try the appropriate forum...you may have better response.
US2JDM is offline   Reply With Quote
Old 02-19-2006, 06:38 PM   #6
teiva-boy
Member#: 22825
teiva-boy is offline   Reply With Quote
Old 02-19-2006, 07:38 PM   #7
chri3
Member#: 16245
My car smells of gas inside.
:fart:
:sneeze:
chri3 is offline   Reply With Quote
Old 02-19-2006, 09:16 PM   #8
zaarin
Member#: 95404
2002 WRX Wagon
What color is bird crap?
I think this problem they will fix even if you are out of warranty, as long as the involved parts are still stock, because it was a recall type of issue, a known flaw across the entire 02/03 WRX line, rather than a part that might brake but usually doesn't. SoA actually got involved in this, so call them if the dealership gives you crap about it.
This is caused by fuel lines to the engine that become loose in the cold. If that isn't the problem, I have no idea how to help you.
Good luck.
zaarin is offline   Reply With Quote
Old 02-19-2006, 09:52 PM   #9
XmanSTi
Member#: 65206
1986 Brat
Red
I had this fuel smell issue on my 02 when I lived in Buffalo NY. I have never heard of the problem in temps over ~20deg F. If you are smelling it in SoCal temps then you likely have a much more serious issue than I've ever heard of related to the TSB issue.
Did you replace your fuel pump and not get a good seal between the cover and tank? Step in a bit of fuel at the filling station? overfill? Lots of reasons for fuel smell. Too many to cover online...
XmanSTi is offline   Reply With Quote
Old 02-19-2006, 10:06 PM   #10
codemunky
Member#: 1804
Maybe a leak on your breather line.
codemunky is offline   Reply With Quote
Old 02-19-2006, 10:45 PM   #11
zaarin
Member#: 95404
2002 WRX Wagon
I had it once, but only once, on a very cold day, but only once and it was a very cold day. I don't know if it was 20F or not, but it was a very cold day. Did I mention it was a very cold day? Because it totally was. A very cold day.
SoCal includes desert regions that dip below 20F regularly. Just ask the Lancaster folks!
Old 02-20-2006, 06:17 PM   #12
Arnie
Member#: 1725
2002 Subaru Forester
SG silver
I'm getting it right now. I just moved up to about 3200ft so it snowed this past weekend and sub 32 degree temps at night. My car's never been in temps this cold till now. Smelly, smelly, smelly. Need to call the dealer and see if they are willing to do anything about it, i.e. I have STi V8 short block and V7 red intake manifold, DP, but all the hoses, fuel lines are all stock.
Arnie is offline   Reply With Quote
Old 02-20-2006, 06:56 PM   #13
zaarin
Member#: 95404
2002 WRX Wagon
Even if it isn't covered under the warranty or recall thingie (which it really ought to be since we're talking about a factory-original fuel leak, which is potentially extremely dangerous) it should be pretty cheap to get fixed, because from what I read in the other threads on this issue it's just a couple of clamps they need to tighten down enough that they won't come loose anymore with temperature changes.
Old 02-20-2006, 11:03 PM   #14
Arnie
Member#: 1725
SG silver
steve - its not the clamps, I believe the hose is too short (new one is 30mm loner than old one). There are two parts (the hose prt# 807707140 and a pipe prt. # 17544AA134) that need to be replaced by the dealer and supposedly necessitates a full intake manifold removal. I'll just order up the parts and do it myself some weekend. Can't be bothered to take it to the dealer. so that means Festiva in the morning, Wagon in the afternoon till it warms up.
Old 02-21-2006, 02:48 AM   #15
WrexFactor36
Member#: 63700
2002 PSM WRX 4EAT
Protuned Stage 2
Arnie is correct, this is what happened to my ride, they needed to replace a hose and a small pipe, and it does involve taking the intake manifold apart, since they're doing that, gonna go ahead and replace the turbo inlet hose also with a perrin unit, i knew i smelled something, it will cost around the $600 mark for labor and parts, mainly labor.
Fuel smell in cabin when turning on heater AlanTheWoo Service & Maintenance 2 03-07-2008 03:15 PM
Need Help For Raw Fuel Smell in Cabin roburXunitas South East Region Forum 6 01-04-2008 06:43 PM
Raw fuel smell in cabin Wade-O Normally Aspirated Powertrain 16 03-10-2007 04:26 PM
Fuel smell in cabin...... WRBlueMeanie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-05-2006 04:36 PM
need help - fuel smell in cabin and engine bay nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-06-2002 08:38 PM
