05-09-2020, 03:01 PM | #2026 | |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
https://www.bobistheoilguy.com/forum...-km-4500-miles https://www.bobistheoilguy.com/forum...30#Post5340524 5k is the max that I would go on any of them.
05-09-2020, 04:12 PM | #2027 | |
Member#: 485637
I'm just starting to learn what to look for in the uoa reports...lots of reading...my wife is wondering wtf is up with reading for days and days and days about oil. Lol. Last edited by TexasWRXs; 05-10-2020 at 04:55 AM. |
05-09-2020, 05:37 PM | #2028 |
Member#: 419593
My wife thinks I lost my mind but I love reading and learning about this stuff.
05-13-2020, 01:02 PM | #2029 |
Member#: 431550
Vehicle:2016 WRX ALL THE STAGES |
2016 WRX -- 102k chassis -- only 2k on built block
Cobb AP3 IAG stage 2 block - stock heads killer B down pipe EWG header - tial 38mm (2x) GS TMIC GS intake GS EBCS socal v3 turbo killer B oil pick up (great oil pressure btw) tapped manifold for M1 - 5 jets total (4 mani + 1 GS bung) Aquamist methkit Car was etuned for 93 and 93 + M1. Peak boost was 25psi tapering down to 20ish. The thing hauled HARD. Definitely fun and quick. For reference I was keeping up with scat pack chargers (assuming they were stock) and absolutely gapping 350/370z. No dyno since they were closed for this plandemic virus. Cyl 3 toasted when corresponding meth jet popped out of the threading thus leaning out cyl 3. Waiting for tear down to see if block is salvageable with just replacing piston or if i need a new short block. Really hoping heads are fine. I don't think I will ever tap plastic ever again. Mind you, I had inspected the lines just hours before the death pull. Probably just going to stick to the 1 jet on the GS tmic for cooling and go FLEXFUEL. |
05-13-2020, 01:09 PM | #2030 |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
Holy crap that sucks, yeah I would opt for the IBR BRZ manifold if you are going to run that M1 manifold setup again, maybe talk to them to see if they can help create a solution for it.
07-05-2020, 03:33 PM | #2031 |
Member#: 457300
Vehicle:2015 WRX Black |
Things to note:
--Car is a 2015 Subaru WRX Premium 6-Speed manual --As of this writing the car has close to 71K miles on it --Her name is Julie --From factory I got front and rear weathertech mats for a good price --From factory I got a STi short throw shifter --I've had multiple Blackstone lab results on my motor oil and it proves to hold up very well. I have been constantly using magnetic oil drain plugs for a while to catch any extra metal parts the filter doesn't get to/misses Motor Oil Used: --Motul 8100 X-Clean EFE 5W-30 Synthetic oil Front and Rear Diff fluid Used: --Motul Gear 300 Fully Synthetic Gearbox Oil - 75W90 Performance mods: --IAG TGV Delete --EGR delete (may be IAG but not sure. They all seem of similar quality anyway so doesn't seem to matter) --Invidia 2015+ WRX J-Pipe/Downpipe (High-flow CAT) coupled with Corsa Catback muffler. I believe it is 3" piping --IAG AOS street version --COBB intake --Perrin Pitch Stop --Cobb 3-Port Boost Control Solenoid --Process West top mounted Verticooler --SouthBend Clutch Stage 2 Daily. Stock flywheel. Was resurfaced. Clutch and fork were done by my Tuner along with a Walnut blasting at around 45K miles. --Verus Clutch fork and ball --JR Tuned at PrimeMotoring on Dyno --Premium Dimpled & Slotted Brake Rotors (#RB-47032) --Front Akebono ACT1078 ProACT Ultra-Premium Ceramic Brake Pad Set --Rear Akebono ACT1114 ProACT Ultra-Premium Ceramic Brake Pad Set --Bled brakes using Motul (2 Pack) 100950 100% Synthetic Brake Dot 5.1 Brake Fluid 1/2 Liter or 500 ml Non-Performance mods: --Mid range hornblasters. I have a stock Subaru fog light switch going to 40 amp relay from old fog light set for the compressor in trunk. Horns are in bumper. Hooked