Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 09-11-2017, 01:24 PM   #18276
bidaci
Member#: 291519
2011 OBS
Originally Posted by amuri1990 View Post
Were you in the white bugeye? I have the whiteline 22mm bar with moog endlinks. I'm still playing with the stiffness in the back, it's on the 2nd out of 3 stiffness settings. I know guys will disconnect their rear sway to get more turn in but in a hatch it's just so wobbly without the bar! It's crazy how different cars respond to dynamics completely differently.
I have the Black Impreza in GS. I was talking to you in grid. I had a 22 on the back and I found it to be either overtsteering or understeering with no balance. But with the springs you have and the struts you don't, it's too early to tweak to much.
If you want to try a softer bar I have a 16 and I think an 18 if you want to try them.
bidaci is offline   Reply With Quote
Old 09-11-2017, 01:36 PM   #18277
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
JourdanWithaU is offline   Reply With Quote
Old 09-11-2017, 01:41 PM   #18278
amuri1990
Member#: 346009
2009 Impreza 2.5i
Newport Blue Pearl
Originally Posted by JourdanWithaU View Post
What's your rsb situation Jourdan? I think you said what you were running a while ago, can't remember haha
amuri1990 is offline   Reply With Quote
Old 09-11-2017, 01:43 PM   #18279
amuri1990
Member#: 346009
2009 Impreza 2.5i
Newport Blue Pearl
Oh right! That's pretty much what I'm getting right now, it's either this or that to the extreme. Although with those re71rs I definitely felt better with a stiffer bar so I think I need either adjustable struts or heavier springs before swapping bars in and out. Stupid tires and their money costing nature...
Old 09-11-2017, 02:40 PM   #18280
bidaci
Member#: 291519
2011 OBS
I had Konis all around. They are great to be able to adjust turn in and constant state sweepers. I said had, as I developed a clunk in one of the inserts up front. So I put in the ExcelG like you have. Way to soft for autox, the Konis are so much better controlling the balance in the elements. That should be your first upgrade if you are going to pursue autox (IMHO). Of course this only works if you have good tires!
Old 09-11-2017, 03:29 PM   #18281
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
What's your rsb situation Jourdan? I think you said what you were running a whole ago, can't remember haha
22mm front sway set soft.
24mm rear sway set stiff.
400# springs in the front, .75 turn from soft.
450# springs in the rear, 2 turns from soft.
(Konis have 2.5 turns from full soft to full stiff.)
-2.5* camber in the front.
-1.6*/-1.8* (natural) camber in the rear.
Even tire pressure front/rear.
I liked the tight ass.
I recon I also had a little bit less weight in the back swapping the spare tire for an amp and sub.
But everyone is different. What works for one person, may or may not work for others. I had one person drive my car and complain that the rear was too loose. I really like the way the car handled.
Old 09-11-2017, 03:44 PM   #18282
bidaci
Member#: 291519
2011 OBS
Wow, that sounds a bit tail happy. Is this your DSP setup? Did you try that on street tires?
Old 09-11-2017, 03:57 PM   #18283
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
AutoX, Track, Street, always ran street tires. 255/40/17 Dunlop ZII was my preference. I had a set of ZIISS and didn't like them initially. They required less camber or less pressure.
I did run GS for a year with WRX springs, Konis, and a 22mm rear sway. Pretty sure I set the sway stiff. Sometimes I think back about what it might have been like if I did 2.5i springs in the front with WRX springs in the rear. Tire choice was also 205/55/16 Dunlop ZII.
Old 09-14-2017, 12:49 PM   #18284
subby00
Member#: 35191
2000 Impreza sport
green
Hey groupies I just got some new wheels and tires
F1R f27s in 18x8.5 +40. I would have rather had +35 but I still like em.
subby00 is offline   Reply With Quote
Old 09-19-2017, 10:06 PM   #18285
McGowannn
Member#: 473736
2008 Subaru Impreza
Dark Gray
Default Desperate to Find UEL Headers...
I've been looking all over for UEL headers for my 2008 Impreza 2.5i Hatch and by what I've seen the only option I have is to spend $800+ for custom headers, and I'm not spending that much so I'm pretty bummed. I was wondering if anyone had some knowledge on if there are any headers that I could buy that aren't so expensive, and are just bolt on, or if there are any UEL headers that will only need little modification. I am desperate for the Subie Rumble...
