Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 08-24-2017, 01:21 AM   #1
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Default 02-07 rear subframe compatibility?
Hey everyone, I am wondering if all 02-07 Impreza rear subframes are all interchangeable or not. I am planning to replace a bunch of suspension related parts under to 2005 Wrx sedan. Some being used stock peices to clean, paint and replace bushings, some beinng new with new bushings.
The rear subframe is one thing I am looking to replace but not sure if I need a specific rear subframe, or if they are all the exact same in this time span.
Are non turbo impreza rear subframes same as Wrx?
Are wagon rear subframes same as sedan?(just different length lateral links?)
Are Sti rear subframes the same as Wrx?(aside from some sti having metal bushings vs wrx rubber bushings?
Thanks everybody.
4eat05 is offline   Reply With Quote
Old 08-24-2017, 01:24 AM   #2
Dairusire
Member#: 418982
1999 WRX STi Type Ra
555 Blue
Thanks everybody.
You'll find you will have to get either an awd Impreza subframe or a WRX subframe to fit your diff. An sti rear subframe is built to have an R180 rear end, while you have r160. Physically different sizes so.
Dairusire is offline   Reply With Quote
Old 08-24-2017, 09:49 AM   #3
moby4dick
Member#: 51901
'04 WRX
I'm running an R180 in my WRX with the original subframe. So I'd think you'd be fine.
moby4dick is offline   Reply With Quote
Old 08-24-2017, 06:39 PM   #4
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Anyone else have any input on the differences between wrx and sti 02-07 rear subframes (other than rubber vs solid bushings)
Old 08-24-2017, 07:06 PM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
The WRX & STi are all pretty much the same during that time frame. I can't say about the non-turbo subframes.
You can use any year of that group WRX to any year that group WRX and everything should be plug & play.
If you want to swap in an STi subframe, it's really not going to do anything for you except for the solid mounts, and, of course, you will pay more money because it is STi.
If you want to swap in an R180 rear diff into your WRX, it will fit no problem. They are the same overall length and size. The only difference here is you have to be careful to match the rear end diff ratio to your transmission. The rear diff ratios, and the transmission transfer ratio are NOT all the same.
Old 08-24-2017, 10:24 PM   #6
JarHarms
Member#: 138994
06 WRX Ltd
Utter nonsense. Please stop spreading miss-information.
Pretty much this ^
OP, stick to any Impreza rear cross-member from 2002-07 and you will limit any issues. Sedan -vs- wagon does not matter for the actual cross-member. I would not worry too much about the solid mounted STI version, it was only used on 2004-05 STIs USDM. Besides some lock bolts will work just as well in a rubber isolated cross-member.
Old 08-25-2017, 11:40 AM   #7
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
Exactly. I have an R180 in my 2000 OBS with original rear subframe.
RokketRide is offline   Reply With Quote
Old 09-13-2017, 07:33 PM   #8
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Is the same for all 02-07 rear trailing arms? All fit my 05 wrx sedan regardless if sti/wrx/nonturbo/sedan/wagon?
Old 09-14-2017, 07:17 AM   #9
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Help yourself out. Go here:
https://www.subaruparts.com/
Plug in year, make, model of car and look up the part numbers.
