09-27-2004, 07:27 PM | #1 |
Member#: 60023
What to swap into a 97 2.5gt
So right now I actually have two 97 2.5gt's. One is totaled because the whole car is tweaked but the engine and drive train are just fine only has 60k on it. The other car I basically bought just for the body, it has 160k on it but still runs just fine.
I would like to turbo the car but understand that the stock block will not hold anything above 5-7 lbs. So far I think it looks best if I keep the stock DOHC heads so the wiring is a lot easier, but as far as the block goes I'm still up in the air. My options seem to be: EJ20T out of a WRX- not enough displacement EJ22T getting better and seems like a better block overall from what ppl say also probably cheaper because it would be a little older. EJ25T out of an STI- probably the most expensive option but I would love to still have 2.5L of displacement not to mention 350hp seems feasible with some head work. What do you guys think? I dont mind spending some decent money if its worth it. I am also not new to turbos/performance work, I am just new to subarus. I am sick of FWD ha ha. Thanks, -Mike
09-27-2004, 08:32 PM | #2 |
Member#: 25952
NWIC
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
The swap that will end up being cheaper down the road would be an STI or WRX swap instead of a hybrid motor...It would be more reliable, and if you got a Version 8, it would be almost 350 (I've seen anywhere from 325-350 CHP) horses right out of the box. The only thing with any of the STI swaps would be the wiring. It's alot of work, but it is really worth it.
Whatever swap you end up doing is going to need alot of wiring. And don't let the 2.0 Displacement get to you. The JDM Version 8 (with the Twin Scroll Turbo) will suprise you on how it runs. Mike Last edited by wrx_driver_2002; 09-27-2004 at 08:42 PM. |
09-28-2004, 12:25 AM | #3 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
I think you will like a WRX motor, then do the usual upgrade path. A ver7 or 8 sti motor would be cool and the US STI has the fly by wire throttle to think about
09-28-2004, 12:39 AM | #4 |
Member#: 60023
At this point I allready have the DOHC wiring in my car because thats how it came stock. Would there be much wiring at all with the STI swap? I dont think I would need to do a harness conversion at all if I have a good fuel management system.
I will not be using a stock turbo, up pipe, down pipe, or any of that. And I will definatly be using a stand alone fuel management system, anyone use the AEM EMS on subarus? About how much are some of the STI blocks going for? No tranny no harness or any of that. All I need is a good strong block with good internals. |
09-28-2004, 12:41 AM | #5 |
Member#: 60023
Oh and my eventual whp goal is 400. I understand that will be pushing it with stock internals.
I've allready done that in a civic with a 1.8L integra engine, it shouldnt be that hard with a subaru. |
09-28-2004, 11:21 AM | #6 |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
The engine you have in the car is completely different, even the wiring. If you want to do a reliable swap you'll take the time to put in the proper harness so the engine can run off of the factory ECM. Subaru's are totally different than Honda's in the wiring department. Each year they changed something and most of the ECM's are totally different.
Z |
09-28-2004, 11:33 AM | #7 |
Member#: 25952
NWIC
I'll post some pics of exactly what is involved in the wiring department. I am doing the exact same thing to a 99 Legacy GT Sedan right now. We've done a 1990 Legacy, two 2002 WRX's, a 2003 TS, and We're getting ready to do a 1986 Subaru GL Wagon
Mike |
09-28-2004, 11:54 AM | #8 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
yay! for member numbers
1 a usdm ej20 will be the easiest and due to the aftermarket support it by far the best way to go 2 it will provide plenty of HP 3 you will probblay spend close to $20k to get a 400 whp legacy |
09-28-2004, 12:24 PM | #9 |
Member#: 60023
For those of you that have done swaps like this, how different are the sensors from my 2.5 block to the EJ257 block. I dont care about anything in the heads or IM just on the block itself.
09-28-2004, 02:12 PM | #10 | |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed (sold) |
ss |
09-28-2004, 02:47 PM | #11 |
Member#: 25952
NWIC
pics of 99 GT
How far the Twin Scroll Turbo Headers Stick down
PNWSEC Decal Version 8 Harness being hacked apart Version 8 Engine Management after being removed from the harness Stock Engine Management after being removed from the car Engine Connector Harness |
09-28-2004, 02:53 PM | #12 |
Member#: 25952
NWIC
More Pics
Twin Scroll Turbo Exhaust Housing
Fuel Pump Controller (Mounted to rear seat back support) Pic from the front side of the rear seat back support STI Waterspray Tank Mounted in Rear right side under dash mess More Mess The Label Maker is your best friend Overall Pic of Engine bay |
09-28-2004, 02:55 PM | #13 |
Member#: 25952
NWIC
more pics
Final Result of Kreeger's car...The 2003 TS Wagon V7 Swap
EJ20TT swap into a 97 Legacy GT, would it have the same difficulty as swapping in RS | Deucalion | Legacy Forum | 2 | 11-09-2009 02:25 AM |
ej20tt swap into a 97 Legacy GT, would it have the same difficultys as swapping in RS | Deucalion | Subaru Conversions | 1 | 11-09-2009 01:19 AM |
01 Phase II swap in 97 2.5GT - EGR/CEL problems | czo79 | Normally Aspirated Powertrain | 2 | 11-06-2008 11:26 PM |
Pictures of my current projects - 97 2.5GT | revhigh96 | Legacy Forum | 4 | 04-10-2006 09:22 PM |
02 Wrx Swap Into A 99 2.5 Rs What Cani Use What Cant I | GODSON | Subaru Conversions | 10 | 10-12-2004 03:56 PM |
