Welcome to the North American Subaru Impreza Owners Club Monday January 22, 2018
Old 07-03-2016, 02:44 PM   #401
Danny9447537
Member#: 429189
So which part number is the correct one for the 15+ Base STI without the auto on/off feature? Trying to source the correct one since there's two LED headlights listed with one being $20 more.
Danny9447537 is offline   Reply With Quote
Old 09-09-2016, 02:46 PM   #402
tturbocar
Member#: 453263
2015 wrx
its the same thing i did when i had a genesis coupe r-spec version. swapped in the lights from the track model and boom they worked! just had to manually adjust the lights since the car was in a wreck but other then that easy!
tturbocar is offline   Reply With Quote
Old 09-29-2016, 02:22 PM   #403
bunz559
Member#: 388585
2015 wrx base
ISM
I haven't followed the thread in a long time. Seems like there's been a lot of info discovered since last year now that used headlights are becoming more available.
I am looking to swap out to WRX limited headlights soon here. Just to be sure, they're a complete plug and play swap. Is there auto leveling features on the limited wrx headlights that I must worry about? If there is, I can still use them and manually adjust correct? The swap will not set off a light on my dash will it?
Thanks!
bunz559 is offline   Reply With Quote
Old 09-29-2016, 05:45 PM   #404
Bubakanush
Member#: 209975
2016 WRX
LBP
I just replaced my base/premium headlights with the LIMITED/STI headlights this past weekend. You can still manually adjust the headlights; there is a white colored screw that controls the adjustments. It's very easy to access even once the headlights are installed.
Yes, they are 100% plug and play. It's nice to not have any extra wires running through the engine bay that an HID kit requires.
No check engine lights/dash lights or codes show up. These lights are good to go once you plug them in. No issues at all!
Bubakanush is offline   Reply With Quote
Old 09-29-2016, 06:43 PM   #405
bunz559
Member#: 388585
2015 wrx base
ISM
Thanks! Just went back and read 17 pages worth of info. But I appreciate your confirmation.
Old 11-20-2016, 10:55 PM   #406
Black17base
Member#: 458495
Default Progress?
[quote=black06;43968171]I am trying to do the whole led swap with the leveling system. I purchased the main front harness, the dash switch, the headlight ecu and the rear level sensor.... It wasn't cheap... The dash switch doesn't match the plug, and I can't find a plug for the headlight ecu, it's supposed to be behind the fuse panel on the driver side.. I removed the fuse panel and the relay panel and, nothing. Also can't find the plug for the rear sensor. The only diagram I was able to find shows that it y's off the rear diff temp sensor, I'm pretty sure my wrx doesn't have a rear differential temp sensor (sti only?)
Any help is appreciated [/QUOTE
Just swapped out my base Sti halogens for the limited headlights off a local club racer who is going to drill large holes in my old lights. I'd like to know about any snags you have run into.
Black17base is offline   Reply With Quote
Old 01-05-2017, 01:31 PM   #407
snowdrift06
Member#: 158604
2016 WRX Premium
Has anyone found a retailer selling these units for less than $1500?
snowdrift06 is offline   Reply With Quote
Old 01-08-2017, 10:20 AM   #408
evilWagon
Member#: 128739
For the sake of anyone considering dropping their money on this; the IHS rates the LEDs worse even than the Halogens. Moderate for Halogens, poor for LEDs.
http://www.iihs.org/iihs/ratings/veh...x-4-door-sedan
This is for the 2015-2017, I'm betting the redesigned 2018 lights will be much better.
evilWagon is offline   Reply With Quote
Old 01-13-2017, 04:06 PM   #409
frederik
Member#: 64405
2018 STi
Maybe I did not read that correctly but what I see in that link is they say the LED are medium and halogen are poor, isn't it?
frederik is offline   Reply With Quote
Old 01-13-2017, 06:33 PM   #410
vladd
Member#: 158185
17 WRX
CWP
I'm seeing marginal for the STI headlights, with poor for the base WRX headlights. Poor is worse than marginal, according to their guide.
http://www.subaruautomotiveparts.com...83702&comment= comes out to $1346.22 with shipping for me. They had free shipping not too long ago, and it was $1305 back then.
I considered buying the LED headlights, until I realized that HIDs were better, and cheaper. A complete HID kit with mounting bracket for the projector, as well as an LED C-light, is less than $500 in parts. The install seems pretty straight-forward, with a bunch of good videos out there on how it's done.
vladd is offline   Reply With Quote
Old 01-24-2017, 03:26 PM   #411
Yoshi99
Member#: 423391
2017 WRX
CWP
I have a 2017 WRX premium and would like to pick up a set of the limited headlights. Has the part # changed for my particular model? Looks like it's 84002VA041 and 84002VA051.
Yoshi99 is offline   Reply With Quote
Old 02-22-2017, 12:58 AM   #412
ChewinDC
Member#: 440246
2016 WRX Limited
Crystal White Pearl
You are correct. The person that posted earlier is wrong.
ChewinDC is offline   Reply With Quote
Old 02-22-2017, 03:53 PM   #413
cyralax
Member#: 425154
2016 WRX Sport
Lapis Blue Pearl
Interesting results from the IIHS. I thought the led projectors are quite good, slightly shocked to see that they are ranked that low.
