Welcome to the North American Subaru Impreza Owners Club Monday July 13, 2020
Old 07-18-2017, 07:28 PM   #51
teds-rex
Member#: 400886
2004 STi
Originally Posted by RexKwonDo View Post
Was there a point at which Subaru stopped using these filters in the banjo bolt? My '17 STI now shows OCI at 6k miles recommended by the owner's manual...so I'm wondering if they abandoned them entirely or ?
I am wondering this as well. I know my '04 had them and are removed, but wondering about my '09. TSB was from that year, but you would think they maybe had some idea before it came out?
teds-rex is offline   Reply With Quote
Old 07-19-2017, 02:09 PM   #52
Marvick08GT
Member#: 469091
I bought this car at 150k. Pulled the bolt to replace the filter (never removed) and it was clean. Not even 1 piece of sediment or debris. I'm wondering if some people have casting material in the head that comes off? I put a new one in.. Turbos need fresh clean oil.
Sorry, 2008 Legacy Gt
Marvick08GT is offline   Reply With Quote
Old 07-20-2017, 09:04 PM   #53
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Here's the 2017 I don't see a filter in the banjo's bolts.
http://estore.subarupartswarehouse.c...10-040-02.html
Look around that site you may be able to find the oil pipes and other banjo's.
Max Capacity is offline   Reply With Quote
Old 07-20-2017, 09:54 PM   #54
teds-rex
Member#: 400886
2004 STi
I don't think it's as simple as that. If you look up the '04 for example I don't see the filters either as they are "part" of the banjos I believe. Still curious if the new models carry these. Has anyone '09+ checked this?
Old 07-20-2017, 10:03 PM   #55
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
over the years ive followed threads about the banjo bolt filters. it seems 99% of the issues is with neglected cars with bad maintenence.
424wrx is offline   Reply With Quote
Old 07-21-2017, 06:44 AM   #56
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
I seem to recall seeing somewhere they were listed as banjo, filter.
There is also a thread here with pictures of each model and where the banjo filters are. I have that bookmarked on my home PC but not here on my lap top.
I did get that picture from this site.
I know they moved them to the top on the OCV's on the 07-09 Legacy GT's.
Have you done a Google search asking where are they located ?
Old 07-22-2017, 06:49 AM   #57
teds-rex
Member#: 400886
2004 STi
Wink
on the same site, if you check out the cylinder head diagram it looks like they still use filters on '17
(3) = 14445 UNION SCREW AND FILTER ASSEMBLY 14445AA090
actually even the same PN as the late '04-'05... does look like there was a redesign in mid '04 though.
14445AA060
'02, October ó '04, March
14445AA090
'04, February ó '04, March
'04, January ó '05, May
'05, April ó '06, June
'06, June ó '07, June
Old 07-24-2017, 12:00 PM   #58
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Thanks for taking the time to find that.
Old 11-07-2017, 02:18 AM   #59
Kevinscott
Member#: 477285
Default 2007 Outback XT - where is the turbo oil line banjo bolt?
Hi all:
I have just experienced the P0011/0021 code. Spent the day online looking at videos and wondering if my turbo is toast or if I can get way with just removing the filters at the banjo bolts on the turbo oil line and/or the AVCS banjo bolt filters.
Some background: I have noticed a drop in power at lower revs, some difficulty starting the car, occasional hesitation pulling away from stop lights and terrible average mileage - 14.4 mpg in mostly city driving.
First step was an oil change. Then I tried to get at the banjo bolt that is supposed to be at the back of the right cylinder, next to the turbo, that supplies the turbo. Pulled the heat shield off the turbo and there was no banjo bolt where I expected one to be. I think most of the videos I saw were 2004 and 2005 cars.
Here's a pic of where I expected it to be. Does not look like what is in the TSB or on any video I saw. Was there a change in 2007?
I will proceed to remove the filters at the other two locations for the AVCS and see if that helps. I'd still like to have an idea where the line that feeds the turbo is and remove the filter there (if there is one in the 2007). Would not want to toast that. Only 68k miles on this car.
Thanks!
Kevin
Kevinscott is offline   Reply With Quote
Old 11-07-2017, 02:18 AM   #60
Kevinscott
Member#: 477285
Hi all:
Link to the pic as the forums don't seem to like where I have hosted the pic: https://laycock.smugmug.com/Other/n-...ts/i-nDMG8Cm/A
Thanks!
Kevin
Old 01-27-2018, 04:54 PM   #61
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Just checked my 05' STi since it's on the lift in my garage and I'm working on it. Checked the two AVCS banjo bolts. No filters in them at all in lodged anywhere they shouldn't be. I am pretty sure I checked these two 7+ years ago and also confirmed no bolt filters... just forgot about them. Never changed the turbo filter. Found a youtube video and someone showing where it was. I removed that banjo bolt and the filter was 100% clean, nothing in it. I removed it anyways just because everything is off and I'd rather not have to do this again.
I do change oil on this car every 3k miles using Motul. In fact this is the only car I have that has ever had 3k oil changes. Rest of our fleet is either 5k for my truck/wifes toyota, or 10k for the Merc and Lexus.
