Welcome to the North American Subaru Impreza Owners Club Sunday August 19, 2018
Old 01-05-2018, 09:15 AM   #1
Joshcole1122
Member#: 479901
Default Will these struts fit and work on my 02 wrx sedan
Joshcole1122 is offline   Reply With Quote
Old 01-05-2018, 09:56 AM   #2
Notch 8
Member#: 355254
Originally Posted by Joshcole1122 View Post
Not without changing the rear top hats.
Search WRX wagon struts to WRX sedan. Lot's of info.
Notch 8 is offline   Reply With Quote
Old 01-05-2018, 10:19 AM   #3
Joshcole1122
Member#: 479901
Thanks I have searched with tons of mixed results.
Old 01-05-2018, 06:10 PM   #4
Joshcole1122
Member#: 479901
Looks like Iíll need different hats
Old 01-06-2018, 12:34 AM   #5
jamal
Member#: 71875
WRX wagon and sedan top mounts are exactly the same.
02-03 and 04-07 rear tops are different because of a change to the springs but they still work and the holes are the same in all 02-07 imprezas.
So those will work. But, the wagon has a narrower track than the sedan so you get a bit of extra camber. IF those are wagon struts. They could be sedan struts on a wagon. Either way it's fine and more negative camber is better for handling. At most you'll need some adjustable bolts for the rear.
jamal is online now   Reply With Quote
Old 01-06-2018, 01:10 AM   #6
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
H&R camber bolts are super nice if you decide to go with some.
monkeyposeur is offline   Reply With Quote
Old 01-06-2018, 09:28 AM   #7
Joshcole1122
Member#: 479901
Great info! Thanks guys!
Old 01-07-2018, 04:17 PM   #8
Joshcole1122
Member#: 479901
Picked them up for 80
Old 01-18-2018, 08:49 AM   #9
cmiovino
Member#: 134005
2004 WRX Premium
Dude, that's a deal and a half. The springs themselves look to be the USDM STI pink springs. I thought I got a good deal on mine at $150 for the springs only, ha.
If you need the struts, I would just swap out your top hats for at least the rears on these ones you picked up. Then you know if you have any issues, it won't be from the rear top hats.
