Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2020
Old 06-12-2020, 12:13 AM   #1
chris the man
Member#: 287783
08 predator evo X
RR
Default Stock Oil-Pickup owners, chime in
Hi all. Recently had a fresh motor build done.
I did not know or think to ask for an upgraded oil pickup.
I have spoken to 2 separate shops that say they focus more on bearing issues before they do oil pickups as they do not see fault caused by pickups as much as they do other discrepancies before hand.
This is my 3rd Subaru, the other two I put over 30k miles on each and never upgraded as well.
Do I have any other built motor, higher HP builds in here that are on the stock pickup?
Thank you!
chris the man is offline   Reply With Quote
Old 06-12-2020, 12:17 AM   #2
Haevn
Member#: 495950
2011 WRX
i would think it would be cheap insurance to put it in when the pan is already out
Haevn is offline   Reply With Quote
Old 06-12-2020, 12:23 AM   #3
chris the man
Member#: 287783
08 predator evo X
RR
For sure. I would hate to yank my new pan with a fresh gasket for this ordeal.
Old 06-12-2020, 07:26 AM   #4
Jay11STI
Member#: 492422
Just upgrade to the Killer B oil pick up and trey kit.
Jay11STI is offline   Reply With Quote
Old 06-12-2020, 08:13 AM   #5
08redWRX
Member#: 186068
2019 STi
If you had a fresh motor build done i assume you're already into it thousands of dollars so why not spend the extra bit on the first oil change and swap it out for extra insurance.
08redWRX is offline   Reply With Quote
Old 06-25-2020, 08:56 AM   #6
lapwizrus
Member#: 77443
I have a 4EAT and 30k on an IAG stage 1 shortblock. When I installed it I bought a new OEM pickup. My thinking is that my engine coupled with the auto transmission sees less shock than one with a manual transmission so the chances of failure are not as high. No issues yet. With a manual tranny I probably would have went with a killerb pickup.
lapwizrus is offline   Reply With Quote
Old 06-25-2020, 09:13 AM   #7
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Have no idea what shops you are talking to but for less than $200 you can get a KillerB oil pan pick-up. Cheap insurance because if the OEM pick-up fails, you just lost your motor. How much did you say you spent on this new motor?
There is a long thread on oil pan pick-up failures. This is not a new issue.
Ditch what the shops are telling you.
Now, while it doesn't mean the OEM pick-up will fail today or tomorrow, or even at all, there is a proven track record of OEM oil pan pick-up failures.
Which side of the failure rate do you want to be on?
Samurai Jack is offline   Reply With Quote
Old 06-25-2020, 09:13 AM   #8
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Like other folks have said...
Cheap insurance!
When I pulled my motor apart the first time, I saw the dodgy welds on the pickup tube. It's pretty well known that Subaru's have some oiling issues at higher power levels, so a $100 pickup tube just makes sense. I've used the Moroso pickup and Killer B pickup in my engine builds. I didn't notice any significant differences between the two, but I liked the Killer B a bit better.
BeastianSTI is offline   Reply With Quote