Also, went and took a look at the headlight results for the new gen Corolla, I'm shocked that they didn't fail it on the glare test.
cyralax is offline   Reply With Quote
Old 05-02-2017, 10:35 PM   #414
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
The LED low-beam lamps are fine, except for illuminating the side of the road as stated by the IIHS.
The left side is not illuminated properly when taking a curve and the right side is only slightly better illuminated versus left side illumination when taking a curve.
Adaptive headlamps will be in place in future models.
So, what does this mean?
Slow down, use the high-beams, or add auxiliary lamps.
Old 05-13-2017, 02:17 AM   #415
J168
Member#: 461992
These will work. I ordered them for 2017 wrx.
J168 is offline   Reply With Quote
Old 08-22-2017, 08:52 AM   #416
ZacT
Member#: 451920
2017 WRX Limited
World Rally Blue
Originally Posted by Squattro View Post
Quoted for the photo.
Did anyone ever sort out the orange wire at pin 6 on the limited/sti?
I am actually doing this backwards and putting premium lights on my limited. The plan is to retrofit them with HID projectors. I just want to be sure that I wont lose my auto-on.
From the photo the orange wire appears to go through the grommet with the other wires associated with auto-LEVELING. I feel like it may have something to do with sensor feedback of the leveling unit.
I feel like auto on shouldn't have anything to do with a small orange wire at the housing, but I have been wrong plenty of times before...
~Zac
ZacT is offline   Reply With Quote
Old 08-22-2017, 12:29 PM   #417
Squattro
Member#: 357064
2015 Subaru WRX
GBP
~Zac
You will have problems going from LED housing to the base version, even after your HID retrofit. The wiring harness for the LED is rated a lot lower because of the lower wattage of LEDs versus the halogen housings having a higher gauge wire in the harness.
There are a few instances of a dash light coming up when you do this or a disable light from users on this forum and over at IWSTI. I can find the links if needed.
Squattro is offline   Reply With Quote
Old 08-22-2017, 02:26 PM   #418
ZacT
Member#: 451920
2017 WRX Limited
World Rally Blue
Hmm... interesting. I will take whatever you have as far as information on the issue goes. Surely there must be a way to get it working, wouldn't a relay harness take care of it? That way the factory harness would only be serving as a trigger. Perhaps my logic is off...
~Zac
Old 08-22-2017, 03:56 PM   #419
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
You are correct.
CRAZYHAWK is offline   Reply With Quote
Old 08-22-2017, 05:13 PM   #420
Infinite0180
Member#: 410716
2016 WRX
CBS
~Zac
Your logic is correct, just use a quality relay harness to bypass any factory wiring. I swapped my base halogens for the led limited and when i flipped through the 2015 service manual it looked as if pin 6 was part of the auto beam leveler system. I would imagine in your case you will see 2 different lights on your dash, one for headlight malfunction and another for auto beam leveler malfunction. If you can deal with seeing those lights everyday then you will probably be fine... kind of like the tpms light when you put a set of wheels on without it... just my guess though... you could always unplug your headlights and see what lights show up on the dash then decide from there what you want to do...
Infinite0180 is online now   Reply With Quote
Old 09-13-2017, 07:52 PM   #421
6042018wrx
Member#: 469302
Default 2018 Base wrx
Hey guys might be off topic.
I have a 2018 Base wrx.
Might be able to source oem 2015 LED headlamp assemblies. I know they physically fit but not sure if the connectors have changed.
Would it still be plug and play?
6042018wrx is offline   Reply With Quote
Old 01-09-2018, 05:22 PM   #422
Originate
Member#: 360984
2017 WRX
CWP
Default BIU failure?
I am considering upgrading my 2017 base WRX with the limited headlights but have read of someone expressing concern about BIU failure. Have any of you that have been running your lights for a while now had any issues?
Originate is offline   Reply With Quote
Old 01-09-2018, 06:14 PM   #423
Infinite0180
Member#: 410716
2016 WRX
CBS
Been running mine for 6 months or so and have had absolutely no issues. I dont think i have even read a single report of a BIU issue with the oem led lights. Maybe what your thinking about is the issues people have had when running the cheapo Chinese plug and play leds that end up frying out. The oem headlights are perfectly safe to swap out as long as you aim them properly after you made the switch in my opinion. All your doing is supplying power and ground to the light just like the halogens. I went through the wiring diagrams in the factory service manual before i did the swap just to be sure. The only thing different in the limited is the wiring for the auto leveling feature and one other wire which i believe is their to tell the car when the led headlight has an issue. Obviously those features wont work when installing them in the base/premium models so you just need to make sure you inspect the functionality of the led lights from time to time. But all in all im very happy with them, they look soo much better than the chrome ones too!
Old 01-18-2018, 04:30 PM   #424
Civ2Sub311
Member#: 178149
2018 WRX Limited
CWP
FYI I'm selling a set of 2018 WRX Limited LED headlights at the thread URL below. They are wrapped in Xpel and have smoked corner lenses. They were only on my car for about 3.5-4k miles.
If anyone wants to do the R&D and work needed to get them working in a lower/older model, buy em!
https://forums.nasioc.com/forums/showthread.php?t=2863759
Civ2Sub311 is offline   Reply With Quote
