Welcome to the North American Subaru Impreza Owners Club Monday July 13, 2020
Old 11-17-2019, 03:14 PM   #1
What could go wrong
Member#: 448908
Default Oil on uppipe, should I be concerned?
Hey guys, I have an 09 WRX 5mt. I have been noticing a melting rubber smell from the passenger side wheel well for a while now but assumed it was the AC drain on the new downpipe or something, but today I found some oil on the up-pipe. I have been doing lots of work around the power steering system, cooling system, and I just did an oil change if any of that matters. any advice on the leak? pictures at the bottom.
There is oil on the inside of the splashguard, and the heatshield, but the actual flange is bone dry. Maybe a valve cover seal or something? I kinda doubt its an oil line because I haven't really been losing more oil than normal, I only added 110ml of oil to keep the car completely topped up right before the last oil change. definitely not a head gasket failure, oil looked clean coming out and looks clean now a few days later, no smoke, no knock, coolant looks good, etc.
any advice would be greatly appreciated, thanks, guys.
https://ibb.co/6v14S6Z
https://ibb.co/xgvY1rp
What could go wrong is offline   Reply With Quote
Old 11-17-2019, 05:24 PM   #2
dryvby
Member#: 49931
0305 wrx/Xt
black/black
Iíd suspect the valve cover gasket and check there. It could be the feed line leaving the head that supplies the turbo tho like you said.
dryvby is online now   Reply With Quote
Old 11-18-2019, 12:57 PM   #3
What could go wrong
Member#: 448908
Thanks, ill check it out. Any advice on how to check that gasket? Is it obvious if you are looking for it?
Old 11-18-2019, 02:33 PM   #4
subi-T
Member#: 348082
2006 impreza
SGM
I would check the Valve cover gasket as well but before taking that apart Iíd check the AVCS breather hose thatís on the top side valve cover.
subi-T is offline   Reply With Quote
Old 11-18-2019, 02:44 PM   #5
klinebau
Member#: 122383
2006 WRX Wagon
Are you sure its not a torn CV boot that is flinging out grease?
klinebau is offline   Reply With Quote
Old 11-18-2019, 05:01 PM   #6
dryvby
Member#: 49931
0305 wrx/Xt
black/black
Yes. Jack the car up and youíll be able to see the bottom side of the whole gasket quite easily. Itís about a 30min job to replace it. You may want to have a replacement on hand along with the two spark plug gaskets.
Old 11-18-2019, 06:16 PM   #7
NickVu
Member#: 27525
03 wrx wagon
yellow
Also those 10mm bolts on the valve cover gaskets bottom out on metal shoulders. Once they get tight, snug them down with wrist or finger force. The spec was something like 4.7ft-lb. They'll rip up threads or snap if you're not careful.
NickVu is offline   Reply With Quote
Old 11-18-2019, 08:08 PM   #8
What could go wrong
Member#: 448908
AVCS Breather, ill check it out, thanks!
I'd sure hope not, just had them replaced... I'll add it to the list though!
Thanks! I'm just hoping the job won't be hell if/when I go to do it
Ill post back in a couple of weeks when I get the time to put the car in the air. I have a suspicion the car has been like this for ages and I haven't been able to track down the leak for some reason, so I'll assume the engine inst going to explode provided I keep my eye on the oil level. Thanks for the help yall!
Old 06-27-2020, 10:39 PM   #9
What could go wrong
Member#: 448908
Just for future reference, it was valve cover gaskets. Also, the bad gaskets may have helped drop oil pressure enough to be an accomplice in the destruction of my rod bearings.
Old 06-28-2020, 08:46 PM   #10
IrishNYer
Member#: 492645
08 WRX
Shhhhh....
Do you have an oil cooler? Because, I had my oil cooler go on me before and the air forced it onto the exhaust.
IrishNYer is offline   Reply With Quote