Heres my car BTW
McGowannn is offline   Reply With Quote
Old 10-15-2017, 06:10 PM   #18286
snowman0812
Member#: 374919
2010 impreza
Default the 2.5i thread
Just a few good pictures of how the car sits now
snowman0812 is offline   Reply With Quote
Old 10-15-2017, 06:57 PM   #18287
amuri1990
Member#: 346009
2009 Impreza 2.5i
Newport Blue Pearl
Heres my car BTW
$800+ is one if two options you have. The other option is a set of UEL headers from SEMotors for 1997-2005 Impreza. Runs about $350 for decatted and $450 for cats. They will require about 12-15" custom piping as the previous gen impreza headers dump on the driver side as opposed to ours on the passenger side. Do-able, but you will not be guaranteed to not throw at CEL and god have mercy on anyone doing exhaust work in MA. I'm buying a stock exhaust to replace mine to pass inspection because ANY aftermarket exhaust mods will no longer pass.
Edit: also understand that any uel headers you get will not have heat shields attached...so you either have to fashionyour own some how or not drive your car in any weather at all
Old 10-15-2017, 08:56 PM   #18288
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Isn't there some kind of coating you can add for weather resistance?
terrainasaurus is offline   Reply With Quote
Old 11-02-2017, 04:04 AM   #18289
HansDC7
Member#: 443373
2005 Legacy GT STGII
Satin White Pearl
Sold Luna a little over a week ago. Some last sunset pics after my last wash with her.
HansDC7 is offline   Reply With Quote
Old 11-03-2017, 01:44 AM   #18290
XSV Klutch
Member#: 259013
2007 Impreza 2.5i
Greyish- Boosted
Someone Please buy my supercharger kit!! lol selling for $1500 and I feel that is a good price
[IMG]20150504_121551[1] by Ryan Kemp, on Flickr[/IMG]
XSV Klutch is offline   Reply With Quote
Old 11-14-2017, 09:42 AM   #18291
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Anyone here has done an engine.swap on these guys?
Does it matter if.the donor is an auto?
Thanks!
ssssssantimonio is offline   Reply With Quote
Old 11-18-2017, 07:04 AM   #18292
frotasticben
Member#: 410164
2008 Impreza 2.5i
Anyone else have issues with the plastic dust cover for auto trans getting stuck?
frotasticben is offline   Reply With Quote
Old 12-03-2017, 08:49 PM   #18293
eustacer
Member#: 416465
2009 Impreza 2.5i
This thread needs a bump so heres a pic of my sti grill (i ripped the badge off) i installed a couple months ago
eustacer is offline   Reply With Quote
Old 12-03-2017, 10:26 PM   #18294
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
Shipman is offline   Reply With Quote
Old 12-04-2017, 03:09 AM   #18295
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Lookin' good! You and I both could use a premium front bumper with the lip ;D
Old 12-04-2017, 11:18 AM   #18296
eustacer
Member#: 416465
2009 Impreza 2.5i
I could use a new bumper all together. its cracked in a couple places and all the plastic brackets are broken
Old 12-05-2017, 09:49 PM   #18297
huwey
Member#: 441433
huwey is offline   Reply With Quote
Old 12-06-2017, 05:40 PM   #18298
denizen
Member#: 478733
2010 2.5i Premium
Dark Grey Metallic
Default clark kent
denizen is offline   Reply With Quote
Old 12-15-2017, 11:40 AM   #18299
eustacer
Member#: 416465
2009 Impreza 2.5i
Taken just before my 3hr drive home from school
Old 12-17-2017, 08:07 PM   #18300
Vertignasse
Member#: 329445
2011 2.5i Hatch
Winter setup, which consists of steelies, Bridgestone Blizzaks and an old bumper. (It's cracked under the right fog light.) I cracked this bumper last winter and replaced it, but I decided to reinstall it now so that I don't need to be too careful while enjoying winter driving.
Vertignasse is offline   Reply With Quote
What's the widest tire that can be put on the 2.5i? SubieSubie Impreza Forum 21 07-25-2017 08:51 AM
Will the STi Front and Rear Bumper will fit on the 2.5i? GD6Noob Interior & Exterior Modification 7 04-30-2012 08:33 PM
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
Test Drove the 2.5i Legacy at SoD maclif Texas Impreza Club Forum -- TXIC 8 06-02-2004 08:42 PM
