Welcome to the North American Subaru Impreza Owners Club Monday December 17, 2018
Old 12-16-2017, 11:50 AM   #526
Tedde22
Member#: 184981
2013 BRZ
Galaxy Blue Silica
Anyone have information on these? Did some quick google'n but cant figure out what MY Outback they are from.
Tedde22 is offline   Reply With Quote
Old 12-22-2017, 03:53 PM   #527
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Originally Posted by shaowQ View Post
If anyone is wondering, 2011+ WRX wheels i took one without the tire to work today and put it on the shipping scale.
Confirmed at 21 pounds
Just another data point.
I bought a refurb from ebay to replace a damaged wheel (some idiot backed into in a parking lot). This was an opportunity to weigh the BARE wheel (no tire, no valve, no tpms, no weights, no grime). On my digital bathroom scale, it came up to exactly 20.0 lbs.
chimchimm5 is offline   Reply With Quote
Old 01-28-2018, 11:52 PM   #528
amanMaphia
Member#: 177368
2011 wrx
Sorry cant find answer...im getting the factory 18x8.5 inch wheels for my 2015 wrx. Currently have the 17x8.
Same offsets
How much further if any do the 18x8.5 extend outwards both running factory recommended tire size
amanMaphia is offline   Reply With Quote
Old 01-29-2018, 11:40 AM   #529
Mach V Dan
Member#: 12029
Um, simple math would tell you it extends outward an additional 1/4", since it's the same offset and 1/2" wider.
But also, please do not ask fitment questions here. This thread is only for OEM wheel specs.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 01-29-2018, 11:41 AM   #530
amanMaphia
Member#: 177368
2011 wrx
Same offsets
Someone help me out here
Old 01-29-2018, 11:45 AM   #531
Mach V Dan
Member#: 12029
2005 Legacy Outback XT. 17x7".
--Dan
Mach V
FastWRX.com
Old 01-29-2018, 12:26 PM   #532
amanMaphia
Member#: 177368
2011 wrx
--Dan
Mach V
FastWRX.com
Thanks
Did not know if it would be 1/4 or 1/2
Old 02-06-2018, 01:41 PM   #533
boostin23
Member#: 204172
---- 05 STi
Any info on the 2018 Crosstrek - US Premium trim.
(6-speed manual if that makes any difference - shouldnt)
boostin23 is offline   Reply With Quote
Old 02-06-2018, 11:32 PM   #534
SnowmanCT
Member#: 330110
2017 STI Limited lip
LBP
Originally Posted by J168 View Post
The question was submitted a while ago but I just ordered and weighed the wheel (18x8.5) without the centercap. It came out to 22.2 lbs. Still lighter than the OEM 17x8 for 2017 WRX (23.6 lbs if I'm not mistaken).
Thank you!
SnowmanCT is offline   Reply With Quote
Old 02-13-2018, 12:00 PM   #535
boostin23
Member#: 204172
---- 05 STi
Any Xtrek info?
Old 02-17-2018, 04:04 PM   #536
N8shon
Member#: 35282
2018 WRX STI 50th
Heritage Blue
Has anyone nailed down exactly who makes the 19's on the 2018, and what construction type is used?
N8shon is offline   Reply With Quote
Old 02-21-2018, 06:58 PM   #537
Phazon Spectre
Member#: 482421
2017 Subaru WRX Lmtd
Lapis Blue Pearl
Default Good wheel and tire setup for GT driving
Currently running the stockers on a '17 WRX, would like to swap to a more touring setup.
I don't mind a dip in cornering perfromance.
Phazon Spectre is offline   Reply With Quote
Old 03-07-2018, 06:03 PM   #538
Mach V Dan
Member#: 12029
Any Xtrek info?
2.0i and 2.0i Premium:
Offset: +55
Bolt pattern: 5x100
Wheel Weight: Unknown
OEM-equipped tire size: 225/60R17
Limited:
Offset: +55
Bolt pattern: 5x100
OEM-equipped tire size: 225/55R18
I'd guess Enkei, but have to check. Probably plain old gravity cast.
