Welcome to the North American Subaru Impreza Owners Club Saturday February 23, 2019
Old 09-26-2018, 07:45 PM   #26
AJM1013
Member#: 364469
2009 WRX
Originally Posted by AJM1013 View Post
I purchased directly from their website Oemassive.com. Their customer service is very slow. I sent them a message on facebook today and it was marked "read" shortly after I sent but I have yet to receive a reply. As for the scratches and dust they are both on the inside of the housing. I cleaned the lens really well and you can see the outside surface is almost perfectly smooth and you can tell, more so in person, that the scratches are on the inside of the lens. I'm sure its just bad luck I got 2 damaged products in a row, but it's mainly the poor and slow customer service the reason i'm thinking about just getting a refund. Too bad because in my opinion they are the best looking aftermarket lights out.
So I called their customer service and the told me that they will not be sending me a replacement for the damaged headlight and that they will send me a return slip for a refund. Too bad, they get a 1/5 stars in my book.
AJM1013 is offline   Reply With Quote
Old 09-26-2018, 07:47 PM   #27
Kwincy
Member#: 484052
2011 Impreza WRX
Iím sorry to hear that, it sucks that they wonít work with you for the replacements. You gave them two chances and they effed it up.
Kwincy is offline   Reply With Quote
Old 09-27-2018, 01:48 PM   #28
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info
Ebay code PICKSOON valid today for 15% off, start price is $384.88 - 15% should be $327.14 with code.
darkstarmoto is offline   Reply With Quote
Old 09-27-2018, 02:10 PM   #29
Stretch18
Member#: 239822
2010 WRX
pandiculation
They're less than $300 on amazon, FYI...
Stretch18 is offline   Reply With Quote
Old 09-27-2018, 02:12 PM   #30
Kwincy
Member#: 484052
2011 Impreza WRX
I believe the lights on amazon aren't the ones that have the turn signal integrated with the "DRL" light as these do. They have separate bulbs for the turn signals.
Old 09-27-2018, 02:20 PM   #31
Stretch18
Member#: 239822
2010 WRX
pandiculation
ah, good to know...
Old 09-29-2018, 04:21 PM   #32
Pawel062
Member#: 299305
You guys can also find them for 300 on pro tuning lab. They have pretty good customer service so far from what I can tell because I called them prior to ordering to make sure they are indeed the switchback ones. I have morimoto 2stroke leds in mine and they are as good in output with and distance wise as my oem hids on sti but a bit brighter I think. Let me know if you guys want pics. I have to adjust the beams a bit still and going to disable drl maybe or wire the c lights as leds. I hate how also the c lights are at max with low beams on. Going to try to change them to 50%. Anyone have details on how the stock connector is wired ? Maybe we need to swap some cables around in the connector only.
Pawel062 is offline   Reply With Quote
Old 09-29-2018, 05:16 PM   #33
Kwincy
Member#: 484052
2011 Impreza WRX
Pictures would be awesome, especially since you put Morimotos in them!
Old 09-29-2018, 06:19 PM   #34
mugen_
Member#: 471151
2011 WRX sedan
Dark Gray Metallic
Thanks for the tip on that site! I wasn't thrilled about spending $420 (I just checked, they dropped the price to $385) from OEMassive.
mugen_ is offline   Reply With Quote
Old 09-30-2018, 02:01 AM   #35
Pawel062
Member#: 299305
From what I spoke with the guys on the phone from ProTuningLab there is only 1 company that makes these. So the oemassive and Protuninglab are the same. The guy was very knowledgeable about the product and from why I remember he said they are from spyder.
The fit is oem like. The brackets that go on bottom of the headlights are built in so you donít need to swap them over like non switchback c lights(at least from what I read online). The low beams are h7 while high beams I believe were still 9005 (the bulbs are same looking as stock but I just never read the numbers)
I need to focus the bulbs better and even the beams out since the right side is lower and then I will take some output photos. I used to do retrofits for people so these are pretty damn good output wise when it comes to width, distance, sharpness, and the blue in cutoff. I was debating taking these apart before putting them on but I tested these with halogen bulbs in and was pleasantly surprised on how good they were. For STI guys like me you loose the inside leveling switch. I have my oems though still so I will try to see if I can remove the motors and transfer them over. Also I want to see if thereís a way to disable drls without doing the disconnect the box trick behind the passenger headlight (although I think thatís the only way) and try to make the c lights run at 50% when low beams are on. I will update you guys here if I get any of that done. For now getting low beams adjusted to spec is my priority.
Pics below. Excuse my lack of a grille and fog grilles in some pictures. They are in hydrodipping. Also will post pictures of the projector fogs I have from ijdmtoy with yellow led bulbs soon.
Old 09-30-2018, 05:22 PM   #36
mugen_
Member#: 471151
2011 WRX sedan
Dark Gray Metallic
That's good to know, I've been hearing OEMassive doesn't have very good customer service. So I'm happy there's another vendor.
Please keep us updated, I'm very interested in your results. I have a set of Morimoto projectors that I'm considering retrofitting into them when I get a set of these headlights.
Old 09-30-2018, 08:21 PM   #37
aa2033
Member#: 490388
Out of curiosity, on the bottom of these lights is there a cutout for ballasts or anything? Could we cut out the bottom of the light and mount the OE HID ballast to the housing? I don't want to use an aftermarket HID kit on these.
Alternatively, I may buy these and open them up and do a quad projector set up and replace the low beam projectors with some TL-R's from TRS and put some miniH1's in the high beam.
aa2033 is offline   Reply With Quote
Old 09-30-2018, 09:23 PM   #38
mugen_
Member#: 471151
2011 WRX sedan
Dark Gray Metallic
Just don't use HID's for the high beams. I don't know if flashing HID's on and off can damage the bulbs or ballasts, but it also looks funny when they're dim and flickering, if you ever have to flash your high beams for any reason.
