Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Vancouver Impreza Club
Old 05-25-2018, 03:27 PM   #1
dalesmotorsport
Member#: 173316
'18 STi Type RA
Default WRX in for an ACT Clutch and Moore Performance BlastPlates
BlastPlates™ are bolted through existing bolt locations that hold the two halves of the transmission together (the transmission will have to be either lowered or removed for the installation). By bolting these plates onto the outside around the gear set the stiffness of the case is increased, improving gear mesh tolerances under shock loading and high torque situations.
BlastPlates are a perfect upgrade for any 5 speed manual transmission, from stock horsepower levels to Stage 2 and Stage 3 levels. There is no hp or tq limit, however this product will allow ANY gearset to achieve maximum power (or much more) due to proper tooth engagement under extremely high load and torque. We’ve personally dyno tested BlastPlates to over 750 horsepower!
Key Features and Benefits:
Fully CAD-designed
Developed and tested using FEA analysis
one piece construction
Custom class 10.9 hardware utilized for high case torque-up.
investment cast 304 stainless steel for ultimate strength and durability
Advanced Clutch Technology // Performance Clutches and Flywheels
SINGLE DISC
CLUTCH KITS
ACT SINGLE DISC CLUTCH KIT FEATURES:
ACT Clutch Kits are newly manufactured units, not rebuilt from used parts. Many other clutch companies modify the original equipment (O.E.) parts to produce limited benefits using the OE diaphragm spring.
ACT fully engineers every application, designs and develops entirely new diaphragms and pressure plate faces. These steps are necessary to achieve vastly improved performance, well beyond the restrictions of the OE geometry.
Features up to 28 different pressure plate and disc combinations for anything from mild street use to full track use.
Torque holding capacity increases ranging from 20% to 400%
Most Meet SFI Spec 1.1
dalesmotorsport is offline   Reply With Quote
Old 06-11-2018, 02:44 PM   #2
tora
Member#: 5851
17 Ford Escape SE
Blk
Nice fellas!
tora is offline   Reply With Quote
