Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-22-2006, 12:37 AM   #1
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
Default Need Advice on Engine Install in Houston
Hey everyone,
My stock 02' 2.0l engine recently tested low on two cylinders during a compression test. Anyway I had originally planned to purchase a 2.5l Sti short block and reuse my stock heads but as luck would have it I found a assembled 2.5l long block at a very reasonable price.
My boggle is this: I don't have the space, tools, or experience (read: mechanical talent) to preform this swap myself... so what options do I have? EL? I've hear good things about Gillman's mechanic Ken... would this be something a dealership would preform? Besides the motor install the ECU will need to be swapped and the AVCS harness will need to be installed. Along with various miscellaneous items associated with motor swaps...
Details on what I need to install:
Engine: SOLD
EJ257 w/CP pistons
Axis modded crank. Balanced & drilled(good for 8000rpm)
Shimed 2.2 oil pump
PE timing belt
V7 large port AVCS heads
Ported TGV’s
Slightly ported intake & throttle body
V8 engine harness
4 coil packs
The engine makes 315whp & 350wtq @3300 with the VF39. Was tuned by Doug at Topspeed
Has about 8000 miles
VF39 turboSOLD
ECU: SOLD
V7 S202
Launch control(no boost)
IC sprayer control
Has been Ecutek flashed already
AVCS harness can be included for $SOLD
Sti pink injectors SOLD
The TMIC, BOV, turbo inlet pipe, BCS, alt, PS pump, A/C, and headers (probably forgetting something) will need to pulled off my current engine and attached to the new engine.
Also I will need to get a set of fuel rails and a fuel pump.
So, any ideas, comments, suggestions, or recommendations?
I'd appreciate the help.
Thanks,
Ken
coolcougar is offline   Reply With Quote
Old 03-22-2006, 12:41 AM   #2
H.K. Phooey
NASIOC T-Shirt Crew
Member#: 35509
2010 SuperChargedJag
Pewter
EL if they have the time Chris will do it right. Then I say Mcree, Johhny and Fred, Also WHS Chuck nows his cars as well.
H.K. Phooey is offline   Reply With Quote
Old 03-22-2006, 02:31 AM   #3
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Cosworth, TSR70, MZM Tune
I've never had to have a block swap done, but I can attest that Kenny at Gillman North is top notch.
-D
Dasani is offline   Reply With Quote
Old 03-22-2006, 03:19 AM   #4
el tekk-O
Visiting NASIOC Timeout
Member#: 65223
2002 WRX-6 speed
130000 miles
whats EL?
el tekk-O is offline   Reply With Quote
Old 03-22-2006, 08:11 AM   #5
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
+1 for EL
Big_Hitter is offline   Reply With Quote
Old 03-22-2006, 09:01 AM   #6
JustA4
Member#: 58210
2004 35r STi
186mph - standing mile!
Thumbs up
Originally Posted by el tekk-O
whats EL?
www.Enginelogics.com
JustA4 is offline   Reply With Quote
Old 03-22-2006, 10:05 AM   #7
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
EL is your best bet...stay away from the stealership for jobs like that....way too expensive...and probably less experience doing the avcs install etc...
_R
RickInLittleElm is offline   Reply With Quote
Old 03-22-2006, 10:08 AM   #8
Hotrodguru
Member#: 37210
2016 Subaru WRX
Kenny from Gilman if he can do it on the side.
Hotrodguru is offline   Reply With Quote
Old 03-22-2006, 10:13 AM   #9
aschen
Member#: 30733
2007 tiny car
striped
Holy carp Ken, Your gonna love that engine. Be nice to teh tranny tho........
aschen is online now   Reply With Quote
Old 03-22-2006, 10:15 AM   #10
coolcougar
Member#: 19674
I've tried calling Kenny from Gilman a couple times but he has yet to call back so I get the impression that he's not that interested in doing this... I'm going to contact EL today and see what they say.... I'm kind of leaning towrds the dealership as i have about $1000 in subaru bucks saved up.