Old 10-28-2018, 05:55 PM   #39
Pawel062
Member#: 299305
There is a cutout for the ballasts like original ones but they use that with a grommet for some of the cabling to come out. You can move that and use the ballasts there though.
I got another set sent over from Protuninglab because the cutoff on the passenger side is blurry. They gave me a full replacement set for that. With that being set I just got a set of projectors and all the supplies so I am going to go ahead and retrofit these. I am debating if I should do some RGBA sequential flowing C lights in these hahha.
With that being said. Does anyone here with this set want my morimoto 2 stroke h7 led bulbs ? They retail for like 120+ shipped Iíll sell them for 110shipped and paypalled. PM me ASAP otherwise I can return these to retrofitsource. I know supplies is still low for them so I figure I can get someone a set faster this way.
Old 10-31-2018, 02:50 PM   #40
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
Satin White Pearl
@mugen_ TL-R and MiniH1 projectors are bixenon so if he's running quads, it'll just be triggering the hi beam solenoids when he fickers the high beam.
JDMSTA is offline   Reply With Quote
Old 11-06-2018, 06:51 PM   #41
jh13wrx
Member#: 466909
Default Great lights although have a few little issues here and there
I recently purchased these lights from the OEMassive website and they have been working no problem. I ended up sticking in aftermarket led lights for both the high beams and low beams. I wasn’t a fan of the DRLs being on when I only wanted the c light part on because it was extremely bright and you couldn’t see the new c light, so I disconnected the daytime running light connector on the passenger side of the car behind the front bumper. The only problems I’ve had with these lights are a bit of condensation here and there which disappears within an hour usually when washing the car if it’s warm out or if there is a temp change between the warm housings and the cooler outside temps and also a slight blinker issue. When turning on a certain blinker or the hazards, it blinks orange but for a split second blinks white as well. It’s an orange-White orange-white pattern that happens quickly and is hard to really tell it’s happening. Some people may like this but sometimes it can get annoying due to the fact others I have seen are only orange. I’ve been talking to the company through Instagram and whoever manages the Instagram account seems rly nice. Def going to see if he can help me figure out this little problem and possibly send some sort of resistor if need be or replace the lights for me. Overall, lights came packaged very well and are good quality other than those little problems listed above.
jh13wrx is offline   Reply With Quote
Old 11-11-2018, 10:07 PM   #42
Pawel062
Member#: 299305
The condensation when I talked with Protuninglab is a known issue. They recommend clear sealant before putting them on. That will solve that.
I got a new set from them due to this and used that oppertunity to retrofit them. I just finished that up and will get them on the car this week.
Some notes now that I opened them:
If you want to retrofit these then the plastic is soft and heats up quick. 210 for 10 min or less is plenty even overkill.
The white orange pattern that was mentioned above is built into the controller of the leds. Thereís a white controller/board for them and itís what alternates them. You would have to open them up to change this.
Also due to this controller there is no way to dim them with the low beams. Maybe with the subie speed harness you might be able to work it if you hack up the wiring.
The led boards for the c light look very similar to 2015 wrx ones so I venture to say the replacement boards will work.
The projectors are pretty damn crappy. The reflectors are not chrome but instead like a brushed silver lol. Lenses are clear but no sharp cutoff. They did give decent output with led bulbs and probably would do same with the hid bulbs but no sharp cutoff.
What I ended up using was profile bi led projectors with ijdmtoy sequential led strip. Also put in profile blue led demon eyes. Iíll post pics soon as they are on. I took some too while assembling. I also added some extra sealant and 2 moisture pouches in each headlight. Also tinted the orange reflector. Will post up pictures once they are on.
Old 11-12-2018, 03:11 PM   #43
Kwincy
Member#: 484052
2011 Impreza WRX
Looking forward to the pics. The condensation issue is something that I'm dealing with too. Perhaps I'll get around to sealing them when I get the patience to take off the bumper again. I have some hids that I want to put on too.
Old 11-12-2018, 09:11 PM   #44
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Unfortunately, you cannot use the OEM DRL resistor to cut the output of an LED bulb/lamp. You would need an LED specific driver to do so. Also, not all LED bulbs/lamps can be dimmed.
Otherwise, kudos on the lamps and I like your car and the hydro-dipped parts.
Old 11-14-2018, 01:43 AM   #45
Pawel062
Member#: 299305
Finally have these on and have some pictures:
Old 11-14-2018, 01:48 AM   #46
Pawel062
Member#: 299305
Part 2 with some pictures during assembly
Album 1:https://imgur.com/a/Z3jWheU
Album 2:https://imgur.com/a/eUz7FyO
Let me know if you guys have any questions.
Old 01-25-2019, 03:51 PM   #47
jamalridesbikes
Member#: 340146
2014 impeza wrx
black
Can you post a link of the led strips you used?
jamalridesbikes is offline   Reply With Quote
Old 01-25-2019, 07:57 PM   #48
DMNDNL
Member#: 448338
Subbed for future reference
DMNDNL is offline   Reply With Quote
Old 01-26-2019, 11:08 AM   #49
ObiBinKenobi
Member#: 496979
Originally Posted by Tfivem View Post
I've had these since May, and have been really happy with the overall quality of them. although, I have not experienced the halogen projectors as I retrofit them with bixenon projectors prior to installing them.
I also went ahead and deleted the amber reflectors while I had them open.
nice!
ObiBinKenobi is offline   Reply With Quote
Old 01-26-2019, 11:09 AM   #50
ObiBinKenobi
Member#: 496979
nice!
