Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 04-17-2018, 07:50 AM   #5726
D1FRNT
Member#: 484761
Didn't find any opinions about Japan Racing rims. What do you think about these specs, would they fit? My biggest concern is if they clear the front brembos? 9.5" width has more concave, but not sure could 18x9.5" ET38 255/35R18 fit.
model: 2003 Blobeye STI
wheel model: Japan Racing JR21
wheel size/offset: 18x8.5" ET38
tire brand/model: Toyo Proxes T1-R
tire size: 225/40R18
suspension: D2 coilovers
alignment: Unknown yet
fender mods: Rolled fenders
spacers: No
Thanks in advance and greetings from Finland!
D1FRNT is offline   Reply With Quote
Old 04-17-2018, 07:39 PM   #5727
AtlBlueBugeye
Member#: 482382
2002 Impreza 2.5TS
the darker blue
I have an 02 TS wagon. i am just wondering if 2018 crosstrek wheels will fit on the stock suspension. right now i have the factory steelys on there(195/60/15) and im looking at a set of 2018 crosstrek wheels, the 18 inch wheels, with stock tires on them. the seller has not sent me the actual tire size yet, pretty sure the wheels are 18x7, but they are off a 2 week old crosstrek. according to subaru.com they should be 225/55/18. if anyone knows about this fitment please let me know! thank you!
model: 2002 Impreza TS2.5 wagon
wheel model: 2018 crosstrek limited 18" wheel
tire brand: Falken Ziex ZE001 A/S? (factory subaru tire)
tire size: 225/55/18 (factory crosstrek tire)
Suspension: stock
alignment: not known yet
fender mods: none/stock
spacers: no
**UPDATE**
2018 18" Crosstrek wheels do not fit a 2002 TS wagon on stock suspension. it rubs the strut.
In related news, would anyone be interested in a set of practically brand new 2018 crosstrek limited wheels?
AtlBlueBugeye is offline   Reply With Quote
Old 04-22-2018, 09:46 PM   #5728
SauceSTi
Member#: 333350
2006 STi
Default Finally Installed my wheels!
year: 2006
model: WRX STI
wheel model: Advan RZ II
wheel size/offset: 17x9 +35
tire brand/model: Bridgestone Potenza RE-71
tire size: 255/40R17 94W
suspension:BC Coilovers
alignment: not sure, have to get it redone
fender mods: Rolled, no liners
spacers: No
I'm pretty sure that I'm at about -1.2 to -1.5 degrees of camber all around, I had the alignment redone years ago when I picked her up, haven't had it done since. So far, only slight rubbing in the front if the wheel is turned and the car hits a deep dip, other than that, no issues.
SauceSTi is offline   Reply With Quote
Old 04-29-2018, 09:07 PM   #5729
ritual21
Member#: 444062
model: 2013 hatchback sti
wheel model: enkei ts10
wheel size/offset: 18x9.5" ET 35
tire brand/model: unknown yet
tire size: 265/30R18? not sure
suspension: stock
fender mods: stock
spacers: None
wondering if this setup will work with the hatch and if i will need any camber?
i was thinking also 255's instead but i want a nice meaty look.
ritual21 is offline   Reply With Quote
Old 04-30-2018, 10:30 AM   #5730
denisbaik
Member#: 485259
Model: 2016 Subaru STI
Wheel Model: Advan RSD
Wheel Size Offset: 18x10 +35 offset
Tire Brand/Model: Not sure yet
Tire Size: 265/35/18
Suspension: Stock:
Fender Mods: None
I am looking to get these rims and was wondering what kind of work will be needed to fit these. Currently have no suspension mods. Is there a lot of work to do?
denisbaik is offline   Reply With Quote
Old 05-07-2018, 10:03 AM   #5731
JustaImpreza
Member#: 357515
2018 WRX - Base
Crystal White Pearl
Default the wheel fitment thread: keep it drama free
Model: 2018 WRX Base
Wheel Model: Stock 2018 WRX Premium Wheel
Wheel Size: 18x8.5 +55 offset
Tire Brand/Model: Continental DWS06
Tire Size: Stock
Suspension: 2018 WRX Base Stock
Fender Mods: None
Spacers: None
Iím looking to put a set of 2018 WRX Premium wheels and tires on my 2018 WRX Base model. The dealer says they wonít fit because the Base Model doesnít have the inverted struts like the Premium and Limited do. Theyíre trying to get me to upgrade to the STI Accessory 17x8 wheel, which I donít want.
JustaImpreza is offline   Reply With Quote
Old 05-07-2018, 07:18 PM   #5732
rymaggi
Member#: 253442
Model: 2016 STI Base
Wheel Model: Enkei RPF1
Wheel Size: 18x9.5 +38
Tire Brand/Model: Unsure brand
Suspension: Fortune Auto Coilovers
Fenders: Rolled Flat
Spacers: 8mm Front (Brembo Clearance)
Question/concerns: How much camber upfront will I need to run? Will the spacers clash with the hubcentric rings that are needed with the Enkei RPF1ís? Has anyone ran these on their 2015+ STI.
