Welcome to the North American Subaru Impreza Owners Club Monday July 13, 2020
Old 04-01-2020, 02:24 PM   #1
What could go wrong
Member#: 448908
Default GR ECU issues
So, I had a rod bearing failure (unrelated) and just put in a new engine. The only hardware modifications are the cobb intake and downpipe. It was running rich as hell during startup, it would clean up after a minute or so, then get rough again then die.
They were getting ready to pull the engine again and check the valve clearance, but someone threw a known good ECU in before just for ****s and grins and it fixed things immediately (aside from the fact its probably lean because of the hardware modifications)
Here is where things get weird, the car is on cobb stage 2+, tuned with an AP, the parameters on the old ECU that are wrong (fuel trims or whatever) STAY WRONG
It doesn't matter if we reset the ECU, idle re-learn, uninstall/reinstall the AP, nothing, the parameters stay wrong. Presumably, the ECU isn't totally dead, as the car attempts to start (and runs properly for a little) so it isn't "broken" necessarily, but we can't seem to get things going on the old ecu.
Now as fun as it sounds to basically blow another $1000 on a new ECU, anyone have any advice on getting the old one working? is there like a proper reset of some variety I don't know about?
Thanks in advance for any help ya'll
What could go wrong is offline   Reply With Quote
Old 04-01-2020, 03:38 PM   #2
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
So you say you swap the ECU and it fixed it? Then it started acting up again with same ecu?
spoolinsti05 is offline   Reply With Quote
Old 04-01-2020, 03:48 PM   #3
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
What you might want to look into is the capacitors. These commonly go bad in electronics.
I had a CSM that had this issue. Yeah not a (dsm) similar however mine was a 4g61t no balance shafts little 1.6L dohc. And the fuel trims would always be off. No matter what tuning I had done. Replaced the capacitors based on a write-up I found and issue was gone.
Old 04-01-2020, 09:11 PM   #4
What could go wrong
Member#: 448908
Thanks for the help, I'll look into it!
Old 04-10-2020, 01:16 PM   #5
What could go wrong
Member#: 448908
I ended up just biting the bullet and getting a new one, didn't want to risk such an important component.
Another symptom it presented with was not correcting AFR. When the engine was running poorly, the AFR was 12ish at idle, but AFR correction wasn't doing anything. Just in case anyone else has a similar problem.
Also, could re-flashing too often have caused this? maybe a bad ground or a bad sensor somewhere? I only ask because I am trying to avoid having this thing crap out on me on the ride home. Thanks guys.
Old 04-10-2020, 04:32 PM   #6
subaru_gc8
Member#: 29292
2004 WRX wagon
I know on the 02-05 16bit ecus there is limit, but I dont think the other have a flash lilmit. and if you brick it you would know. Sometimes ECUs go bad I ave a JDM one that controls the left head avcs okay but not the right.... so yeah Stupid computer stuff
subaru_gc8 is online now   Reply With Quote
Old 06-27-2020, 10:48 PM   #7
What could go wrong
Member#: 448908
that sucks, it's kinda weird these cars don't have a self-diagnostic for the computer, I wouldn't think it would be spectacularly difficult to implement when there are entire operating systems for PC's that can repair themselves nowadays... granted my car is a decade old but still...