Old 03-22-2006, 10:18 AM   #11
coolcougar
Member#: 19674
Yeah... I've already started composing a 'Just blew 2nd gear' thread in the transmission forum... I've already started saving...
Old 03-22-2006, 10:37 AM   #12
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
Geezus Ken. That'll rock. Now the car will finally be able to keep up with your driving skillz
How about having the dealership install the major things (longblock, AVCS crap, ECU wiring) and then you or EL stick on the easy stuff?
forced4 is offline   Reply With Quote
Old 03-22-2006, 10:39 AM   #13
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
EL pulls (and rebuilds) motors all the time
that's what they do
Old 03-22-2006, 10:45 AM   #14
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
Default not paying attention
That's the worst and most expensive option. EL builds performance motors and does it well. Dealerships fix rattles and replace broken parts..they don't build performance engines.
_R
Edit : re-read 1st post...OK, so engine is already assembled...EL is still a better choice
Old 03-22-2006, 10:45 AM   #15
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
$2007 Challenge: 1st gen Brat w/ WRX swap. 'Nuff said.
Old 03-22-2006, 10:47 AM   #16
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
_R
The way Ken was talking it is all put together. So no building involved Since Ken has $1k of Suby Bucks to burn, why not use them to do the major stuff?
I see your point though Rick.
Old 03-22-2006, 10:51 AM   #17
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
Suby bucks.....nice....hate to waste them on over-priced labor, though but that would make it easier on the wallet.....
Rick continues to wave the EL flag
_R
Old 03-22-2006, 10:53 AM   #18
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
I think if kenny did it, subaru bucks may not cover...
and it sounds like Ken is gonna be an SM driver now...
DanzBorin is offline   Reply With Quote
Old 03-22-2006, 10:53 AM   #19
Hotrodguru
Member#: 37210
2016 Subaru WRX
Well thats true but it's an assembled long block so not like there is alot of assembly to do there. Just pull out the longblock and drop in the new 2.5L.
Guru
P.S. Kenny at Gilman has done MANY MANY modded engine swaps and does mod installs there at the dealer all the time.
Old 03-22-2006, 10:54 AM   #20
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
There is a Brat in my neighbor's field that I've been eyeing......would make a perfect project. I'm gonna try to talk 'em out of it.
Old 03-22-2006, 10:55 AM   #21
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
Guru
...Well shut my mouth! ...looks like you have plenty of good options then.
Old 03-22-2006, 11:02 AM   #22
MartinG
Member#: 89610
2006 STI Silver
Honda Civic & CRX Old
I have no doubt that Kenny at Gillman North would do it right. He is no stranger to procedures like this. I believe he used to build race engines for motor boats. But using GN may be the more expensive option. Why don't you give the service writer, Chris Wehe 281 209 4327, a call and see what they would charge you?
MartinG is offline   Reply With Quote
Old 03-22-2006, 11:03 AM   #23
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
Ken, how much do you want for your 2.0 long block/harness/ecu?
Old 03-22-2006, 11:08 AM   #24
DanzBorin
Member#: 7131
2015 Outback - Croc
project SF swap?
Old 03-22-2006, 11:12 AM   #25
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
Originally Posted by DanzBorin
project SF swap?
affirmative
Need advice on engine replacement beckoswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-12-2007 04:47 PM
Need a JL Subwoofer installed in Houston Geoff Texas Impreza Club Forum -- TXIC 1 09-27-2007 12:11 PM
Help with engine install in Houston - Sunday April 30th coolcougar Texas Impreza Club Forum -- TXIC 60 06-02-2006 09:00 PM
My engine is blown, need advice on engine options GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-26-2004 07:21 PM
Need Advice on Upgrading Stereo in 1998 Forester S jeromekelly Forester Forum 12 05-30-2003 10:33 AM
