11-26-2011, 10:53 AM | #351 | |
Member#: 230925
Vehicle:04 WRX Wag Stage 4 06 Impreza 2.5I |
On the one in the rear there a lil hole to pop out the rear badge it might have tabs with two holes in between the skeleton of the trunk. It should be the same on yours too just double check. I took off the rear badge awhile ago on my 06. G.L
11-26-2011, 09:51 PM | #352 | |
Member#: 288147
Vehicle:2011 wrx premium obp |
Right on, I'm going to check it out tomorrow hopefully. Thanks! |
11-27-2011, 10:55 PM | #353 |
Member#: 302008
BAIC
Vehicle:02 WRX Silver |
Very clean.
11-28-2011, 04:15 PM | #354 |
Member#: 301876
Vehicle:2009 2.0 Diesel satin pearl white |
I can't decide for an color schema. I dive an 09 hatchback in satin pearl white.
Grill is complete black (Stock) and the rear trim also gets matt black. I fought about all chrome -> white (the ring around also) and the blue part black or chrome - > neon green and the blue part black. i would love to color the brake caliper also in green so this would match very well and in the summer maybe black rims? its so hard to decide |
12-28-2011, 11:17 PM | #355 |
Member#: 159478
HIIC
Vehicle:06 STi Aspen white |
Very nice.
12-29-2011, 12:28 AM | #356 |
Member#: 300717
RMIC
Vehicle:2004 WRX JBP |
One hot tip...
I did mine this weekend using goof off. Took me about 30 minutes of light scrubbing with q-tips. No cracking, fading, or foggyness. Perfect job. Then I decided to give it a quick rinse with goof off. Well...don't do that. The plastic started melting before I could rinse it off. So I have a few melted in fingerprints. Because of that. So goof off works perfectly as long as you keep it on q-tips only. Painting it on the other hand took me 4x as long. |
12-29-2011, 07:40 AM | #357 |
Member#: 281725
Vehicle:2006 STI Aspen White |
My first attempt at using gold leaf failed, so I just went with gold paint.
12-29-2011, 07:42 AM | #358 | |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
12-29-2011, 08:27 AM | #359 |
Member#: 281725
Can anyone see my image two posts up? I can't figure out why they keep disappearing...
12-29-2011, 08:28 AM | #360 |
Member#: 153412
I can see it on my ipod
12-29-2011, 10:09 AM | #361 |
Member#: 305062
Vehicle:2011 WRX |
I just want to make sure I don't have any hazing so should I wet sand it? If so what do I polish the plastic with after?
12-29-2011, 10:14 AM | #362 |
Member#: 281725
I didn't sand it, how I went about it (albeit inefficient) was to use paint thinner (this WILL cloud the plastic) but then used a buffer pad on my Dremel and plastic polishing compound that I had. I'd advise doing something else, as that all took me...well...a long time.
If you get any hazing, wet sanding may work well. It might be a pain to do inside the stars though. |
12-29-2011, 10:20 AM | #363 |
Member#: 305062
Vehicle:2011 WRX |
Yeah I want it to have that nice polished look... Any suggestions on what I can do a practice run on.... I didn't practice on my tail lights on my old civic and ummmm let's just say it didn't end well lol. No way I'll repeat that on new wrx
12-29-2011, 10:22 AM | #364 |
Member#: 281725
Could always go to a junkyard and pick up a crap light from somewhere. If you can polish that up, you should be good to go.
12-29-2011, 04:20 PM | #365 |
Member#: 282812
NWIC
Vehicle:2005 WRX PSM |
Did this on my wife's '04. Used the goof off and probably 200 q-tips.
Ended up having a little crack in it but from more that a foot away it looked great. |
12-29-2011, 09:31 PM | #366 |
Member#: 294069
Vehicle:98 Forester Green |
im in for this mod, will probably be one of my first five DIY mods
PSM for the stars and gloss black background also, i will paint PSM in the circle around the stars |
12-29-2011, 10:35 PM | #367 |
Member#: 230925
12-29-2011, 10:43 PM | #368 |
Member#: 159478
HIIC
I wanted to test before I did it. So I pulled out one of my extra badges today and gave it a shot. Time consuming especially since im a perfectionist but not a single problem. Take your time and do it right. I'll post pics once I get around to doing the emblems on my actual car.
12-29-2011, 10:58 PM | #369 | |
Member#: 230925
12-29-2011, 11:03 PM | #370 | |
Member#: 207098
Vehicle:STI :( Gone '14XV Gone, '10 FXT |
12-29-2011, 11:48 PM | #371 | |
Member#: 230925
Damn jstepp..... u did this n didnt put me down? i feel like the bastard step child. |
12-29-2011, 11:55 PM | #372 | |
Member#: 159478
HIIC
And as for removing the paint I used 600 grit sand paper than a 1000 grit wet sand to smooth it. |
12-29-2011, 11:57 PM | #373 | |
Member#: 214796
Vehicle:2004 OBS |
Updated pic of how mine came out: Matched the badge to the OBS paint scheme on the car (Green/Gold) |
01-03-2012, 08:20 PM | #374 |
Member#: 305263
Vehicle:2011 Impreza wrx DGM |
Got an 11 hatch, all you need is some even heat, and patience, they come right off.
01-08-2012, 04:05 PM | #375 |
Member#: 285661
TXIC
Vehicle:2011 STI Dark Grey Metallic |
Finally got around to doing this one. Took me forever, and I don't know how well it came out, but it looks good from more than 3 feet away.
How to paint your stock wheels | criscross79 | Interior & Exterior Modification | 545 | 04-10-2012 05:10 PM |
Video Intruction of how to debadge your SUBARU | minx1225 | Interior & Exterior Modification | 15 | 03-21-2006 05:30 PM |
How To Keep Your Subaru Alive (V2 Manual) | NewDriverOlderRide | Private 'For Sale' Classifieds | 0 | 01-20-2006 11:43 PM |
How to paint your seats | reconracer | Interior & Exterior Modification | 62 | 08-26-2005 01:23 PM |
How to paint your aftermarket rims? | o2sys | Interior & Exterior Modification | 2 | 06-29-2005 04:51 PM |