with a 3 way switch to go from stock horns to train horn. Looks pretty stealthy in the car. Pain to install (neatly) and get working. Horn is triggered by the stock steering wheel horn --BlackVue front and rear dashcams. Wiring routed neatly. Wired up to the cig plug in center console --Pioneer AVH-X5600 2-DIN head unit. Was essential since the stock head unit left MUCH to be desired. Sound quality increased immensely and left stereo this way. Only gripe I have is it lacks good noise cancelation when on a phone call but otherwise works great. Would love a quality Android head unit but keeping this one. The stock speakers sounded WAY better afterwards --All front headlights (high/low) changed over to LED from Subispeed. This was one of the first mods I did since the Stock bulbs were TERRIBLE. Blinkers left on stock bulbs because I could care less about that --Backup alarm that I can switch on and off. Reverse lights work whether I have the alarm enabled or not. Just for fun. Combined with the train horn you can reverse, have reverse alarm enabled, and tap horn twice to sound like a huge 18-wheeler is backing up or something like that --17" BBS wheels with all season Michellin Sports tires. Still have the stock wheels. May get set of summer and winters and switch them seasonally --Max 360 Escort radar detector. Wired neatly and tapped into switched cig lighter wiring Put the switch for it neatly in console --Interior lighting green from LEDGUYS Current issue with car: --Code P2270... Seems to be my rear O2 sensor. I may of resolved issue by ultimately putting new rear downstream sensor in car. Had tried with original sensor using one of those restrictor fittings but that is frowned upon since it is considered a defeat device. I had removed that and put sensor directly in muffler stream as it is designed to be. |
07-06-2020, 09:26 AM | #2032 |
Member#: 177056
Vehicle:2020 CX-5 Turbo 2015 WRX |
And we care, why?
07-06-2020, 11:29 AM | #2033 | |
Member#: 431550
Your motor seems to be just fine. |
07-06-2020, 07:54 PM | #2034 |
Member#: 504042
SCIC
Vehicle:2018 WRX ISM |
I read this ^^ halfway and feel like being trolled so skipped to the end. Turns out, I was trolled. His engine is fine...
08-07-2020, 04:19 PM | #2035 |
Member#: 7156
SCIC
Vehicle:2016 Subaru WRX Grey |
Model/Year: 2016 WRX Base 6MT
Milage:53,026 EM: None Mods: None Fuel: 91 (California) Oil: Mobil 1 5W30 Circumstances: Driving home from the beach in moderate traffic, started losing power. Turned stereo off, heard rod knock. Actual engine failure: Dealer only told me needs a new short block, but I assume spun bearing/rod knock. Will know more when they tear it down next week, dealer covering everything under warranty. Note: I've owned modded WRXs and STIs before, this time I decided to just leave it alone and I'm glad I did. |
08-13-2020, 08:51 AM | #2036 |
Member#: 463147
First post on Nasoic, came for unfortunate reasons. 6th Subaru, first turbo and WRX.
16 WRX bought with 85k miles, installed IAG AOS (street series) everything else stock. 87k miles, driving home from work with cruise at 74mph when a semi flung a few rocks at my car and cracked the windshield, coincidentally, (obviously unrelated) my car started loosing power (seemed like throttle was sputtering to Maintain speed). Oil temp went from 205 to 240, pulled off the highway and heard the knock. Shut down the engine, called a tow, and checked the oil (it was clean). Dealership called me yesterday told me I need to replace everything (9400 in repairs). Thought I was okay buying this WRX as it had one owner that was a mid-40 something year old guy with full service records. Guess not. |
08-13-2020, 11:28 AM | #2037 |
Member#: 453427
Not the first story I've heard with cruise control grenading engines on this platform, especially in 6th gear.
