Brakes & Suspension Forum sponsored by The Tire Rack |
01-30-2006, 01:22 PM | #1 |
Member#: 98214
Vehicle:2004 WRX, Stage 2 Silver |
Post lowering spring camber recommnedations for alignment
Hi everyone. I just lowered my car this weekend. I went with the Crucial springs that are 1.25" front and 1" rear. I am extremely happy with them. I do not do any track racing, but I like driving the curvey back roads aggresively. I am looking for suggestions on my camber settings for when I get my car aligned this week. I remember reading a thread with suggestions, but I have been unable to find it or anything in my search that helps me out much. A friend recommended -.5. Does this sound good? Thanks in advance for any help you can offer.
01-30-2006, 01:34 PM | #2 |
Member#: 65699
Vehicle:15 WRX WR Blue |
The rear is not adjustable.....you'll see -1 to -1.5 typically. Adjust the front for as much camber as you can get. Again, typically - 1 to -1.3. Tire wear will not be affected at all. 0 toe all around.
01-30-2006, 01:56 PM | #3 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Being dropped 1.25" in the front you should be able to get at least -2*. That would probably be good in the front. The rear is not adjustable without camber bolts and you would likely be at -1.25*. Those camber setting should be good for what you want to do. I would also recommend 0 toe all around as a mix between having the best tire wear and fun ride.
Tony |
01-30-2006, 02:17 PM | #4 |
Member#: 98214
Thank you very much!!
01-30-2006, 05:00 PM | #5 |
Member#: 98214
I guess I'm better off getting your opinion on caster as well..... Thanks!
01-30-2006, 05:13 PM | #6 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
I'd say -2deg might be a bit much if all he's doing is aggressive street driving. I'd aim for about -1.5deg. It depends on how often he hits the curvey back roads, I guess. If it's only every once in a while, then that -2deg will (from my experience) begin to wear the inner shoulder of the tire (yes, even with 0 toe all around). If he's hitting the back roads every day, then -2deg should work out fine.
Pat Olsen '97 Legacy 2.5GT sedan |
01-30-2006, 05:16 PM | #7 | |
Member#: 65699
01-30-2006, 05:29 PM | #8 | |
Member#: 98214
Damn, can anyone spot the WRX noob here??!! I even did the install myself with a buddy and I don't know why I didn't make the connection...... |
01-30-2006, 05:27 PM | #9 | |
Member#: 98214
I take the back roads about 5 days a week. I'm thinking 1.5 from what you are all saying. |
Similar Threads | ||||
Tanabe GF210 Lowering Springs in stock for 05-06 WRX and STi! | GNV Motorsports | Suspension/Brakes/Handling | 4 | 07-12-2006 12:44 PM |
lowering springs and swaybars for 06 wrx | djsniggedy | Brakes, Steering & Suspension | 4 | 01-23-2006 09:33 AM |
Swift Lowering Springs - In Stock for all Suby Models | J-Spec Tuning | Suspension/Brakes/Handling | 13 | 11-22-2005 11:52 AM |
lowering springs and coilovers for sale | colt45_high | Interior & Exterior Modification | 2 | 08-09-2004 07:20 PM |
Lowering Spring Install Directions for WRX | SleeperWRX | Brakes, Steering & Suspension | 8 | 08-06-2002 02:13 PM |
