Welcome to the North American Subaru Impreza Owners Club Saturday August 8, 2020
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 04-10-2019, 09:58 PM   #1
SythLordRex
Member#: 18556
Default Car pulls to the right
I have a WRX and I noticed the car pulls slightly to the right. I had a 2018 and it did the same thing. Anyone else experience issues like this?
SythLordRex is offline   Reply With Quote
Old 04-11-2019, 12:39 PM   #2
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Its the alignment or damaged suspension parts.
Several years ago I had to avoid t-boning a big truck that pulled out and came to a dead stop blocking 3 full lanes. Evasive maneuver meant crossing a low curb median at (well above posted) mph. Across the median into incoming traffic then back across the median to correct traffic direction. Bent all 4 BBS but otherwise fine after straightening and alignment.
However when NTB didn't do proper alignment (something loose in the rear) my car would pull right under throttle and had excessive snap oversteer to the right... always to the right. I suggest getting under the car to check every nut, bolt, and bracket. Dealer might be focusing on the front rather than whole car.
imma_stocker is offline   Reply With Quote
Old 04-11-2019, 12:47 PM   #3
SythLordRex
Member#: 18556
If its the suspension, what could it possible be? They checked the control arms, tie rods, wheels, tires. Nothing was out of place or damaged. Wheels are not dented or damaged. I just can't wrap my head around it. I mean could it be a strut or strut mount?
Old 04-11-2019, 04:36 PM   #4
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
1st ALL cars 'veer' to right with manufacture spec alignments
this is to prevent a head on collision if driver falls asleep/has medical blackout
2nd most all roads are banked to right for drainage(any car/truck will pull to right)
3rd if the alignment sheet is all in green your good
however
-the align sheet (the shop should of given you) would use the original/initial align sheet
there should be readings 'before'' and "after" also the red means out of spec green is within tolerance
I could 'read' the sheet for you, but you need to post it
-quick visual test
go to the left front tire
put your fingers/CC/cigarette pack between the tire and dogleg of the fender
the gaps should be very similar
if one side shows the wheel 'pushed' back and the opposite side is not.....its a lower control arm
you can pass an align even if one wheel is 'pushed' back
-when is the last time you rotated your tires?
if all the above fails, jack up the front of your car
swap the LF to the RF and visa versa
then take a drive
betcha $10 your car will now pull to left
(tires not alignment)
I have gone thru this process with 100's of customers after their vehicle in a crash
GL
AliBenn is offline   Reply With Quote
Old 04-11-2019, 04:46 PM   #5
SythLordRex
Member#: 18556
however
-quick visual test
then take a drive
GL
I don't have the colored align sheet with me but it did show based on the specs I posted some were in the Red Before and are now Green.
Since I only have 3500 on the car, tires have not been rotated yet.
Once I get the car back, I will do the "quick visual test"
Thanks for the info.
Old 04-11-2019, 06:12 PM   #6
AliBenn
Member#: 487
Acadia Green RS-T
^^^cool will check back man
if tht visual test looks good....its the tires = easy!
hell go back to the shop tht did the multiple alignmnts.......they should rotate all tires for free! and then gloat tht you solved the issue.
Old 04-12-2019, 02:58 PM   #7
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Another question, which dealer are you using?
Old 04-12-2019, 03:02 PM   #8
SythLordRex
Member#: 18556
Since I know some dealers or their employee's read these forums, I will refrain from stating who it is at this point. There are only a handful or less of Subaru Dealers in the Dallas area.
Does your question about the dealer pertain to the quality of work they might do?
Old 04-16-2019, 01:20 PM   #9
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Yes.
For instance, it has been well known for a long time to see Mario at Gilman SW if you really wanted something done right at a Subaru dealer in Houston. And to see Wally if you need the hook up, even if he couldn't get the hook up you would still leave smiling and laughing.
Old 04-16-2019, 01:24 PM   #10
SythLordRex
Member#: 18556
Yes.
Gotcha.
Well the car is still at the dealer. Still don't know why its pulling. Waiting for a call. Since I am in Dallas, Houston would be a nice little road trip for me. lol
Old 05-01-2019, 07:56 AM   #11
SythLordRex
Member#: 18556
Basically after having my car for almost a month, several alignments later, I get it back and the door panels were scratched in several places, scratch in the paint, they had to redo my wheels because their alignment machine scratched the paint on them multiple times. Unfortunately when they repainted them for the 2nd time, the numb-nut that put the wheel back on wasn't paying attending and removed the newly refinished surface inside the lug nut hole. Idiot.
When I discussed these issues with their Service Director, he said that maybe they were not the dealership for me. When I asked him to elaborate, he said that they provide loaner cars to their customers and they don't come after them for dents, dings or scratches implying that I should turn a blind eye to their crappy way of handling customer cars. He claimed if I continue to bring my car there, this kind of thing is going to happen. WTF?
Old 05-22-2019, 03:05 PM   #12
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
All shops are only as good as their worst tech.
Sounds like they have a management issue...
