Welcome to the North American Subaru Impreza Owners Club Friday November 16, 2018
Old 02-15-2013, 11:13 PM   #76
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
1.2 will soon be a standard. We have just begun to see the bar raised
Old 02-15-2013, 11:13 PM   #77
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by Phatron View Post
you dont want small turbos to hold more boost at redline....more boost /=/ more airflow all the time.
You have to watch the airflow.....most of the time on small turbos trying to jack up the boost at redline doesnt actually increase the MAF.
If they put a EL header on this car, the airflow would increase and the boost would drop after 5200rpm.
Originally Posted by Steve.804 View Post
You guys are so held up on dyno numbers and no disscusion on the 18.5psi at redline? That is 3 psi more than I could ever get my vf-43 to hold even when I was playing with the use of a helper spring. I think the turbo has a different wheel or something which would also make sense of the extra power this car is making.
+12345
My VF39 used to hold 15-13psi at redline and my car trapped 121mph and used to pull on pump gas 35R cars .
It only made a max of 330whp airboy
Old 02-15-2013, 11:49 PM   #78
toph
Member#: 78640
14 LTZ 6.2
04 STi
121 is MOVING OUT on any VF wow. What kinda weight reduction.
toph is offline   Reply With Quote
Old 02-16-2013, 11:40 AM   #79
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
121-122 is doable on a VF in a WRX with tall gearing. I had a customer hit 11.6 @ 122mph with this kind of setup. If I recall, Juan thought it was impossible until he tried it himself .
-- Ed
