Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Old 12-06-2008, 09:55 AM   #1
sonicsam
Member#: 95494
2001 Forester STi
Rustoleum Gloss White
Question Missing the bolts that hold a STI driveshaft together, what to do??
Hi all,
I did a fair bit of searching and didn't find much on the connecting bolts for the two piece 2006 STI Driveshaft. I got the driveshaft in seperated condition missing those joining bolts.
I got my hands on a 02-06 impreza parts manual but no where in there does it list driveshaft components. I also looked through the service manual for 06 sti and no where did they list or even show those bolts except for in a cross section detail drawing. The bolts are not mentioned anywhere else, I guess they weren't meant to be taken out.
Subaru Genuine Parts told me I can't order them, so what can I do? Can I just buy some bolts at Home Depot or the local hardware store? I'm worried they might not be strong enough and shear. Has anyone else ran into this problem?
Thanks in advance.
sonicsam is offline   Reply With Quote
Old 12-06-2008, 04:52 PM   #2
ovr_bst
Member#: 111298
2006 WRX TR stg 2
Crystal Grey
check your local driveshaft shop. the dealer can not order anything but the assembly. most driveshaft shops can and will rebuild the shaft- or get/supply/sell you the bolts
ovr_bst is offline   Reply With Quote
Old 12-07-2008, 07:09 AM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Go to Home Depot with your measurements from it. Buy about three bolts that you think will fit, one right size, one over, and one under. Go home and fit them to determine what size is best and write this down. Return the bolts (real men don't return anything FYI) or put them in your shop coffee can o' nuts and bolts and order real bolts from McMaster Carr. If you break out your local yellow pages you should have a local hardware store that specializes in nuts/bolts that will sell you Grade 10 or better bolts....high grade hardware is what you want to use. If you have a local shop, you could even bring in the driveshaft and do a running fit in the store and they could recommend and test fit on the spot. Bolts are bolts, but in this case I'd errr on the size of going too high.
Old 12-07-2008, 11:25 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The head of the bolts are 12mm which is import as they fit the profile of the driveshaft. They are M8x1.25 bolts that are about an inch long with matching nuts and lock washers.
Tony
Old 12-08-2008, 09:05 PM   #5
t3t4meat
Member#: 196972
make sure you use grade 8 hardware and you should not have any problems.
t3t4meat is offline   Reply With Quote
Old 12-08-2008, 09:06 PM   #6
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
^^ what he said!
djerickd is offline   Reply With Quote
Old 12-09-2008, 02:52 PM   #7
kleinkid
Member#: 27091
2010 STi SE
Default these should work
There is a good chance these are good part numbers, for your application.
Washer 903200005
Bolt 901660010
Nut 021808000
kleinkid is offline   Reply With Quote
Old 12-10-2008, 08:55 AM   #8
rice h8r
Member#: 94524
^ Where did you get that information?
rice h8r is offline   Reply With Quote
Old 12-10-2008, 08:12 PM   #9
sszyma
Member#: 31399
2007 WRX
2015 SQ5
mcmastercarr.com
any type, grade of bolt you could ever wish for.
sszyma is offline   Reply With Quote
Old 12-10-2008, 08:30 PM   #10
sonicsam
Member#: 95494
2001 Forester STi
Thanks so much guys for all the info. VERY HELPFUL. I very much appreciate it.
kleinkid, where'd you get that info? Do you have a service manual page that illustrates those bolts and their location?
Old 12-11-2008, 01:22 AM   #11
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Dude, they are bolts. Go get some grade 8 and call it a day!!
aboothman is offline   Reply With Quote
Old 12-11-2008, 11:46 AM   #12
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
get grade 8 and save the tiny amount over 10.9, i'm sure nothing bad will come of it. but who cares if it does your only stuck somewhere.
Mr_Snips is offline   Reply With Quote
Old 12-11-2008, 04:13 PM   #13
Do_It_Sidewayz
Member#: 24372
the 12mm head is very important here....
Most mechanics shops that work on alot of Japanese stuff will have replacement bolts in their "tool rooms"
the dealer likely does also. you are looking for JIC standard bolts
Do_It_Sidewayz is offline   Reply With Quote
Old 12-11-2008, 06:21 PM   #14
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
OK, lets put an end to the misinformation!!
I hate to tell Tony that he is wrong, but he is. He is on the right track, but off a size.
Straight from my 2006 STi driveshaft sitting in my garage:
Bold Head: 14mm
Bolt: M10, 1.25 thread pitch
Length: 35mm, with plenty of room left over
Mine has regular (non-flanged) m10 1.25 nuts, and lock washers.
BUY GRADE 8 OR BETTER, FROM ANY LOCAL HARDWARE STORE. As Unabomber said, a bolt is a freaking bolt...with exception for grade of course
/thread
Old 03-06-2011, 04:52 PM   #15
bigbenp
Member#: 216142
'04 & 11 STi's
'10 & 14 Foresters
Bump from the dead....
I decided to replace my driveshaft bolts during a clutch swap since the ones I took off are starting to round a little.
aboothman is right...If you replace your driveshaft or disconnect the bolts and need to replace them, the bolts you need are M10x1.25x35mm JIS. I found a supplier online, as all the local bolt shops (Fastenal, Grainger, etc...) didn't carry the correct JIS bolts/nuts. The head on standard M10 bolts is 17mm, and the JIS is 14mm and just fits in the driveshaft union.
http://www.clipsandfasteners.com/Pro...uctCode=A14790
http://http://www.clipsandfasteners....uctCode=A10589
http://www.clipsandfasteners.com/Pro...uctCode=A14797
Here is a comparison of the bolt I removed from my driveshaft to one I picked up from a local autoparts store.
I did place an order with SGP using the part numbers in this thread, I will post the comparison to the stock nut/bolts and the nut/bolts I ordered from clipsandfasteners.com
***UPDATE***The previously listed part numbers were updated by Jamie at SGP for my 04 STi and have been ordered...
032008000 (M10x1.25 JIS Nut with 14mm Head)
021808006 (Washer)
901700144 (M10x1.25 JIS Bolt with 14mm low clearance head)
bigbenp is offline   Reply With Quote
Darn it... Just stripped the threads on the bolt that holds the knock sensor in. Surestick Normally Aspirated Powertrain 3 04-21-2010 05:28 PM
I got the best xmas present ever and I dunno what to do b_tapper Off-Topic 218 12-27-2004 04:35 PM
STi stolen/recovered..what to do?? Qbushido Off-Topic 18 09-25-2004 10:48 PM
Badly Rashed Sti Gold Rims: What to Do? STI_Jaguar North West Impreza Club Forum -- NWIC 4 08-08-2004 02:59 AM
Got some new toys today. Then broke the bolt that holds the neg battery terminal down Kwyjibo Southern California Impreza Club Forum -- SCIC 2 02-12-2003 02:21 AM