08-14-2020, 01:30 PM | #2038 | |
Member#: 467692
08-14-2020, 01:32 PM | #2039 | |
Member#: 467692
08-14-2020, 01:47 PM | #2040 | |
Member#: 467692
08-14-2020, 03:55 PM | #2041 |
Member#: 431550
I don't think anyone should be using cruise control on manual for anything under 3k rpms. 5th gear at 3k rpm = 70mph.
08-17-2020, 11:12 AM | #2042 |
Member#: 501446
Vehicle:'15 WRX gone plaid |
08-19-2020, 10:10 AM | #2043 |
Member#: 486921
NESIC
Vehicle:2018 Outback Tungsten |
I don't know what kind of highways you guys are losing these engines on. Up here in the Adirondacks from i-87 to i-90 which is known for having rolling hills especially into the Berkshires of Massachusetts having a long hill climb to the highest point on i-90 east of the Dakotas I constantly run my cruise control at 70-80mph in 6th. The car never builds boost while under cruise control even through that mountain climb in the Berkshires.
How does cruise control cause such ludicrous cylinder pressures that you're getting bent rods? You'd think you'd be getting this from more severe lugging, there isn't anything wrong with mild pedal pressure in 6th even when starting low at 2000rpm ~60mph I have an EGR/TGV delete with a Grimmspeed EBCS, 93 octane and flex fuel, dyno tuned at Bren Tuning. 32k miles and I run Motul 5w30 EFE, OEM oil filter Last edited by Mike1Juliet; 08-19-2020 at 10:16 AM. |
08-19-2020, 10:32 AM | #2044 | |
Member#: 431550
Mild pedal pressure in 6th means you are in control of the throttle = most likely throttling with out hitting boost at all. Cruise control will simply adjust the throttling to achieve set MPH. I would not trust that in 6th in general. Then again, I like to play it somewhat safe while doing daily driver things. I try to understand the gearing in a very rudimentary sort of way --- higher gear at lower RPM = engine having to work harder to accelerate (aka lugging). There are enough granade stories out there on any platform where low rpm + high load results in a bent rod. I wouldn't risk it. |
08-19-2020, 10:50 AM | #2045 | |
Member#: 486921
NESIC
Yes, I can say reasonably that I can, in 6th gear at 2000rpm, mildly accelerate without pushing the turbo above 0 psi or anything that would be considered "lugging". I don't actually feel that the car is working very hard in this scenario. My second point is that in my area's rolling hills or long hill climbs, 6th gear at 70-80mph doesn't appear to be lugging either in that the cruise control is able to maintain a set speed without making positive turbo pressure. That being said I don't have a real idea as to what cylinder pressures I could be getting as turbo pressure doesn't tell you much about cylinder pressure, maybe that is lugging but I'm still having a hard time conceptualizing that this is severe enough to cause bent rods. |
08-19-2020, 12:35 PM | #2046 | |
Member#: 431550
01-15-2021, 06:16 AM | #2047 |
Member#: 309174
Model/Year: 2016 WRX Premiem
Milage: 167,773 EM: Cobb ap with Protune Mods: Cobb intake, nameless J pipe, nameless muffler deletes Fuel: 93 octane Circumstances: I was driving to work in the highway going about 70 mph. I down shifted and did a brief pull to get off the exit, less the 50% throttle. I noticed oil temps slowly moving past their normal range. I'm usually around 206 to 212. The oil temps where around 250. I exit the off ramp. I didn't notice the car shut off. The car was hard to restart, but being stuck on a high speed off ramp wasn't an option. After 2 attempts the car starts. The engine sounds very bad, like something rod or piston related . I've only owned the car for less then 2 months. Actual engine failure: Not confirmed , but pretty sure. |
01-15-2021, 09:26 AM | #2048 | |
Member#: 512891
Vehicle:2010 STi/21 Passport RIP 19 WRX & 16 FXT |
01-15-2021, 01:33 PM | #2049 | |
Member#: 446029
01-18-2021, 12:20 PM | #2050 | |
Member#: 418242
Vehicle:2017 WRX |