Really could use some help as Iím looking to buy wheels/tires soon. Mine are extremely bald.
rymaggi is offline   Reply With Quote
Old 05-18-2018, 05:11 PM   #5733
DoctorTako
Member#: 486141
OMGHi2U
Model: 2005 STi
Wheel Size: 17x9 et+36
Unsure Tire brand
Tire Size: Probably 225/40R17
Suspension: Stock
Questions/Concerns: As far as I've found on this thread (I didn't read all the pages but enough that my eyes hurt) they should fit but I will have to roll fenders correct?
Also, I'm fine running some negative camber, the wheels I'm looking at will need a bit of TLC before I get tires and install them, so getting camber plates/Group N top hats/bolts will be done by then.
DoctorTako is offline   Reply With Quote
Old 05-25-2018, 12:14 AM   #5734
JayR_16
Member#: 427425
Default Fitment help
Year: 2012
Model: sti hatchback
Wheel: work emotion d9r
Suspension: isc coilovers
I need some help fitting these wheels on my sti. What would be a good tire size to run with this set up, also would I need wheel spacers or fender mods for these.
JayR_16 is offline   Reply With Quote
Old 05-25-2018, 02:37 AM   #5735
z_alchaar
Member#: 442960
2004 Forester XT
JBP
Default 2004 Forester XT
Was looking for a few pieces of advice, sorry if this is in the wrong spot:
year: 2004
model: Subaru Forester (V7 full transmission swap with Brembos 5x114.3)
wheel model: TE37 SL
wheel size/offset: 18x10 +40
tire brand/model:
tire size: 255 35 18
suspension: Stance
Just wondering if I can get these wheels to fit on my car? I am sure I would have to to a roll/pull but has anyone used a similar setup? Thanks!
z_alchaar is offline   Reply With Quote
Old 05-25-2018, 04:35 PM   #5736
mvadenais
Member#: 472751
2018 WRX
Tire Size: Stock
Fender Mods: None
Spacers: None
I have 18x8.5 +45 offset wheels with 245/45 on my base 18. And I'm lowered on Swift spring spec-r. No rubbing, fit excellently
mvadenais is offline   Reply With Quote
Old 05-31-2018, 05:06 PM   #5737
CP-28
Member#: 221325
Model: 2008 STI
Wheels: Stock BBS 18x8.5
Tire size: 265/40/18
Tire Model: some el cheapo Goodyear all season stuff
Suspension: KW Clubsport 10KG ft 12KG rr
Fendr mods : none
Spacer: 1 1/8" spacer ft none in the rear
going from 265/35/18 to 265/40/18 on the stock BBS's on my 08 STI ordered the wrong profile by accident and now I cant return them.hope they fit. Former STU autox car and these are the daily wheels so the tires just need to look pretty and last forever lol. car hasn't been lowered much just enough to almost level out the lower control arms up front.
CP-28 is offline   Reply With Quote
Old 06-02-2018, 09:05 PM   #5738
18flashsti
Member#: 486709
Default 2018 sti 19x8.5 55
I am trying to fit a +35 wheel without rubbing is it possible?
18flashsti is offline   Reply With Quote
Old 06-07-2018, 09:41 PM   #5739
Mrsuperchango
Member#: 480447
Question
year:2006
model:wrx tr
wheel model:stock
wheel size/offset:stock
tire brand/model:michain
tire size:17x7
suspension:coilovers 1.5inch drop
Im currently on stocks and am thinking of new wheels.. from what iv been reserching 18x9 or 18x8 with specs from +48 to +35 i want to run meaty tires no streching and a little to no camber im willing to roll my fenders. Any recomendations?
Mrsuperchango is offline   Reply With Quote
Old 06-08-2018, 07:23 PM   #5740
kaiuchi23
Member#: 486969
2007 Impreza 2.5i
Obsidian Black
Question 2007 Impreza 2.5i Special Edition wheel/tire fitment HELP
Good afternoon.
I wanted to make it clear that I'm very new to vehicle modding, so some constructive criticism will be greatly appreciated!
I am considering buying this wheel/tire setup for my bone-stock Impreza, since I got a decent deal on it, but using the "search thread" tool, I cannot seem to find anyone else with a similar setup:
year: 2007
model: Impreza 2.5i Special Edition (Obsidian Black)
wheel model: Bremmer Kraft BR14
wheel size/offset: 18x8 +45mm
tire brand/model: Bridgestone Potenza RE760 Sport
tire size: 245/40R18
suspension: bone stock
alignment: stock
fender mods: Hopefully no
spacers: Hopefully no
Again, I am considering getting these because I am keeping an eye on this decent deal, plus I think the wheels look good based on the image on Tire Rack. When doing some research, I keep seeing thread posts that say that one should use 235's instead of 245's, or to get 35% instead of 40%. I'm not sure if the tires would rub against the stock suspension coil or the fenders at all. If it will, there are some 17" wheels that I am looking as well, but I will have to look at other tires.