--Dan
Mach V
FastWRX.com
Old 03-07-2018, 06:18 PM   #539
N8shon
Member#: 35282
2018 WRX STI 50th
Heritage Blue
Offset: +55
Bolt pattern: 5x100
Limited:
Offset: +55
Bolt pattern: 5x100
--Dan
Mach V
FastWRX.com
My guess as well but I'd like to know for sure on both aspects.
Old 03-27-2018, 04:07 PM   #540
Jonquist
Member#: 432969
2017 WRX Premium
2012-2014 STI, 2016-2017 Premium/Limited WRX, made by Enkei
Offset: +55
Bolt pattern: 5x114
Wheel Weight: 26.6 pounds
OEM-equipped tire size: 245/40R18
Forgive me if its been asked, has anyone dipped/powdercoated/painted a set of these black? Curious to see how it would look.
Jonquist is offline   Reply With Quote
Old 04-07-2018, 05:34 PM   #541
asloan5
Member#: 482420
2005-2007 legacy outback wagon. They come in silver and gunmetal grey.
I had a set on my 08 forester and they looked awesome
asloan5 is offline   Reply With Quote
Old 04-09-2018, 12:11 PM   #542
08OBS
Member#: 274397
2005 WRX V9 207
2018 Colorado Duramax
For anyone interested UK WRX wheels, the same as STI Wagon (GG) wheels. Stoptech ST40 calipers 328x28 fit under them. I test fitted them this weekend.
08OBS is offline   Reply With Quote
Old 04-17-2018, 04:39 PM   #543
Pelco
Member#: 435599
2016 Impreza Sport
Update for 2012-2016 Impreza Sport wheels
17x7 Alloy
Offset +48
Bolt Pattern 5x100
Weight 22lbs
Oem-equipped tires 205/50R17 ~ 21lbs
Yokohama Avid S34
Total weight 43lbs/19kg.
Pelco is offline   Reply With Quote
Old 04-18-2018, 05:05 PM   #544
Mach V Dan
Member#: 12029
Weight 22lbs
You weighed the wheel alone? Or just the mounted wheel/tire combo?
--Dan
Mach V
FastWRX.com
Old 06-02-2018, 08:11 PM   #545
wutdadilyo
Member#: 53967
2011 WRX Premium
Satin White Pearl
Does anyone know the wheel specs for these stock Subaru wheels? I'm not sure but I think they are off a Forester? Again not sure but here are pics...
wutdadilyo is offline   Reply With Quote
Old 06-13-2018, 03:33 PM   #546
Mach V Dan
Member#: 12029
2006 Legacy Outback XT Limited (among others). 17x7 +48 5x100.
--Dan
Mach V
FastWRX.com
Old 07-10-2018, 04:40 AM   #547
FIGURRAMOTORS
Member#: 482561
Default Has anyone posted this model before?
17*7J +48 5*100 56.1mm
Made in Korea. I came across them in some Subaru catalogue. Were available in 2 colours: gold and copper.
FIGURRAMOTORS is offline   Reply With Quote
Old 08-08-2018, 02:02 PM   #548
Mach V Dan
Member#: 12029
I've never seen that wheel in real life. Has anyone else?
--Dan
Mach V
FastWRX.com
Old 08-19-2018, 06:16 PM   #549
SonorousAria
Member#: 456372
2017 WRX Limited
Pure Red
Subaru Stars
I may have missed it in my scanning the pages of this thread, Buy does anyone know if the 19" wheels from the 2018 STI are forged or cast? Are the 2015-2017 BBS the only OEM wheels that are forged with the 5x114 pattern? thank you for your help!
SonorousAria is offline   Reply With Quote
Old 10-01-2018, 06:11 PM   #550
Kostamojen
Member#: 2272
2018 Type-RA 196/500
1999 OBS Camo Wagon
Anyone have the weight of the Type-RA wheel yet?
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 10:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 04:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 01:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 01:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 10:20 PM