Completely agree on the filters in the bolts being an idiotic design. Why they didn't include some type of inline filter just seems like extra work to have a filter in a freaking banjo bolt...
Good thread! Hope no one else's stuff gets trashed.
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 10-27-2018, 01:01 AM   #62
Rvicen34
Member#: 475941
Default Looking at buying an 05 LGT
The car Iím looking into says it has a new turbo and clutch, 116k and Carfax says tranny was replaced a ways back. Iíve read the ďsti vs LGTĒ thread and many say donít even look at one that says ďnew turboĒ. If it has a new turbo is it because of the banjo or could it be something else? Iím taking it to a Performance shop that works Subaruís to have them look it over. Just wondering what to look for. Any help is appreciated
Rvicen34 is offline   Reply With Quote
Old 08-31-2019, 10:22 PM   #63
s0nic0nslaught
Member#: 505858
2013 Impreza WRX
WR Blue
Default 2013 USDM WRX w/ EJ255
I have a pretty much bone stock 2013 WRX with an EJ255. Is it likely that these filters are still in the banjo bolts on this model year? It seems, according to the parts documentation from Subaru, that some of the locations I've seen referenced in posts elsewhere do not have filters in the bolts.
According to the Subaru parts literature I've reviewed, on the 2013 MY WRX these filters would be present in the following locations: top turbo main bearing inlet bolt, front of drivers side head, and rear of passenger side head under the intake.
Any confirmation on this? Visually I can see that only these locations have the bolts with the little protrusion on the head which seems to be characteristic of the bolt with the filter screen.
s0nic0nslaught is offline   Reply With Quote
Old 08-31-2019, 10:26 PM   #64
s0nic0nslaught
Member#: 505858
2013 Impreza WRX
WR Blue
Does anyone know if these filters still exist on the USDM EJ255 on the 2013 WRX? My search of the Subaru parts literature suggests there are three. One is under the intake on the passenger side which looks..fun..to remove.
Old 10-23-2019, 10:07 PM   #65
Saidaigen8
Member#: 349548
2011 wrx
black
11+ don't have them for the turbo's.
Still there for each avcs.
Saidaigen8 is offline   Reply With Quote
Old 11-11-2019, 05:42 PM   #66
bo0sted2g
Member#: 218513
2005 Legacy GT
BSM
I need to do this this weekend
bo0sted2g is offline   Reply With Quote
Old 11-16-2019, 11:16 PM   #67
SLOMNUTS
Member#: 507835
08 WRX
I just bought a 2008 WRX from a buddy of mine. He changed the oil every 2500 miles so Iím debating whether or not to remove the banjo filter from the oil line to the turbo. After reading some, I see thereís a couple more also. Any advice on what I should do would be appreciated. Thanks.
SLOMNUTS is offline   Reply With Quote
Old 11-18-2019, 08:02 AM   #68
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Despite having turbo failure at 82k miles due to a clogged screen, I still have all screens and have added another 100k miles. I only run xW-40 or Euro xW-30 and change the oil every 5k.
Old 11-18-2019, 09:56 PM   #69
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Yes, the screens are there for good reason. They prevent large debris from damaging the turbo and causing the avcs solenoids to stick. If a large enough piece of debris gets into the avcs, it can cause a malfunction of the valve timing. The bulletin shown only states to clean or replace the screen. Even with a few pieces of debris in the screen, there is more than enough area for sufficient oil supply. If you're worried about the screens, be sure to change your oil regularly and more often if you track it obviously. You can also just remove the screens to inspect them every 30-40k miles to be sure they are staying clean.
2slofouru is offline   Reply With Quote
Old 11-22-2019, 09:55 PM   #70
SLOMNUTS
Member#: 507835
08 WRX
Thanks. Thatís great advice. Appreciate it.
Old 12-05-2019, 12:01 AM   #71
metalheadsunite
Member#: 163465
Thanks for the insight. Was searching around for the filter stuff but didn't know the AVCS had them. I'll have to put that on the list for next time I do oil change.
metalheadsunite is offline   Reply With Quote
Old 06-27-2020, 11:27 AM   #72
wjfawb0
Member#: 122526
2020 Subaru STI
A friend's GM truck had a similar issue with the filter for the oil supply to the valvetrain. Apparently it was an issue for many GM V8s. The screen would clog and starve oil to the valvetrain. I found a how to for him to follow to fix it. Just cleaning or removing the screen didn't help aparently. The grit that would build up would drain back down the oil supply hole and just clog the new filter or be sent into the valvetrain. There are youtube videos for cleaning the system during a new filter install.
I'm going to go change the oil on my STI now.
wjfawb0 is offline   Reply With Quote
Old 06-27-2020, 12:59 PM   #73
benflynn
Member#: 515308
I replaced the turbo side line to turbo and AVCS, now my AVCS are off a degree or so, guessing the other side is a lil clogged, harder to get to tho
benflynn is offline   Reply With Quote
Old 06-27-2020, 02:29 PM   #74
jbolduc33
Member#: 516180
One of 3 post b4 I'm allowed to start my own thread.
jbolduc33 is offline   Reply With Quote