I wanted to make the wheels be somewhat flush with the fenders instead of the stock look where the outer part of the wheel was 1-1.5" inside of the fenders.
Thank you for your help in advance.
kaiuchi23 is offline   Reply With Quote
Old 06-08-2018, 07:33 PM   #5741
fuelMuncher
Member#: 301554
2002 WRX Wagon
PSM, 2007 OBP WRX Limited
It comes down to the tire brand. With Bridgestone Potenza I'd stick with 235s, as they run wider than Japanese tires. If you were going 8.5 on the wheels 245s would work but may require slight rear fender modifications at 18". With the stock suspension though, you should be fine.
fuelMuncher is online now   Reply With Quote
Old 06-08-2018, 07:47 PM   #5742
kaiuchi23
Member#: 486969
2007 Impreza 2.5i
Obsidian Black
Thank you for the quick response!
Old 06-09-2018, 02:03 PM   #5743
grge
Member#: 390294
2005 sti
Originally Posted by boostedxsti View Post
I ran 18x10 +38s with a 5mm spacer for front caliper clearance on my 05 STi. Now, im running 18x10.5 +15 with no spacers (but i have karlton flares now). To me, 255s seem a bit big for a 17x9, as i had 255s on my 18x10s, and now have 265s on my 10.5s, and believe me I'm not a fan of stretched tires (although I do have the 35 not the 40). To answer your question, It should fit just fine. I had my fender liners removed to accommodate my wheel setup, but you should be alright with those sizes. Just to be safe, I'd maybe have some spacers on hand or camber bolts (hopefully your coilovers have the option to add camber plates) just in case you need to free up 5 mm or so.
Jumping on this Convo since I am trying to fit 18x10 38 work xd9. Iím sitting on bc coilovers and rolled fenders all around. I do not want a lot of camber but know I will have to dial up a few digits. Which tire size will give me the least amount of camber wear 255/35 or 235/45. Also leaning towards federals 595 if that matters
grge is offline   Reply With Quote
Old 06-12-2018, 09:51 PM   #5744
Mrsuperchango
Member#: 480447
Originally Posted by Mrsuperchango View Post
year:2006
model:wrx tr
wheel model:stock
tire size:17x7
what about some 17x8 or 17x9.... with what offset would be good with some federal rsrr's? and would some 245/45/17 or 245/40/17s fit?
Old 06-27-2018, 12:15 AM   #5745
RemysBRZ
Member#: 467887
Year: 2018
Model: WRX Limited
Wheel model: Enkei NT03
Wheel size/offset: 18x9.5 +38
Tire brand/model: Kumho Ecsta
Tire size: 255/35/18
Suspension: RCE Yellows -1.6 front -2.2 rear
Will this setup work safely without rubbing? Not looking to do any fender rolling. Would 265/35 work as well?
Thanks!
RemysBRZ is offline   Reply With Quote
Old 06-27-2018, 07:29 PM   #5746
VanWo
Member#: 447721
2017 WRX Limited
Originally Posted by RemysBRZ View Post
Year: 2018
Model: WRX Limited
Thanks!
255/35 will be fine. 265/35 could rub depending on the tire specifically (different brand run a little wider than others) but might get away with it considering -2.2 camber. If you want to be safe, and not worry about it, go 255/35
VanWo is offline   Reply With Quote
Old 06-27-2018, 11:58 PM   #5747
sublyme
Member#: 244114
2016 WRX premium
Year: 2018
Model: WRX Limited
Thanks!
I was running that exact setup with the same wheels and springs. (You posted in my for sale thread. If you zoom in my the pics you can see the tire size.)
18 x 9.5 NT03s with 265/35/18 tires.
Suspension is stock aside from the RCE yellows. No fender rolling needed. Absolutely no rubbing.
sublyme is offline   Reply With Quote
Old 06-28-2018, 12:22 AM   #5748
sublyme
Member#: 244114
2016 WRX premium
I would be interested to see any 265/35 tire that does not work for 2015+ WRX or STi.
Old 06-28-2018, 06:26 PM   #5749
VanWo
Member#: 447721
2017 WRX Limited
Depends on what you mean by "work" I guess?
On a 18x9.5 +38 wheel I've heard alot people say they rub (over bumps) in the rear and end up rolling rear fenders. As i mentioned this does depend on camber setting too but it's possible.
Personally it wouldn't worry me, but whenever someone says specifically they don't want to rub or have to mess with their fenders, it's fair warning.
Old 06-28-2018, 10:00 PM   #5750
sublyme
Member#: 244114
2016 WRX premium
I was running 18x9.5 with 265/35 +40 on RCE yellows with no rub whatsoever.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 04:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 02:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 02:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 04:54 PM
